path: root/include/configs/ls1043a_common.h
2020-03-30dm: arm64: ls1043a: add i2c DM supportBiwen Li
This supports i2c DM and enables CONFIG_DM_I2C for SoC LS1043A Signed-off-by: Biwen Li <biwen.li@nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
2019-11-27armv8: ls1043aqds: modify the qspi_bootcmd definitionWen He
Fix the kernel offset of qspi_bootcmd scripts, followed the qoriq_memory_layout definition. Signed-off-by: Wen He <wen.he_1@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2019-11-08freescale/layerscape: Rename the config CONFIG_SECURE_BOOT nameUdit Agarwal
Rename CONFIG_SECURE_BOOT to CONFIG_NXP_ESBC to avoid conflict with UEFI secure boot. Signed-off-by: Udit Agarwal <udit.agarwal@nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
2019-05-26configs: Migrate CONFIG_FMAN_ENET and some related options to KconfigTom Rini
Move the main symbol for Freescale Fman Ethernet controller option to Kconfig. Also migrate the CONFIG_SYS_QE_FMAN_FW_IN_xxx macros and rename the SPIFLASH one to follow the same format as all of the others. To do this fully we need to migrate CONFIG_QC, do so. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-05-22armv8: Secure Boot: Modify boot_a_script definitionVinitha V Pillai
esbc_validate command will not be executed if “load” command for its header fails and will further execute the source command for bootscript, without its validation and boot process continues. To halt the boot process in case secure boot header is not loaded successfully, esbc_validate command is invoked separately after “load” command. The secure boot validation of the bootscript header will fail (if header is not loaded) and halts the boot process, which prevent source command from execution. Signed-off-by: Vinitha V Pillai <vinitha.pillai@nxp.com> Signed-off-by: Udit Agarwal <udit.agarwal@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-03-25Convert CONFIG_ENV_SPI_* to KconfigPatrick Delaunay
This converts the following to Kconfig: CONFIG_ENV_SPI_BUS CONFIG_ENV_SPI_CS CONFIG_ENV_SPI_MAX_HZ CONFIG_ENV_SPI_MODE Most of time these value are not needed, CONFIG_SF_DEFAULT with same value is used, so I introduced CONFIG_USE_ENV_SPI_* to force the associated value for the environment. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2019-03-03board: ls1043a: use default scan_dev_for_bootMian Yousaf Kaukab
Default environment variable is more complete. Also scans for efi binaries for example. Signed-off-by: Mian Yousaf Kaukab <ykaukab@suse.de> Reviewed-by: Ashish Kumar <Ashish.Kumar@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-03-03board: ls1043a: enable dhcp bootMian Yousaf Kaukab
dhcp boot is a useful feature and works out-of-the-box on these platforms. Enable it as a boot source. Signed-off-by: Mian Yousaf Kaukab <ykaukab@suse.de> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-02-19armv8: layerscape: move CONFIG_LAYERSCAPE to KconfigRajesh Bhagat
Moves CONFIG_LAYERSCAPE for all NXP Layerscape platforms. Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-02-19QE: ls1043a: modify CONFIG_SYS_QE_FW_ADDR to (512*4A00) in SD CardZhao Qiang
Due to the new layout of Layerscape series, move the QE firmware to address (512*4A00) in SD Card. Signed-off-by: Zhao Qiang <qiang.zhao@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-02-19armv8: ls1043ardb: Add the nand_bootcmd definitionWen He
nand_bootcmd doest not exist, it should be support for nand auto boot up. Signed-off-by: Wen He <wen.he_1@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-01-17ls1043a: add support for nand-boot cmd for TFAPankit Garg
Signed-off-by: Pankit Garg <pankit.garg@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-12-06armv8: ls1043ardb: Add TFABOOT supportRajesh Bhagat
