Porting the iMX6Q DDR3/LPDDR2 ARM2, iMX6DL DDR3/LPDDR2 ARM2 and
iMX6Q POP LPDDR2 ARM2 board codes from v2019.04.
Signed-off-by: Ye Li <ye.li@nxp.com>
(cherry picked from commit 8ce8ab2f9b875fe43489d7624a296f036e43e585)
(cherry picked from commit 34d29f3cdbf5e9f30ff9593295af4c85d3833ee3)
(cherry picked from commit 6f8ff60c04d8c5ab1e017db45ef6909f2d31447f)
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
CONFIG_MII
CONFIG_DRIVER_TI_EMAC
Acked-by: Jagan Teki <jagan@amarulasolutions.com>
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
This migrates ASIX, ASIX88179, MCS7830, RTL8152 and SMSC95XX to Kconfig.
Update defconfigs.
Signed-off-by: Chris Packham <judge.packham@gmail.com>
CONFIG_USB_HOST_ETHER is the framework that the drivers are dependent on
USB_HOST_ETHER. Use this as a menu and move the existing LAN75XX and
LAN78XX options under new menu. Finally update the defconfigs that need
CONFIG_USB_HOST_ETHER.
CONFIG_ENV_IS_IN_MMC
CONFIG_ENV_IS_IN_NAND
CONFIG_ENV_IS_IN_UBI
CONFIG_ENV_IS_NOWHERE
In fact this already exists for sunxi as a 'choice' config. However not
all the choices are available in Kconfig yet so we cannot use that. It
would lead to more than one option being set.
In addition, one purpose of this series is to allow the environment to be
stored in more than one place. So the existing choice is converted to a
normal config allowing each option to be set independently.
There are not many opportunities for Kconfig updates to reduce the size of
this patch. This was tested with
./tools/moveconfig.py -i CONFIG_ENV_IS_IN_MMC
And then manual updates. This is because for CHAIN_OF_TRUST boards they
can only have ENV_IS_NOWHERE set, so we enforce that via Kconfig logic
now.
The following options are migrated over fully now:
- USB_EHCI_ATMEL
- USB_EHCI_MARVELL
- USB_EHCI_MX6
- USB_EHCI_MX7
- USB_EHCI_MSM
- USB_EHCI_ZYNQ
- USB_EHCI_GENERIC
This also requires fixing the depends on USB_EHCI_MARVELL as it's used
by Orion5X and Kirkwood as well.
Migrate the rest of the users of CONFIG_USB_EHCI_HCD over to Kconfig.
For a few SoCs, imply or default y this if USB is enabled. In some
cases we had not already migrated to CONFIG_USB so do that as well.
In order to be able to migrate the various SoC EHCI CONFIG options we
first need to finish the switch from CONFIG_USB_EHCI to
CONFIG_USB_EHCI_HCD.
CONFIG_BOARD_EARLY_INIT_F
In some cases we were missing CONFIG_USB=y so enable that when needed.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
Move all standard mx6 MMC configs to mx6_common.
Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
Reviewed-by: Tom Rini <trini at konsulko.com>
Move all standard filesystem, partition and fdt options to mx6_common.
Move generic miscellaneous options that are standard across most, if not all,
mx6 boards to central mx6_common define to ensure consistent features.
Define common LOADADDR and BOOTDELAY to ensure a consistent experience
across mx6 boards
Define CONFIG_MXC_GPIO and CONFIG_CMD_GPIO by default in mx6_common
Define the standard ATAG consfigs in mx6_common.
All boards define CONFIG_MX6, CONFIG_DISPLAY_BOARDINFO, CONFIG_DISPLAY_CPUINFO
and CONFIG_SYS_GENERIC_BOARD so define them in mx6_common
The linux/sizes.h, asm/arch/imx-regs.h, asm/imx-common/gpio.h,
config_cmd_default.h includes are used fairly universally across imx6 boards
so include them in mx6_common.h by default.
We define CONFIG_SYS_NO_FLASH before config_cmd_default.h so that we
don't have to undef CONFIG_CMD_FLASH / CONFIG_CMD_IMLS everywhere.
Entering the maximum number of characters defined by CONFIG_SYS_CBSIZE into
the console and hitting enter afterwards, causes a hang in the system because
CONFIG_SYS_PBSIZE is not capable of storing the extra characters of the error
message:
"Unknown command '' - try 'help'".
Use the default CONFIG_SYS_PBSIZE definition from config_fallbacks.h to solve
this problem.
