path: root/include/configs/io.h
2016-07-01autoboot: remove CONFIG_ZERO_BOOTDELAY_CHECKMasahiro Yamada
As the help message of CONFIG_BOOTDELAY says, CONFIG_BOOTDELAY=-2 means the autoboot with no delay, with no abort check even if CONFIG_ZERO_BOOTDELAY_CHECK is defined. To sum up, the autoboot behaves as follows: [1] CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=y autoboot with no delay, but you can abort it by key input [2] CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=n autoboot with no delay, with no check for abort [3] CONFIG_BOOTDELAY=-1 disable autoboot [4] CONFIG_BOOTDELAY=-2 autoboot with no delay, with no check for abort As you notice, [2] and [4] come to the same result, which means we do not need CONFIG_ZERO_BOOTDELAY_CHECK. We can control all the cases only by CONFIG_BOOTDELAY, like this: [1] CONFIG_BOOTDELAY=0 autoboot with no delay, but you can abort it by key input [2] CONFIG_BOOTDELAY=-1 disable autoboot [3] CONFIG_BOOTDELAY=-2 autoboot with no delay, with no check for abort This commit converts the logic as follow: CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=n --> CONFIG_BOOTDELAY=-2 Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Stefan Roese <sr@denx.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Christian Riesch <christian.riesch@omicronenergy.com> Acked-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
2016-04-08powerpc: Replace CONFIG_SYS_INIT_RAM_END with CONFIG_SYS_INIT_RAM_SIZEYork Sun
CONFIG_SYS_INIT_RAM_SIZE may be used out of the board header file. Some boards use CONFIG_SYS_INIT_RAM_END for the same purpose. To unify the macros, use CONFIG_SYS_INIT_RAM_SIZE for all. Signed-off-by: York Sun <york.sun@nxp.com> CC: Mario Six <mario.six@gdsys.cc> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Anatolij Gustschin <agust@denx.de>
2015-10-21cmd: Convert CONFIG_CMD_ELF to KconfigBin Meng
Convert CONFIG_CMD_ELF to Kconfig and tidy up affected boards. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-06-08autoboot.c: Move config options to KconfigStefan Roese
This patch moves the following config options to Kconfig: CONFIG_AUTOBOOT_KEYED CONFIG_AUTOBOOT_PROMPT CONFIG_AUTOBOOT_DELAY_STR CONFIG_AUTOBOOT_STOP_STR AUTOBOOT_KEYED_CTRLC Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Drop ip04 and pm9263 configs/ additions, those boards previously set CONFIG_AUTOBOOT_PROMPT but never used it, re-run savedefconfig over all boards that did change. Make digsy_mtc_* string include seconds to match others and not warn. ] Signed-off-by: Tom Rini <trini@konsulko.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com>
2014-07-25board: Add CONFIG_SYS_GENERIC_BOARD to all gdsys boardsDirk Eibach
Add the generic board infrastructure to all gdsys boards. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Stefan Roese <sr@denx.de>
2014-07-07fit: make sha256 support optionalDirk Eibach
sha256 has some beefy memory footprint. Make it optional for constrained systems. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2014-07-07board: gdsys: Remove commands to reduce footprintDirk Eibach
Commit "2842c1c fit: add sha256 support" badly increased memory footprint, so some of our boards did not build anymore. Since monitor base must not be changed I removed some commands to save memory. Maybe making sha256 optional for fit would be an option for the future since it really has some beefy footprint. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2014-02-19configs: Delete obsolete macro, CONFIG_SYS_GBL_DATA_SIZEMasahiro Yamada
CONFIG_SYS_GBL_DATA_SIZE is not used any more. The size of struct "global_data" is automatically calculated by asm-offsets. (See lib/asm-offsets.c) GENERATED_GBL_DATA_SIZE should be used instead of CONFIG_SYS_GBL_DATA_SIZE. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-01-24powerpc: ppc4xx: remove redundant CONFIG_4xx definitionMasahiro Yamada
We do not have to define CONFIG_4xx in board config headers because it is defined in arch/powerpc/cpu/ppc4xx/config.mk. include/configs/JSE.h defines "CONFIG_4x", not "CONFIG_4xx". I believe it is a typo because "CONFIG_4x" is not used at all in other files. So, I also deleted "CONFIG_4x" in include/configs/JSE.h. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-07-25powerpc/ppc4xx: Remove CONFIG_SYS_FLASH_PROTECTION from gdsys boardsDirk Eibach
CONFIG_SYS_FLASH_PROTECTION was active on most gdsys boards by default, while hardware flash protection was not implemented. Hardware support was added recently and we get into trouble because backward compatibility is broken (u-boot can't unprotect the protected flash after a downgrade). So we decided to disable hardware flash protection for all our boards. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Stefan Roese <sr@denx.de>
2013-07-25powerpc/ppc4xx: Use generic accessor functions for gdsys FPGADirk Eibach
A set of accessor functions was added to be able to access not only memory mapped FPGA in a generic way. Thanks to Wolfgang Denk for getting this sorted properly. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Stefan Roese <sr@denx.de>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23i2c, ppc4xx_i2c: switch to new multibus/multiadapter supportDirk Eibach
Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Heiko Schocher <hs@denx.de> Cc: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2012-04-30powerpc/ppc4xx: Update gdsys board configurationsDirk Eibach
Signed-off-by: Dirk Eibach <eibach@gdsys.de> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2012-04-30powerpc/ppc4xx: Adapt gdsys 405ep boards to platform changesDirk Eibach
Print fpga info at last_stage_init on gdsys 405ep boards. Use dtt_init() to startup fans. Signed-off-by: Dirk Eibach <eibach@gdsys.de> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2012-04-30powerpc/ppc4xx: Make gdsys 405ep boards reset more genericDirk Eibach
In order to add boards that have different hardware for fpga reset, any 405ep gdsys board now provides these functions: void gd405ep_init(void); void gd405ep_set_fpga_reset(unsigned state); void gd405ep_setup_hw(void); int gd405ep_get_fpga_done(unsigned fpga); Signed-off-by: Dirk Eibach <eibach@gdsys.de> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2011-02-07ppc4xx: Add DLVision-10G board supportDirk Eibach
Board support for the Guntermann & Drunck DLVision-10G. Adds support for multiple FPGAs per board for gdsys 405ep architecture. Adds support for dual link osd hardware for gdsys 405ep. Signed-off-by: Dirk Eibach <eibach@gdsys.de> Signed-off-by: Stefan Roese <sr@denx.de>
2010-10-25ppc4xx: Add Io and IoCon 405EP board supportDirk Eibach
Board support for the Guntermann & Drunck CATCenter Io. Board support for the Guntermann & Drunck IoCon. Signed-off-by: Dirk Eibach <eibach@gdsys.de> Signed-off-by: Stefan Roese <sr@denx.de>