TFABOOT support includes: - ls1043ardb_tfa_defconfig to be loaded by trusted firmware - environment address and size changes for TFABOOT - FMAN and QE address changes for TFABOOT - define BOOTCOMMAND for TFABOOT Signed-off-by: Pankit Garg <pankit.garg@nxp.com> Signed-off-by: Vinitha V Pillai <vinitha.pillai@nxp.com> Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-07-26armv8: layerscape: Drop u-boot-with-spl.bin for selected boardsYork Sun
For SPL boot with PBL, u-boot-with-spl-pbl.bin is the final image. Drop unused u-boot-with-spl.bin. Signed-off-by: York Sun <york.sun@nxp.com> CC: Mingkai Hu <mingkai.hu@nxp.com> CC: Ruchika Gupta <ruchika.gupta@nxp.com> CC: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> CC: Udit Agarwal <udit.agarwal@nxp.com> CC: Sumit Garg <sumit.garg@nxp.com> CC: Priyanka Jain <priyanka.jain@nxp.com>
2018-04-15Merge git://git.denx.de/u-boot-imxTom Rini
2018-03-29drivers: i2c: mxc: Update SYS_I2C_MXC_I2C support in KconfigSriram Dash
NXP layerscape platforms like ls1088a, ls2088a uses MXC I2C Controller. -Remove dependency of MX6 for the same. Update related configs to use Kconfig file. -Add SYS_I2C_MXC_I2C1,_I2C2,_I2C3,_I2C4 in Kconfig -Add CONFIG_SYS_MXC_I2C1_SPEED,_I2C2_,_I2C3_,_I2C4_ in Kconfig -Add CONFIG_SYS_MXC_I2C1_SLAVE,_I2C2_,_I2C3_,_I2C4_ in Kconfig Signed-off-by: Sriram Dash <sriram.dash@nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
2018-03-16Convert all of CONFIG_CONS_INDEX to KconfigTom Rini
This converts the following to Kconfig: CONFIG_CONS_INDEX We have existing entries for this option in a number of places, with different guards on them. They're also sometimes used for things not directly inside of the serial driver. First, introduce a new symbol to guard the use of CONFIG_CONS_INDEX, so that in the case where we don't need this for the serial driver, but for some other use, we can still do it. Next, consolidate all of these into the single entry in drivers/serial/Kconfig. Finally, introduce CONS_INDEX_[023456] so that we can imply a correct value here to make the defconfig side of this smaller. Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Rework a lot of the logic here, such that I took authorship from Adam, but kept his S-o-B line] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-23Remove config_distro_defaults.hAdam Ford
With the contents of config_distro_defaults.h migrated to Kconfig, we can remove this header file completely Signed-off-by: Adam Ford <aford173@gmail.com>
2017-12-06SECURE BOOT: Add fall back optionVinitha Pillai-B57223
Add fall back option, to boot from NOR/QSPI/SD for LS1043, LS1046, LS1021 in case of distro boot failure. For LS1046, add kernel validation in case of secure boot in sd_bootcmd and qspi_bootcmd. For LS1043 and LS1021, add kernel validation in case of secure boot in sd_bootcmd, qspi_bootcmdand nor_bootcmd. Signed-off-by: Vinitha Pillai <vinitha.pillai@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-11-15armv8: ls1043ardb: Add sd_bootcmd for distro fallback in case of sdbootShengzhou Liu
Signed-off-by: Shengzhou Liu <Shengzhou.Liu@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-10-27net: remove CONFIG_NET_MULTIMasahiro Yamada
This macro is defined, but not referenced by anyone. I did not touch config_whitelist.txt - the CONFIG will be dropped by the next re-sync. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-10-09armv8: ls1043ardb_sdcard: prepare falcon bootYork Sun
Due to a conflict with recent Primary Protected Application (PPA), PPA cannot be loaded for SPL stage, falcon boot is not enabled by default. With compatible PPA image, to enable falcon boot, activate these Kconfig options in defconfig CONFIG_SPL_FIT=y CONFIG_SPL_FSL_LS_PPA=y CONFIG_SPL_GZIP=y CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_OS_BOOT=y CONFIG_SPL_OF_LIBFDT=y Because environment variables are not avaiable during SPL stage for SD boot, set "boot_os=y" as default. Signed-off-by: York Sun <york.sun@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-22armv8: ls1043a: disable IFC in SPL only when QSPI is usedYangbo Lu
