path: root/include/configs/secomx6quq7.h
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-05-26mx6: standardise CONFIG_CMD_CACHEPeter Robinson
Move CONFIG_CMD_CACHE to mx6_common and standardise the way it's defined. Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Tom Rini <trini at konsulko.com>
2015-05-26imx6: generic MMC config options to mx6_commonPeter Robinson
Move all standard mx6 MMC configs to mx6_common. Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Tom Rini <trini at konsulko.com>
2015-05-26imx6: standardise filesystem and boot optionsPeter Robinson
Move all standard filesystem, partition and fdt options to mx6_common. Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-05-26imx6: move generic miscellaneous and overwrite optionsPeter Robinson
Move generic miscellaneous options that are standard across most, if not all, mx6 boards to central mx6_common define to ensure consistent features. Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-05-26imx6: centralise common boot options in mx6_common.hPeter Robinson
Define common LOADADDR and BOOTDELAY to ensure a consistent experience across mx6 boards Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-05-26imx6: move MXC_GPIO define to mx6_common.hPeter Robinson
Define CONFIG_MXC_GPIO and CONFIG_CMD_GPIO by default in mx6_common Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-05-26imx6: move standard ATAG configs to mx6_common.hPeter Robinson
Define the standard ATAG consfigs in mx6_common. Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Tom Rini <trini at konsulko.com>
2015-05-26imx6: move generic imx6 options to mx6_common.hPeter Robinson
All boards define CONFIG_MX6, CONFIG_DISPLAY_BOARDINFO, CONFIG_DISPLAY_CPUINFO and CONFIG_SYS_GENERIC_BOARD so define them in mx6_common Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Tom Rini <trini at konsulko.com>
2015-05-26imx6: move all standard includes to mx6_common.hPeter Robinson
The linux/sizes.h, asm/arch/imx-regs.h, asm/imx-common/gpio.h, config_cmd_default.h includes are used fairly universally across imx6 boards so include them in mx6_common.h by default. We define CONFIG_SYS_NO_FLASH before config_cmd_default.h so that we don't have to undef CONFIG_CMD_FLASH / CONFIG_CMD_IMLS everywhere. Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-03-23board/seco: Add mx6q-uq7 basic board supportBoris BREZILLON
Add basic SECO MX6Q/uQ7 board support (Ethernet, UART, SD are supported). It also adds a Kconfig skeleton to later add more SECO board (supporting SoC and board variants). Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
