path: root/include/configs/meesc.h
2014-11-17spi, atmel: move CONFIG_SYS_SPI_WRITE_TOUT into common headerHeiko Schocher
move CONFIG_SYS_SPI_WRITE_TOUT into drivers/spi/atmel_spi.h and define a default value. Delete this define in the board config files, where it is possible (all boards use currently the same value). Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-12-09at91: nand: switch atmel_nand to generic GPIO APIAndreas Bießmann
Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Acked-by: Jens Scharsig (BuS Elektronik)<esw@bus-elektronik.de> Tested-by: Jens Scharsig (BuS Elektronik)<esw@bus-elektronik.de> Acked-by: Scott Wood <scottwood@freescale.com>
2013-11-09Merge branch 'iu-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: arch/arm/cpu/arm926ejs/mxs/Makefile board/compulab/cm_t35/Makefile board/corscience/tricorder/Makefile board/ppcag/bg0900/Makefile drivers/bootcount/Makefile include/configs/omap4_common.h include/configs/pdnb3.h Makefile conflicts are due to additions/removals of object files on the ARM branch vs KBuild introduction on the main branch. Resolution consists in adjusting the list of object files in the main branch version. This also applies to two files which are not listed as conflicting but had to be modified: board/compulab/common/Makefile board/udoo/Makefile include/configs/omap4_common.h conflicts are due to the OMAP4 conversion to ti_armv7_common.h on the ARM side, and CONFIG_SYS_HZ removal on the main side. Resolution is to convert as this icludes removal of CONFIG_SYS_HZ. include/configs/pdnb3.h is due to a removal on ARM side. Trivial resolution is to remove the file. Note: 'git show' will also list two files just because they are new: include/configs/am335x_igep0033.h include/configs/omap3_igep00x0.h
2013-11-04arm: atmel: get rid of too many ifdefferyBo Shen
Get rid of too many ifdeffery in usb ohci driver Add following two configuration for USB clock selecting - CONFIG_USB_ATMEL_CLK_SEL_PLLB: using PLLB as usb ohci input clock - CONFIG_USB_ATMEL_CLK_SEL_UPLL: using UPLL as usb ohci input clock Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-09-01ARM: Remove unused stack and irq config definesRob Herring
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present in most ARM board config files. IRQs are only enabled for 1 config, so remove the unused config options for IRQ and FIQ stack size as well. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-06-20CONFIG_SYS_BAUDRATE_TABLE: Add <config_fallbacks.h>, place thereTom Rini
We provide a default table of { 9600, 19200, 38400, 57600, 115200 } in <config_fallbacks.h> which mkconfig places after <configs/...h> in the generated config file. This is used when a board has not set its own table. Signed-off-by: Tom Rini <trini@ti.com>
2012-05-15include/configs: Remove CONFIG_SYS_64BIT_VSPRINTFTom Rini
This define does not control anything, remove it. Signed-off-by: Tom Rini <trini@ti.com>
2011-11-29Fix Stelian's email addressStelian Pop
Change my old email address which is no longer valid. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-11-05at91: defined mach-types for meesc board in board config fileDaniel Gorsulowski
quotation from Albert ARIBAUD: "Recently the ARM mach-types.h file has been brought in sync with its Linux original, leasing to a number of boards not being listed any more, as the new list only contains boards which have actual Linux support or were declared less than one year ago. The symptom is a build failure with a message of the form "error: 'MACH_TYPE_XXXXXX' undeclared (first use in this function)". U-Boot maintainers of such boards (in Cc: of this mail) should provide a patch to re-introduce the MACH_TYPE_XXXXXX definition in their boards' config header file in include/configs/." Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu>
2011-09-03at91: reworked support for meesc boardMatthias Fuchs
The meesc board support was broken. Within this opportunity, I completely reworked the board files. Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu> Signed-off-by: Matthias Fuchs <Matthias.Fuchs@esd.eu>
2010-10-29Drop support for CONFIG_SKIP_RELOCATE_UBOOTWolfgang Denk
For ARM systems, before ELF relocation was introduced, CONFIG_SKIP_RELOCATE_UBOOT coul be used to prevent *COPYING* the U-Boot image from whereever it was loaded to it's link address (CONFIG_SYS_TEXT_BASE). The name was badly chosen, as no relocation was performed at all, it was just a memcpy(). With ELF relocation, this does not work like that any more, and related boards need to be fixed anyway. So don't keep this relict any longer. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-08-20at91: Enabeling USB host on meesc boardDaniel Gorsulowski
There was an redesign, so USB is available now. Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-08-20at91: Update meesc board to new SoC accessDaniel Gorsulowski
* convert meesc board to use c stucture SoC access * change gpio access to at91_gpio syntax * moved CONFIG_SYS_HZ below board and cpu defines (purely cosmetic) Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-08-20at91: Defined main clock frequency on esd at91 boardsDaniel Gorsulowski
Autodetection is undesired now Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-04-03at91: boards cleanup for deprecated CONFIG_CMD_AUTOSCRIPTDaniel Gorsulowski
CONFIG_CMD_AUTOSCRIPT support is deprecated and non-existing This clean up patch removes the references for esd boards Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu>
2010-02-12add a new AT91 GPIO driverJens Scharsig
* add a real AT91 GPIO driver instead of header inline code * resolve the mixing of port and pins * change board config files to use new driver * add macros to gpio to realize backward compatibility Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
2010-02-12add new CONFIG_AT91_LEGACYJens Scharsig
* add's the new temporary CONFIG_AT91_LEGACY to all board configs This will need for backward compatiblity, while change the SoC access to c structures. If CONFIG_AT91_LEGACY is defined, the deprecated SoC is used. Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
2010-01-23at91: Enable slow master clock on meesc boardDaniel Gorsulowski
Normally the processor clock has a divisor of 2. In some cases this this needs to be set to 4. Check the user has set environment mdiv to 4 to change the divisor. Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu>
2009-12-08common: delete CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOULHeiko Schocher
There is more and more usage of printing 64bit values, so enable this feature generally, and delete the CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL defines. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-10-13at91: Update MEESC board supportDaniel Gorsulowski
This patch implements several updates: -disable CONFIG_ENV_OVERWRITE -add new hardware style variants and set the arch numbers appropriate -pass the serial# and hardware revision to the kernel -removed unused macros from include/configs/meesc.h -fixed multiline comment style Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu>
2009-07-18NAND: Part 2: Fix warning Please define CONFIG_SYS_64BIT_VSPRINTF...Wolfgang Denk
Commit 8d2effea added a warning for configurations that use NAND without defining the (then necessary) CONFIG_SYS_64BIT_VSPRINTF but failed to fix the affected boards. This patch covers the non-PPC boards that were missed in the previous patch (commit 170c1972). Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-06at91: Add esd gmbh MEESC board supportDaniel Gorsulowski
This patch adds support for esd gmbh MEESC board. The MEESC is based on an Atmel AT91SAM9263 SoC. Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu>
