path: root/include/configs/pcm051.h
2019-08-25Convert CONFIG_SYS_SPI_U_BOOT_OFFS to KconfigHannes Schmelzer
This converts the following to Kconfig: CONFIG_SYS_SPI_U_BOOT_OFFS Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com> [trini: Expose this for SPL_SPI_SUNXI for now] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-07-09at91, omap2plus: configs: migrate CONFIG_ENV_ to defconfigsMarkus Klotzbuecher
Enable the extended ENV options for AT91 and OMAP2PLUS in order to be able to use CONFIG_ENV_UBI_* on these architectures. As this change also makes the configs ENV_SIZE, ENV_SECT_SIZE, ENV_OFFSET visible to AT91 and OMAP2PLUS, migrate users of these to KConfig. This migration was run using an extended moveconfig.py which evaluates expressions such as "(512 << 10)". See patch ("moveconfig: expand simple expressions"). All modified boards were built with SOURCE_DATE_EPOCH=0 before and after the change and successfully confirmed that the identical binary is generated (the only exception was igep00x0, which does not define CONFIG_ENV_IS_IN_UBI in the original board header. Once that is defined, the test passes too). hs: rebased patch to: 68b90e57bc: "configs: tinker-rk3288 disable CONFIG_SPL_I2C_SUPPORT" Signed-off-by: Markus Klotzbuecher <markus.klotzbuecher@kistler.com> Cc: Heiko Schocher <hs@denx.de> Cc: Eugen Hristev <eugen.hristev@microchip.com> Cc: Tom Rini <trini@konsulko.com>
2018-06-12configs: pcm051: Use am335x-wega-rdk.dtb as fdtfileMatwey V. Kornilov
In upstream Linux kernel, the fdtfile for this specific board is called am335x-wega-rdk.dtb Signed-off-by: Matwey V. Kornilov <matwey.kornilov@gmail.com>
2018-06-12configs: pcm051: Use DEFAULT_LINUX_BOOT_ENV instead of hardcoded valuesMatwey V. Kornilov
It appears that DEFAULT_LINUX_BOOT_ENV can be used to boot pcm051 board. Signed-off-by: Matwey V. Kornilov <matwey.kornilov@gmail.com>
2018-06-12configs: pcm051: Use DEFAULT_MMC_TI_ARGS instead of hardcoded duplicatesMatwey V. Kornilov
2018-06-12configs: pcm051: Support distro bootcmdsMatwey V. Kornilov
Add support for distro bootcmds. Signed-off-by: Matwey V. Kornilov <matwey.kornilov@gmail.com>
2018-04-11spl: spi: Move CONFIG_SPL_SPI_LOAD to KconfigMarek Vasut
Add Kconfig entry for CONFIG_SPL_SPI_LOAD symbol and move all configurations using it to Kconfig. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Tom Rini <trini@konsulko.com>
2018-04-08Migrate CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to KconfigAlex Kiernan
Convert CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to Kconfig Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Petr Vorel <petr.vorel@gmail.com> Reviewed-by: Petr Vorel <petr.vorel at gmail.com>
2018-03-16Convert all of CONFIG_CONS_INDEX to KconfigTom Rini
This converts the following to Kconfig: CONFIG_CONS_INDEX We have existing entries for this option in a number of places, with different guards on them. They're also sometimes used for things not directly inside of the serial driver. First, introduce a new symbol to guard the use of CONFIG_CONS_INDEX, so that in the case where we don't need this for the serial driver, but for some other use, we can still do it. Next, consolidate all of these into the single entry in drivers/serial/Kconfig. Finally, introduce CONS_INDEX_[023456] so that we can imply a correct value here to make the defconfig side of this smaller. Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Rework a lot of the logic here, such that I took authorship from Adam, but kept his S-o-B line] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-01-22Convert CONFIG_USB_MUSB_OMAP2PLUS et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_USB_MUSB_OMAP2PLUS CONFIG_USB_MUSB_AM35X CONFIG_USB_MUSB_DSPS CONFIG_USB_MUSB_PIO_ONLY Signed-off-by: Adam Ford <aford173@gmail.com>
2017-10-03usb: gadget: usb_ether: Move the interfaces to KconfigMaxime Ripard
We need to select an interface for the usb_ether gadget, and they haven't been converted to Kconfig yet. Add a choice to make sure we have an option selected, and convert all the users. Reviewed-by: Łukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-10-03usb: gadget: Convert USB_ETHER to KconfigMaxime Ripard
The USB Ethernet gadget option has not yet been moved to Kconfig, let's deal with that. Reviewed-by: Łukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-08-13spl: moveconfig: remove SPL_LDSCRIPT definitions for header-filesPhilipp Tomsich
