path: root/include/configs/odroid_xu3.h
2016-09-27dfu: Migrate to KconfigTom Rini
Introduce a hidden USB_FUNCTION_DFU Kconfig option and select it for CMD_DFU (as we must have the DFU command enabled to do anything DFU). Make all of the entries in drivers/dfu/Kconfig depend on CMD_DFU and add options for all of the back end choices that DFU can make use of. Cc: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com>
2016-04-20usb: gadget Move: CONFIG_G_DNL_* to KconfigSam Protsenko
And also reformat defconfigs using "make savedefconfig" rule. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: dwc3: Move CONFIG_USB_DWC3_PHY_* to KconfigSam Protsenko
2016-04-20usb: dwc3: Move CONFIG_USB_DWC3_GADGET/HOST to KconfigSam Protsenko
Description was borrowed from kernel dwc3 Kconfig. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DOWNLOAD to KconfigSam Protsenko
While at it, remove obsolete CONFIG_USBDOWNLOAD_GADGET option from some config headers. This is also probably fixes am335x_baltos board. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DUALSPEED to KconfigSam Protsenko
Move CONFIG_USB_GADGET_DUALSPEED option to Kconfig and make all UDC controllers select USB_GADGET_DUALSPEED: - add next options to Kconfig selecting USB_GADGET_DUALSPEED: - USB_GADGET_ATMEL_USBA - USB_GADGET_DWC2_OTG - USB_DWC3 - CI_UDC - make USB_MUSB_GADGET select USB_GADGET_DUALSPEED While at it, make some related fixes: - remove DUALSPEED from configs that don't enable gadget support: - kwb.h - tseries.h - add missing USB_GADGET option to next configs: - novena_defconfig - pcm051_rev*_defconfig - xfi3_defconfig Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_VBUS_DRAW to KconfigSam Protsenko
The description was borrowed from kernel. Definitions were added to defconfig files in a way that "make savedefconfig" generates exactly the same file as used defconfig. Boards using 0 mA as CONFIG_USB_GADGET_VBUS_DRAW value were moved to use 2 mA (as minimal allowed by Kconfig). Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-03-25usb: gadget: Move CONFIG_USB_GADGET to KconfigSam Protsenko
The description was borrowed from kernel. "tristate" type was changed to "bool" (I believe we don't support modules for u-boot yet, right?). CONFIG_USB_GADGET requires CONFIG_USB to be defined too, so add it along as well. Definitions were added to defconfig files in a way that "make savedefconfig" generates exactly the same file as used defconfig. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Add zynq_zc702 conversion] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-02-24dfu: odroid xu3: Define DFU_MANIFEST_POLL_TIMEOUT to handle large files ↵Lukasz Majewski
transmission and storage As tested on the Odroid XU3, large files to be stored on the file system require considerable time to be physically written to the medium. The default 300 ms is not enough to store large file (e.g. 26 MiB). To fix this situation the DFU_MANIFEST_POLL_TIMEOUT has been defined. It is used to cease the communication with dfu-util and allow the target board to store the data on file system. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
2015-11-02exynos5-dt-types: add board detection for Odroid XU3/XU3L/XU4.Przemyslaw Marczak
This commit adds additional file with implementation of board detection code for Odroid-XU3/XU4. The detection depends on compatible found in fdt: - "samsung,exynos5" - uses Exynos5 generic code - "samsung,odroidxu3" - try detect XU3 revision There are few revisions of Odroid XU3/XU4, each can be detected by checking the value of channel 9 of built-in ADC: Rev ADC Board 0.1 0 XU3 0.1 0.2 372 XU3 0.2 | XU3L - no DISPLAYPORT 0.3 1280 XU4 0.1 The detection code depends on the ADC+10% value. Implementation of functions: - set_board_type() - read ADC and set type - get_board_rev() - returns board revision: 1..3 - get_board_type() - returns board type string Additional functions with return values of bool: - board_is_generic() - true if found compatible "samsung,exynos5" but not "samsung,odroidxu3" - board_is_odroidxu3() - true if found compatible "samsung,odroidxu3" and one of XU3 revision. - board_is_odroidxu4() - true if found compatible "samsung,odroidxu3" and XU4 revision. After I2C controller init, the get_board_type() can check if the XU3 board is a "Lite" variant, by probing chip 0x40 on I2C0 (INA231 - exists only on non-lite). This is useful for setting fdt file name at misc_init_r(). Enabled configs: - CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG - CONFIG_ODROID_REV_AIN - CONFIG_REVISION_TAG - CONFIG_BOARD_TYPES Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Simon Glass <sjg@chromium.org> Tested-by: Anand Moon <linux.amoon@gmail.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-08-05exynos: config: Move common options to the common headers and tidy upSimon Glass
Many options are duplicated on the exynos5 boards. Move these to the common files. Also some options are not used so can be removed. Tidy this up to make the files easier to maintain. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
2015-07-22usb: USB download gadget and functions config options coherent namingPaul Kocialkowski
This introduces a coherent scheme for naming USB download gadget and functions config options. The download USB gadget config option is moved to CONFIG_USB_GADGET_DOWNLOAD for better consistency with other gadgets and each function's config option is moved to a CONFIG_USB_FUNCTION_ prefix. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Tested-by: Lukasz Majewski <l.majewski@samsung.com> Test HW: Odroid_XU3 (Exynos5422), trats (Exynos4210)
2015-06-08odroid-xu3: config: enable DFU/THOR/UMS by add configs and environmentPrzemyslaw Marczak
This patch enables all functions required to use DFU/THOR and UMS: - DWC3: core, gadget, Samsung DWC3 PHY - USB gadget: endpoint autoconf, downloader, DFU, THOR, UMS The CONFIG_EXTRA_ENV_SETINGS from exynos5-common.h is redefined and appended by dfu environment setting and some system settings. The boot is still using $distro_boot as previous. Signed-off-by: Inha Song <ideal.song@samsung.com> Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com>
2015-03-04Odroid-XU3: enable the last dram bank and reserve 22MiBPrzemyslaw Marczak
This commit enables the last DRAM bank and reserves the last 22 MiB of it, for the secure firmware. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Akshay Saraswat <akshay.s@samsung.com> Cc: Hyungwon Hwang <human.hwang@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-12-22odroid-XU3: Add entry for DTS EHCI GPIOSjoerd Simons
Add samsung,vbus-gpio information for the XU3. This allows the usage of the EHCI controller on the XU3, which is connected to the SMSC LAN9514 chip (usb hub + network). Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-12-22Odroid-XU3: Add support for Odroid-XU3Hyungwon Hwang
This patch adds support for Odroid-XU3. Signed-off-by: Hyungwon Hwang <human.hwang@samsung.com> Reviewed-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Tested-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Kevin Hilman <khilman@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
