path: root/include/configs/platinum_picon.h
2015-05-26imx6: move generic imx6 options to mx6_common.hPeter Robinson
All boards define CONFIG_MX6, CONFIG_DISPLAY_BOARDINFO, CONFIG_DISPLAY_CPUINFO and CONFIG_SYS_GENERIC_BOARD so define them in mx6_common Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Tom Rini <trini at konsulko.com>
2015-01-19arm: mx6: Add Barco platinum-picon and platinum-titaniumStefan Roese
This patch adds the new Barco platinum platform. It currently includes those two boards: platinum-titanium ----------------- This is the same board as the titanium that is already supported in mainline U-Boot. But its now moved to this new platform to support multiple "flavors" of imx6 boards in one directory. Its also moved to support SPL booting. And with this we use the run-time DDR configuration of this SPL support. The board is equipped with the Micron MT41J128M16JT-125 DDR chips. We now can remove the DDR related registers tuples from the imximage.cfg file. As all this is done in the SPL at run-time. platinum-picon -------------- This board is new and based on the MX6DL with 1GiB DDR using the Micron MT41K256M16HA DDR3 chips. Its also equipped with 2 NAND chips (each 512MiB). Signed-off-by: Stefan Roese <sr@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Pieter Ronsijn <pieter.ronsijn@barco.com>