Current u-boot disables IFC support for SD boot on all ls1043a boards. Actually IFC only conflicts with QSPI on ls1043a hardware. Only when QSPI is used, IFC should be disabled. Otherwise, the u-boot with ls1043aqds_sdcard_ifc_defconfig would not work. Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-09-03include/configs: remove numerous CONFIG_SYS_BARGSIZE definitionsThomas Petazzoni
This commit removes definitions of CONFIG_SYS_BARGSIZE defined to be equal to CONFIG_SYS_CBSIZE in numerous configuration files. We remove such definitions in two situations: - CONFIG_SYS_CBSIZE is otherwise not defined in the board configuration file, which means the default value of CONFIG_SYS_CBSIZE == 256 applies. In this case, the default value of CONFIG_SYS_BARGSIZE == 512 (common/image.c) is suitable, as it is larger. - CONFIG_SYS_CBSIZE is defined in the board configuration file, but to a value equal or less than 512. In this case, the default value of CONFIG_SYS_BARGSIZE == 512 (common.image.c) is suitable, as it is equal or larger. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_PBSIZEThomas Petazzoni
Now that the fallback value of CONFIG_SYS_PBSIZE in include/config_fallbacks.h has been adjusted, remove its definition from a large number of board configuration files. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-08-13spl: moveconfig: remove SPL_LDSCRIPT definitions for header-filesPhilipp Tomsich
With the hierarchical defaults set up, we remove these from the header files. To do so, I've run moveconfig on SPL_LDSCRIPT and this commits the changes. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-01arm64: ls1043ardb: Add distro secure boot supportSumit Garg
Enable validation of boot.scr script prior to its execution dependent on "secureboot" flag in environment. Disable fall back option to nor/qspi boot in case of secure boot. Also enable "secureboot=y" flag in environment for ARM based platforms instead of bootcmd. Signed-off-by: Sumit Garg <sumit.garg@nxp.com> Tested-by: Vinitha Pillai <vinitha.pillai@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-08-01arm64: ls1043ardb: Add distro boot supportShengzhou Liu
Include common config_distro_defaults.h and config_distro_bootcmd.h for u-boot enviroments to support automatical distro boot which scan boot.scr from external storage devices(e.g. SD/USB/SATA/SCSI disk) and execute autoboot script. Tested on ls1043ardb with automatically boot Ubuntu from SD card or USB disk, if it fails to detect external storage disk, fall back to nor/qspi boot. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-06-05common: arm: freescale: layerscape: Move header files out of common.hSimon Glass
We should not have an arch-specific header file in common.h. Adjust the board files a little so it is not needed, and drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-01QE: add QE support on SD bootZhao Qiang
modify u_qe_init to upload QE firmware from SD card when it is SD boot Signed-off-by: Zhao Qiang <qiang.zhao@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-05-26Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
2017-05-23armv8: layerscape: Adjust memory mapping for Flash/SD card on LS1043AAlison Wang
This patch is to adjust the memory mapping for FLash/SD card on LS1043AQDS and LS1043ARDB, such as PPA firmware load address, FMAN firmware load address, QE firmware load address, U-Boot start address on serial flash and environment address. Signed-off-by: Alison Wang <alison.wang@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-05-22Kconfig: Drop CONFIG_CMD_ENVSimon Glass
This option is not used in U-Boot. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22lib: move hash CONFIG options to KconfigTom Rini
