path: root/include/configs/rk3036_common.h
2016-10-30rockchip: use rockchip linux partitions layoutJacob Chen
Unify the partitions of each chip then it will be more easy for us to write scripts, tools or guides for rockchip chips. Those extra partitions mostly are used to be compatible with our internal loaders (such as miniloader which was same as spl, or android loader then we can support dual boot) Signed-off-by: Jacob Chen <jacob2.chen@rock-chips.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2016-10-01rockchip: add boot-mode support for rk3288, rk3036Jacob Chen
rockchip platform have a protocol to pass the the kernel reboot mode to bootloader by some special registers when system reboot. In bootloader we should read it and take action. We can only setup boot_mode in board_late_init becasue "setenv" need env setuped. So add CONFIG_BOARD_LATE_INIT to common header and use a entry "rk_board_late_init" to replace "board_late_init" in board file. Signed-off-by: Jacob Chen <jacob2.chen@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-01rockchip: move partitons define from 3036-kylin to 3036-commonJacob Chen
To keep it same with 3288. Signed-off-by: Jacob Chen <jacob2.chen@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-01rockchip: add usb mass storage feature support for rk3036jacob2.chen
Enable ums feature for rk3036 boards, so that we can mount the mmc device to PC. Signed-off-by: jacob2.chen <jacob2.chen@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-08-26ARM: Move SYS_CACHELINE_SIZE over to KconfigTom Rini
This series moves the CONFIG_SYS_CACHELINE_SIZE. First, in nearly all cases we are mirroring the values used by the Linux Kernel here. Also, so long as (and in this case, it is true) we implement flushes in hunks that are no larger than the smallest implementation (and given that we mirror the Linux Kernel, again we are fine) it is OK to align higher. The biggest changes here are that we always use 64 bytes for CPU_V7 even if for example the underlying core is only 32 bytes (this mirrors Linux). Second, we say ARM64 uses 64 bytes not 128 (as found in the Linux Kernel) as we do not need multi-platform support (to this degree) and only the Cavium ThunderX 88xx series has a use for such large alignment. Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Stefan Roese <sr@denx.de> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Vaibhav Hiremath <hvaibhav@ti.com> Acked-by: Lokesh Vutla <lokeshvutla@ti.com> Cc: Steve Rae <steve.rae@raedomain.com> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Stefan Agner <stefan.agner@toradex.com> Acked-by: Heiko Schocher <hs@denx.de> Cc: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Cc: Peter Griffin <peter.griffin@linaro.org> Acked-by: Paul Kocialkowski <contact@paulk.fr> Cc: Anatolij Gustschin <agust@denx.de> Acked-by: "Pali Rohár" <pali.rohar@gmail.com> Cc: Adam Ford <aford173@gmail.com> Cc: Steve Sakoman <sakoman@gmail.com> Cc: Grazvydas Ignotas <notasas@gmail.com> Cc: Nishanth Menon <nm@ti.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Robert Baldyga <r.baldyga@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Thomas Weber <weber@corscience.de> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: David Feng <fenghua@phytium.com.cn> Cc: Alison Wang <b18965@freescale.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Simon Glass <sjg@chromium.org> Cc: York Sun <york.sun@nxp.com> Cc: Shengzhou Liu <Shengzhou.Liu@nxp.com> Cc: Mingkai Hu <mingkai.hu@nxp.com> Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Cc: Aneesh Bansal <aneesh.bansal@freescale.com> Cc: Saksham Jain <saksham.jain@nxp.com> Cc: Qianyu Gong <qianyu.gong@nxp.com> Cc: Wang Dongsheng <dongsheng.wang@nxp.com> Cc: Alex Porosanu <alexandru.porosanu@freescale.com> Cc: Hongbo Zhang <hongbo.zhang@nxp.com> Cc: tang yuantian <Yuantian.Tang@freescale.com> Cc: Rajesh Bhagat <rajesh.bhagat@nxp.com> Cc: Josh Wu <josh.wu@atmel.com> Cc: Bo Shen <voice.shen@atmel.com> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Hannes Schmelzer <oe5hpm@oevsv.at> Cc: Thomas Chou <thomas@wytron.com.tw> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Sam Protsenko <semen.protsenko@linaro.org> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Christophe Ricard <christophe-h.ricard@st.com> Cc: Anand Moon <linux.amoon@gmail.com> Cc: Beniamino Galvani <b.galvani@gmail.com> Cc: Carlo Caione <carlo@endlessm.com> Cc: huang lin <hl@rock-chips.com> Cc: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Cc: Xu Ziyuan <xzy.xu@rock-chips.com> Cc: "jk.kernel@gmail.com" <jk.kernel@gmail.com> Cc: "Ariel D'Alessandro" <ariel@vanguardiasur.com.ar> Cc: Kever Yang <kever.yang@rock-chips.com> Cc: Samuel Egli <samuel.egli@siemens.com> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Hans de Goede <hdegoede@redhat.com> Cc: Ian Campbell <ijc@hellion.org.uk> Cc: Siarhei Siamashka <siarhei.siamashka@gmail.com> Cc: Boris Brezillon <boris.brezillon@free-electrons.com> Cc: Andre Przywara <andre.przywara@arm.com> Cc: Bernhard Nortmann <bernhard.nortmann@web.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Ben Whitten <ben.whitten@gmail.com> Cc: Tom Warren <twarren@nvidia.com> Cc: Alexander Graf <agraf@suse.de> Cc: Sekhar Nori <nsekhar@ti.com> Cc: Vitaly Andrianov <vitalya@ti.com> Cc: "Andrew F. Davis" <afd@ti.com> Cc: Murali Karicheri <m-karicheri2@ti.com> Cc: Carlos Hernandez <ceh@ti.com> Cc: Ladislav Michl <ladis@linux-mips.org> Cc: Ash Charles <ashcharles@gmail.com> Cc: Mugunthan V N <mugunthanvnm@ti.com> Cc: Daniel Allred <d-allred@ti.com> Cc: Gong Qianyu <Qianyu.Gong@freescale.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Chin Liang See <clsee@altera.com> Tested-by: Stephen Warren <swarren@nvidia.com> Acked-by: Paul Kocialkowski <contact@paulk.fr>
2016-08-05rockchip: add fastboot support for rk3036 boardXu Ziyuan
Enable fastboot feature on rk3036, please refer to doc/README.rockchip for more detailed usage. Signed-off-by: Ziyuan Xu <xzy.xu@rock-chips.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-07-31rockchip: remove the duplicated macro configjk.kernel@gmail.com
CONFIG_DOS_PARTITION and CONFIG_EFI_PARTITION are already included in config_distro_defaults.h, and we don't need them in SPL stage. Signed-off-by: Ziyuan Xu <xzy.xu@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-07-31configs: rockchip: remove no use MACROKever Yang
The CONFIG_ROCKCHIP_COMMON and CONFIG_SPL_ROCKCHIP_COMMON are no use now, remove them. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-07-11rockchip: Disable CONFIG_SDHCISimon Glass
This option is not actually needed for rockchip boards. Drop it, since it will not support driver-model MMC operation support. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-01-31armv7: add cacheline sizes where missingAlbert ARIBAUD
Some armv7 targets are missing a cache line size declaration. In preparation for "arm: cache: Implement cache range check for v7" patch, add these declarations with the appropriate value for the target's SoC or CPU. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-01-12rockchip: Use the debug UART on rk3036Simon Glass
Rather than using a new debug UART implementation, use the standard one provided by U-Boot. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Thomas Chou <thomas@wytron.com.tw>
2015-12-01rockchip: move SYS_MALLOC_SIMPLE to mach-rockchip KconfigAriel D'Alessandro
Commit 1eb0c03c2198a7ec9de456b83dacdc4831b96cbf added SPL_SYS_MALLOC_SIMPLE Kconfig option and changed the way it is evaluated. Thus, the definitions of CONFIG_SYS_MALLOC_SIMPLE in rk3***_common.h board configs are now incorrect because CONFIG_SPL_BUILD is enabled so CONFIG_IS_ENABLED(SYS_MALLOC_SIMPLE) will look for SPL_SYS_MALLOC_SIMPLE instead of SYS_MALLOC_SIMPLE. This commit fix this enabling SPL_SYS_MALLOC_SIMPLE with the new Kconfig option by default in rockchip-mach. Signed-off-by: Ariel D'Alessandro <ariel@vanguardiasur.com.ar> Acked-by: Simon Glass <sjg@chromium.org>
2015-12-01rockchip: rk3036: Add core Soc start-up codehuang lin
rk3036 only 4K size SRAM for SPL, so only support timer, uart, sdram driver in SPL stage, when finish initial sdram, back to bootrom.And in rk3036 sdmmc and debug uart use same iomux, so if you want to boot from sdmmc, you must disable debug uart. Signed-off-by: Lin Huang <hl@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org> Fixed build error for chromebook_jerry, firefly-rk3288: Signed-off-by: Simon Glass <sjg@chromium.org> Series-changes: 8 - Fix build error for chromebook_jerry, firefly-rk3288