Cc: Jason Liu <r64343@freescale.com>
Acked-by: Jason Liu <r64343@freescale.com>
Add pinmux settings and implement board_ehci_hcd_init
Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
Update the ddr scripts for LPDDR2 and add two build configs for LPDDR2
arm2 board. Since the LPDDR2 arm2 board has different DDR size, use
CONFIG_DDR_MB in defconfig to replace the PHYS_SDRAM_SIZE.
Signed-off-by: Ye.Li <B37916@freescale.com>
This patch adds the i.MX6DL arm2 board support. The i.MX6DL ARM2
shared the same board with i.MX6Q ARM2 board since the i.MX6DL is
pin-pin compatible with i.MX6Q.
The patch also support the DDR 32-BIT mode option. Please define
CONFIG_DDR_32BIT in the board configure file to enable DDR 32-BIT
mode.But due to the board design, it's 64bit DDR buswidth physically,
so, if you CONFIG_DDR_32BIT, the DDR memory size will be half of it.
1. Set the image load partition to the first FAT partition.
2. Set the kernel rootfs partition to the second partition.
To support loading FDT file for kernel, add the fdt address,
file and loading script to arm2 board default environment.
Define CONFIG_SYS_FSL_ESDHC_ADDR using USDHC4_BASE_ADDR.
USDHC3 and USDHC4 are both initialized in board_mmc_init. There is
no restriction on USDHC3 addr or USDHC4 addr should be assigned to
CONFIG_SYS_FSL_ESDHC_ADDR. So, just choose USDHC4_BASE_ADDR to avoid
errors when fsl_esdhc_mmc_init is invoked.
Enable the CONFIG_SYS_GENERIC_BOARD for imx6q/dl arm2 board to
use generic board.
Change the default environment to use zImage instead of uImage, this
requires changes to the default environment to load a file named
zImage instead of uImage, and to use the 'bootz' command instead of
'bootm' when booting the kernel.
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
There is no real benefit in adding the board name into U-boot's prompt, so
remove the custom CONFIG_SYS_PROMPT definitions so that the standard "=> "
prompt is used across FSL boards.
Remove platform CONFIG_SYS_HZ definition for configs a-z*.
[trini: Fixup common/cmd_io.c]
Now that U-Boot has common CONFIG_ options to work around some ARM CPU
errata, enable the relevant options on MX6, and remove the custom
lowlevel_init.S, since it's just duplicated code now.
Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
README
board/samsung/universal_c210/universal.c
drivers/misc/Makefile
drivers/power/power_fsl.c
include/configs/mx35pdk.h
include/configs/mx53loco.h
include/configs/seaboard.h
Commits 6dc71c8 "MMC: MXS: Toggle the generic bounce buffer on the
boards" and 49a627f "MMC: Remove the MMC bounce buffer" replaced
CONFIG_MMC_BOUNCE_BUFFER with CONFIG_BOUNCE_BUFFER, but missed
converting a few boards over to the new option. Fix this.
Signed-off-by: Andy Fleming <afleming@freescale.com>
Use CONFIG_MX6 when the particular processor
variant isn't important.
Reserve the use of CONFIG_MX6Q to
specifically test for quad cores variant.
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
Fix usage of 'mmc rescan' by many configs. Proper use is
'mmc dev ${mmcdev}; mmc rescan' to set the mmc device and then rescan
the device. 'mmc rescan' itself does not take any arguments.
Signed-off-by: Andrew Bradford <andrew@bradfordembedded.com>
Data cache and CONFIG_MMC_BOUNCE_BUFFER can be safely enabled now.
Define default SoC input clock frequencies for i.MX5/6 in order to get rid of
duplicated definitions.
Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
Cc: Matt Sealey <matt@genesi-usa.com>
Cc: Fabio Estevam <fabio.estevam@freescale.com>
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present
in most ARM board config files.
IRQs are only enabled for 1 config, so remove the unused config options
for IRQ and FIQ stack size as well.
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
All mx6 based boards should use arch_cpu_init().
Exactly one board has defined CONFIG_SYS_PROMPT_HUSH_PS2 to a value
different than "> " which is vision2. I have Cc'd the maintainer here
as I strongly suspect this is a bug rather than intentional behavior.
We provide a default table of { 9600, 19200, 38400, 57600, 115200 }
in <config_fallbacks.h> which mkconfig places after <configs/...h> in
the generated config file. This is used when a board has not set its
own table.
Allow booting a zImage kernel.