With the hierarchical defaults set up, we remove these from the header files. To do so, I've run moveconfig on SPL_LDSCRIPT and this commits the changes. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_EEPROM et al to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_EEPROM CONFIG_CMD_EEPROM_LAYOUT CONFIG_EEPROM_LAYOUT_HELP_STRING Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Rework Kconfig logic slightly, define EEPROM location on TI eval platforms] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-11configs: am335x_evm: Use omap2 generic spl load scriptLokesh Vutla
No reason to use a separate load script for am33xx than using omap-common load script. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-28arm: Clean up MACH_TYPE_xxx usage after re-sync of mach-typesTom Rini
With the latest mach-types values we have many instances where we no longer need to define a value and a few cases where the name (but not value) have changed slightly. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-01-25Convert CONFIG_ARCH_MISC_INIT to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_ARCH_MISC_INIT Signed-off-by: Simon Glass <sjg@chromium.org>
2016-11-21arm: Introduce arch/arm/mach-omap2 for OMAP2 derivative platformsTom Rini
This moves what was in arch/arm/cpu/armv7/omap-common in to arch/arm/mach-omap2 and moves arch/arm/cpu/armv7/{am33xx,omap3,omap4,omap5} in to arch/arm/mach-omap2 as subdirectories. All refernces to the former locations are updated to the current locations. For the logic to decide what our outputs are, consolidate the tests into a single config.mk rather than including 4. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-09-16Convert CONFIG_SPL_YMODEM_SUPPORT to KconfigSimon Glass
Convert CONFIG_SPL_YMODEM_SUPPORT to Kconfig Move this option to Kconfig and tidy up existing uses. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-16Convert CONFIG_SPL_NET_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_NET_VCI_STRING to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SPL_NET_VCI_STRING Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-16Convert CONFIG_SPL_ETH_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_ENV_SUPPORT to KconfigSimon Glass
2016-04-25configs: Re-sync CONFIG_USB_MUSB_HOSTTom Rini
Now that CONFIG_USB_MUSB_HOST is part of Kconfig, migrate that over to the defconfig files. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DUALSPEED to KconfigSam Protsenko
Move CONFIG_USB_GADGET_DUALSPEED option to Kconfig and make all UDC controllers select USB_GADGET_DUALSPEED: - add next options to Kconfig selecting USB_GADGET_DUALSPEED: - USB_GADGET_ATMEL_USBA - USB_GADGET_DWC2_OTG - USB_DWC3 - CI_UDC - make USB_MUSB_GADGET select USB_GADGET_DUALSPEED While at it, make some related fixes: - remove DUALSPEED from configs that don't enable gadget support: - kwb.h - tseries.h - add missing USB_GADGET option to next configs: - novena_defconfig - pcm051_rev*_defconfig - xfi3_defconfig Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2015-11-21eeprom: Zap CONFIG_SYS_I2C_MULTI_EEPROMSMarek Vasut
This option only complicates the code unnecessarily, just use CONFIG_SYS_DEF_EEPROM_ADDR as the default address if there are only five arguments to eeprom {read/write} if this is defined. If CONFIG_SYS_DEF_EEPROM_ADDR is not defined, we mandate all six arguments. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@konsulko.com> Cc: Heiko Schocher <hs@denx.de> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-08-05usb: musb-new: CONFIG_MUSB prefix replacement with CONFIG_USB_MUSBPaul Kocialkowski
USB-related options are usually prefixed with CONFIG_USB and platform-specific adaptation for the MUSB controller already have a CONFIG_USB_MUSB prefix, so this switches all MUSB-related options to a CONFIG_USB_MUSB prefix, for consistency. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2015-06-02configs: remove CONFIG_NET_MULTILars Poeschel
CONFIG_NET_MULTI is not used anywhere and thus can safely be removed from the configs. Acked-by: Marek Vasut <marex@denx.de> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Lars Poeschel <poeschel@lemonage.de>
2015-06-02ARM: phytec: pcm051: Remove unneeded CONFIG_USE_IRQLars Poeschel
The config for pcm051 still undef'd CONFIG_USE_IRQ. This is not needed any more since it is not defined in the whole include path before. Signed-off-by: Lars Poeschel <poeschel@lemonage.de>
2015-01-13pcm051: Add boot script support to pcm051matwey.kornilov@gmail.com
This patch adds boot script support to pcm051 Signed-off-by: Matwey V. Kornilov <matwey.kornilov@gmail.com>
