path: root/include/configs/microblaze-generic.h
2016-09-16Convert CONFIG_SPL_NOR_SUPPORT to KconfigSimon Glass
2016-08-08spl_nor.c: Support devicetree sizes different from 16kMike Looijmans
The devicetrees for various platforms already exceed 16k. Add a define CONFIG_SYS_FDT_SIZE to specify the FDT size, and set to 16k for the two boards that define this CONFIG_SYS_FDT_BASE parameter. This allows platforms with larger devicetree blobs to boot from NOR. Signed-off-by: Mike Looijmans <mike.looijmans@topic.nl>
2016-07-22microblaze: Remove empty ifdef around cachesMichal Simek
Code around was removed because of move to Kconfig. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-04-04microblaze: Remove !OF_CONTROL code for timer and interruptMichal Simek
OF_CONTROL is enabled by default that's why this is dead code. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27microblaze: Fix board_init calling sequenceMichal Simek
board_init() is in final elf file but it is not called at all. Use board_init_late() instead and call gpio_init() from it. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27microblaze: Enable HUSH via KconfigMichal Simek
Cleanup board file. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27microblaze: Read information about RAM from DTMichal Simek
Do not setup ram start/size in board file. Read it from DT instead. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27microblaze: Move CONFIG_NETCONSOLE to KconfigMichal Simek
2016-01-27microblaze: Remove CONFIG_FIT from board fileMichal Simek
And enable it via defconfig by default. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27microblaze: Remove systemace from board fileMichal Simek
Systemace is ancient IP which is not tested. Remove it from default configuration. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27microblaze: Move eth configuration to KconfigMichal Simek
Cleanup board specific file. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27microblaze: Enable axi emac via KconfigMichal Simek
Enable driver by default for all platforms. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27net: emaclite: Move emaclite to KconfigMichal Simek
Add PHYLIB and MII dependencies and enable it by default for Microblaze. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-01-27microblaze: Enable MICREL_KSZ9021Michal Simek
To solve enabling ETH_DM where ksz90x1_reg_field is defined only when additional Micrel type is defined. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27microblaze: Enable PHYLIB via KconfigMichal Simek
Cleanup board configuration. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27microblaze: Enable uart16550 DM by defaultMichal Simek
Microblaze is uses uartlite or uart16550 as console drivers. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27serial: uartlite: Add uartlite to KconfigMichal Simek
- Move config option out of board file. - Remove uartlite address from config file Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Thomas Chou <thomas@wytron.com.tw>
2016-01-27microblaze: Move baudrate setting out driver selectionMichal Simek
Preparation of moving to DM. Uartlite ignores baudrate setting. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27microblaze: Remove CONSOLE_ARGMichal Simek
Take it from DT instead. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-12-18microblaze: Do not handle watchdog and gpio in SPLMichal Simek
watchdog and gpio are not validated for SPL that's why do not use them. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-12-18microblaze: Remove support for LL_TEMACMichal Simek
LL_TEMAC is available at big endian MB and it is not properly tested that's why the patch removes it. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-12-18microblaze: Use malloc setting via KconfigMichal Simek
Clean board specific file. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-12-18microblaze: Make room for malloc before ELFMichal Simek
Create space below u-boot binary for early malloc. It means memory layout is stack grows down, space for early malloc, u-boot code. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-08-18of: clean up OF_CONTROL ifdef conditionalsMasahiro Yamada
We have flipped CONFIG_SPL_DISABLE_OF_CONTROL. We have cleansing devices, $(SPL_) and CONFIG_IS_ENABLED(), so we are ready to clear away the ugly logic in include/fdtdec.h: #ifdef CONFIG_OF_CONTROL # if defined(CONFIG_SPL_BUILD) && !defined(SPL_OF_CONTROL) # define OF_CONTROL 0 # else # define OF_CONTROL 1 # endif #else # define OF_CONTROL 0 #endif Now CONFIG_IS_ENABLED(OF_CONTROL) is the substitute. It refers to CONFIG_OF_CONTROL for U-boot proper and CONFIG_SPL_OF_CONTROL for SPL. Also, we no longer have to cancel CONFIG_OF_CONTROL in include/config_uncmd_spl.h and scripts/Makefile.spl. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2015-05-19net: Remove all references to CONFIG_ETHADDR and friendsJoe Hershberger
We really don't want boards defining fixed MAC addresses in their config so we just remove the option to set it in a fixed way. If you must have a MAC address that was not provisioned, then use the random MAC address functionality. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-02-09microblaze: spl: Do not call mem_malloc_init and use early allocMichal Simek
This patch has some parts connected together: - Use _gd in bss section which is automatically cleared Location at SPL_MALLOC_END wasn't cleared at all - Use MALLOC_F_LEN(early alloc) instead of FULL MALLOC (mem_malloc_init is not called at all) - Simplify malloc and stack init. At the end of SPL addr is malloc area and below is stack Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-02-09microblaze: Add support for CONFIG_SYS_MALLOC_F_LENMichal Simek
Create space for dm_init where calloc is called and malloc_base has to be initialized. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-02-09microblaze: Move architecture to use generic board initMichal Simek
Compile code with -fPIC to get GOT. Do not build SPL with fPIC because it increasing SPL size for nothing. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-02-09microblaze: Enable SPL_NOR support when FLASH_BASE is setupMichal Simek
Simplify SPL NOR init. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-09-25kconfig: move CONFIG_DEFAULT_DEVICE_TREE to kconfigMasahiro Yamada
This option specifies the default Device Tree used for the run-time configuration of U-Boot. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@nvidia.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Michal Simek <michal.simek@xilinx.com>
2014-09-25kconfig: move CONFIG_OF_* to KconfigMasahiro Yamada
This commit moves: CONFIG_OF_CONTROL CONFIG_OF_SEPARATE CONFIG_OF_EMBED CONFIG_OF_HOSTFILE Because these options are currently not supported for SPL, the "Device Tree Control" menu does not appear in the SPL configuration. Note: zynq-common.h should be adjusted so as not to change the default value of CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@nvidia.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Acked-by: Michal Simek <michal.simek@xilinx.com>
2014-07-30include: remove CONFIG_SPL/CONFIG_TPL definition in config headersMasahiro Yamada
Now CONFIG_SPL and CONFIG_TPL are defined in Kconfig. Remove the redundant definition in config headers. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-07-30kconfig: delete redundant CONFIG_${ARCH} definitionMasahiro Yamada
CONFIG_${ARCH} is defined by Kconfig. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-07-30include: define CONFIG_SPL and CONFIG_TPL as 1Masahiro Yamada
We are about to switch to Kconfig in the next commit. But there are something to get done beforehand. In Kconfig, include/generated/autoconf.h defines boolean CONFIG macros as 1. CONFIG_SPL and CONFIG_TPL, if defined, must be set to 1. Otherwise, when switching to Kconfig, the build log would be sprinkled with warning messages like this: warning: "CONFIG_SPL" redefined [enabled by default] Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