Commit 94e3c8c4fd7b ("crypto/fsl - Add progressive hashing support using hardware acceleration.") created entries for CONFIG_SHA1, CONFIG_SHA256, CONFIG_SHA_HW_ACCEL, and CONFIG_SHA_PROG_HW_ACCEL. However, no defconfig has migrated to it. Complete the move by first adding additional logic to various Kconfig files to select this when required and then use the moveconfig tool. In many cases we can select these because they are required to implement other drivers. We also correct how we include the various hashing algorithms in SPL. This commit was generated as follows (after Kconfig additions): [1] tools/moveconfig.py -y SHA1 SHA256 SHA_HW_ACCEL [2] tools/moveconfig.py -y SHA_PROG_HW_ACCEL Note: We cannot move SHA_HW_ACCEL and SHA_PROG_HW_ACCEL simultaneously because there is dependency between them. Cc: Poonam Aggrwal <poonam.aggrwal@freescale.com> Cc: Naveen Burmi <NaveenBurmi@freescale.com> Cc: Po Liu <po.liu@freescale.com> Cc: Shengzhou Liu <Shengzhou.Liu@freescale.com> Cc: Priyanka Jain <Priyanka.Jain@freescale.com> Cc: Shaohui Xie <Shaohui.Xie@freescale.com> Cc: Chunhe Lan <Chunhe.Lan@freescale.com> Cc: Chander Kashyap <k.chander@samsung.com> Cc: Steve Rae <steve.rae@raedomain.com> Cc: Dirk Eibach <eibach@gdsys.de> Cc: Feng Li <feng.li_2@nxp.com> Cc: Alison Wang <alison.wang@freescale.com> Cc: Sumit Garg <sumit.garg@nxp.com> Cc: Mingkai Hu <Mingkai.Hu@freescale.com> Cc: York Sun <york.sun@nxp.com> Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Cc: Jaehoon Chung <jh80.chung@samsung.com> Cc: Akshay Saraswat <akshay.s@samsung.com> Cc: Heiko Schocher <hs@denx.de> Cc: Jagan Teki <jagan@amarulasolutions.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-17armv8: ls1043a: Drop macro CONFIG_LS1043AYork Sun
Use CONFIG_ARCH_LS1043A instead. Signed-off-by: York Sun <york.sun@nxp.com>
2017-04-17arm: ls1043ardb: Add NAND secure boot targetRuchika Gupta
Add NAND secure boot target for ls1043ardb. - Change the u-boot size defined by a macro for copying the main U-Boot by SPL to also include the u-boot Secure Boot header size as header is appended to u-boot image. So header will also be copied from SD to DDR. - MACRO for CONFIG_BOOTSCRIPT_COPY_RAM is enabled to copy Bootscript from NAND to DDR. Offsets for Bootscript on NAND and DDR have been also defined. Signed-off-by: Vinitha Pillai <vinitha.pillai@nxp.com> Signed-off-by: Sumit Garg <sumit.garg@nxp.com> Signed-off-by: Ruchika Gupta <ruchika.gupta@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-04-17arm: ls1043ardb: Add SD secure boot targetRuchika Gupta
- Add SD secure boot target for ls1043ardb. - Implement FSL_LSCH2 specific spl_board_init() to setup CAAM stream ID and corresponding stream ID in SMMU. - Change the u-boot size defined by a macro for copying the main U-Boot by SPL to also include the u-boot Secure Boot header size as header is appended to u-boot image. So header will also be copied from SD to DDR. - CONFIG_MAX_SPL_SIZE is limited to 90KB. SPL is copied to OCRAM (128K) where 32K are reserved for use by boot ROM and 6K for secure boto header. - Error messages during SPL boot are limited to error code numbers instead of strings to reduce the size of SPL image. Signed-off-by: Vinitha Pillai-B57223 <vinitha.pillai@nxp.com> Signed-off-by: Sumit Garg <sumit.garg@nxp.com> Signed-off-by: Ruchika Gupta <ruchika.gupta@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-04-17armv8: ls1043ardb: SPL size reductionSumit Garg
Using changes in this patch we were able to reduce approx 10k size of u-boot-spl.bin image. Following is breif description of changes to reduce SPL size: 1. Changes in board/freescale/ls1043ardb/Makefile to remove compilation of eth.c and cpld.c in case of SPL build. 2. Changes in board/freescale/ls1043ardb/ls1043ardb.c to keep only ddr_init and board_early_init_f funcations in case of SPL build. 3. Changes in ls1043a_common.h & ls1043ardb.h to remove driver specific macros due to which static data was being compiled in case of SPL build. 4. Disable MMC driver from bieng compiled in case of SPL NAND build and NAND driver from bieng compiled in case of SPL MMC build. 5. Remove I2C driver support from SPL in case of LS1043ARDB. Signed-off-by: Vinitha Pillai <vinitha.pillai@nxp.com> Signed-off-by: Sumit Garg <sumit.garg@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