2014-09-24spl: replace CONFIG_SPL_SPI_* with CONFIG_SF_DEFAULT_*Nikita Kiryanov
Currently, CONFIG_SPL_SPI_* #defines are used for controlling SPI boot in SPL. These #defines do not allow the user to select SPI mode for the SPI flash (there's no CONFIG_SPL_SPI_MODE, so the SPI mode is hardcoded in spi_spl_load.c), and duplicate information already provided by CONFIG_SF_DEFAULT_* #defines. Kill CONFIG_SPL_SPI_*, and use CONFIG_SF_DEFAULT_* instead. Cc: Tom Rini <trini@ti.com> Cc: Marek Vasut <marex@denx.de> Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Cc: Lokesh Vutla <lokeshvutla@ti.com> Cc: Vitaly Andrianov <vitalya@ti.com> Cc: Lars Poeschel <poeschel@lemonage.de> Cc: Bo Shen <voice.shen@atmel.com> Cc: Hannes Petermaier <hannes.petermaier@br-automation.com> Cc: Michal Simek <monstr@monstr.eu> Acked-by: Marek Vasut <marex@denx.de> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Reviewed-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-08-25pcm051: use ti_am335x_common.h configMatwey V. Kornilov
Include general configs/ti_am335x_common.h and drop redundant #defines. Signed-off-by: Matwey V. Kornilov <matwey.kornilov@gmail.com>
2014-07-30include: remove CONFIG_SPL/CONFIG_TPL definition in config headersMasahiro Yamada
Now CONFIG_SPL and CONFIG_TPL are defined in Kconfig. Remove the redundant definition in config headers. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-07-30include: define CONFIG_SPL and CONFIG_TPL as 1Masahiro Yamada
We are about to switch to Kconfig in the next commit. But there are something to get done beforehand. In Kconfig, include/generated/autoconf.h defines boolean CONFIG macros as 1. CONFIG_SPL and CONFIG_TPL, if defined, must be set to 1. Otherwise, when switching to Kconfig, the build log would be sprinkled with warning messages like this: warning: "CONFIG_SPL" redefined [enabled by default] Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-03-04drivers: net: cpsw: add support to have phy address from cpsw platform dataMugunthan V N
Some platforms like AM437x have different EVMs with different phy addresses, so this patch adds support for passing phy address via cpsw plaform data. Also renamed phy_id to phy_addr so better understanding of the code. Reviewed-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> [trini: Update BuR am335x_igep0033 pcm051_rev3 pcm051_rev1 cm_t335 pengwyn boards] Signed-off-by: Tom Rini <trini@ti.com>
2013-11-13i2c, omap24xx: convert driver to new mutlibus/mutliadapter frameworkHeiko Schocher
- add omap24xx driver to new multibus/multiadpater support - adapted all config files, which uses this driver Tested on the am335x based siemens boards rut, dxr2 and pxm2 posted here: http://patchwork.ozlabs.org/patch/263211/ Signed-off-by: Heiko Schocher <hs@denx.de> Tested-by: Tom Rini <trini@ti.com> Cc: Lars Poeschel <poeschel@lemonage.de> Cc: Steve Sakoman <sakoman@gmail.com> Cc: Thomas Weber <weber@corscience.de> Cc: Tom Rix <Tom.Rix@windriver.com> Cc: Grazvydas Ignotas <notasas@gmail.com> Cc: Enric Balletbo i Serra <eballetbo@iseebcn.com> Cc: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Ilya Yanok <yanok@emcraft.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Nishanth Menon <nm@ti.com> Cc: Pali Rohár <pali.rohar@gmail.com> Cc: Peter Barada <peter.barada@logicpd.com> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Michael Jones <michael.jones@matrix-vision.de> Cc: Raphael Assenat <raph@8d.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Stefano Babic <sbabic@denx.de>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-09-20am335x:Handle worst case scenario for Errata 1.0.24Steve Kipisz
In Errata 1.0.24, if the board is running at OPP50 and has a warm reset, the boot ROM sets the frequencies for OPP100. This patch attempts to drop the frequencies back to OPP50 as soon as possible in the SPL. Then later the voltages and frequencies up set higher. Cc: Enric Balletbo i Serra <eballetbo@iseebcn.com> Cc: Lars Poeschel <poeschel@lemonage.de> Signed-off-by: Steve Kipisz <s-kipisz2@ti.com> [trini: Adapt to current framework] Signed-off-by: Tom Rini <trini@ti.com>
2013-08-19configs: Remove unused CONFIG_BOOTP_DEFAULTTom Rini
2013-08-15am33xx: Stop using PHYS_DRAM_1 defineTom Rini
We defined PHYS_DRAM_1 to 0x80000000 (start of DRAM) and then used this for CONFIG_SYS_SDRAM_BASE. But then we kept on referencing PHYS_DRAM_1 in other places. Change to directly setting CONFIG_SYS_DRAM_BASE and then using that name in code. Signed-off-by: Tom Rini <trini@ti.com>
