DDR address 0x88000000 - 0x90000000 is reserved for M4, conflicts may
happen if we set the CONFIG_FASTBOOT_BUF_ADDR as 0x80280000 and
the CONFIG_FASTBOOT_BUF_SIZE as 0x19000000.
Change the CONFIG_FASTBOOT_BUF_ADDR to 0x98000000 to avoid such issue.
Change-Id: I141b6b3efc40d36ec6eb523e6ffb804c314dba52
Signed-off-by: Luo Ji <ji.luo@nxp.com>
This commit did:
1. Sync AVB lib with external/avb, head of commit is:
commit 6d5326a945c2d17d5d0e7718d5cb97663c3b33a2
Author: Neal Ostrem <nealo@google.com>
Date: Tue Apr 24 13:09:45 2018 -0700
Merge fix/changes required after merge from AOSP ToT.
Change library name to one used by AT.
Test: Built successfully and unit tests pass.
Change-Id: I5e5fc9a6010d96cfecfc6faf0858ba930cba65a0
2. Change product id in ATX to be full zeros to sync with
external/avb.
3. Fix build errors and implement ops fsl_set_key_version.
4. Move most nxp modified code to lib/avb/fsl/.
Test: build and boot successfully for imx7d_pico and imx8m_phanbell.
Change-Id: I199a035fe8267b10955299a4b745458d40a2e754
We can get the bootimage SD/MMC offset at runtime according to the SOC type and
version. No need to use CONFIG_BOOTLOADER_OFFSET_33K and CONFIG_BOOTLOADER_OFFSET_32K
any longer, so remove them.
Signed-off-by: Ye Li <ye.li@nxp.com>
(cherry picked from commit 63af66f27c2c1b836c6dd48eb9901d622007e4a4)
Add board level support for android and android auto. Each board has
android/andriod_auto specified header file for defining relevant configuraitons.
And add build targets for their android uboot images building.
