path: root/include/configs/ls1046ardb.h
2016-09-14armv8: ls1046ardb: Add LS1046ARDB board supportMingkai Hu
LS1046ARDB Specification: ------------------------- Memory subsystem: * 8GByte DDR4 SDRAM (64bit bus) * 512 Mbyte NAND flash * Two 64 Mbyte high-speed SPI flash * SD connector to interface with the SD memory card * On-board 4G eMMC Ethernet: * Two XFI 10G ports * Two SGMII ports * Two RGMII ports PCIe: * PCIe1 (SerDes2 Lane0) to miniPCIe slot * PCIe2 (SerDes2 Lane1) to x2 PCIe slot * PCIe3 (SerDes2 Lane2) to x4 PCIe slot SATA: * SerDes2 Lane3 to SATA port USB 3.0: one super speed USB 3.0 type A port one Micro-AB port UART: supports two UARTs up to 115200 bps for console Signed-off-by: Mingkai Hu <mingkai.hu@nxp.com> Signed-off-by: Shaohui Xie <Shaohui.Xie@nxp.com> Signed-off-by: Gong Qianyu <Qianyu.Gong@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
