path: root/include/configs/socfpga_vining_fpga.h
2016-09-27dfu: Migrate to KconfigTom Rini
Introduce a hidden USB_FUNCTION_DFU Kconfig option and select it for CMD_DFU (as we must have the DFU command enabled to do anything DFU). Make all of the entries in drivers/dfu/Kconfig depend on CMD_DFU and add options for all of the back end choices that DFU can make use of. Cc: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com>
2016-09-26kconfig: introduce kconfig for UBIHeiko Schocher
move the UBI config options into Kconfig. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andrew F. Davis <afd@ti.com> Reviewed by: Evgeni Dobrev <evgeni at studio-punkt.com>
2016-06-01arm: socfpga: Add samtec VIN|ING boardMarek Vasut
Add support for board based on the popular Altera Cyclone V SoC. This board has the following properties: - 1 GiB of DRAM - 1 Gigabit ethernet - 1 USB gadget port - 1 USB host port with an on-board hub - 2 QSPI NORs connected to the Cadence QSPI core - Multiple I2C EEPROMs and one I2C temperature sensor Signed-off-by: Marek Vasut <marex@denx.de> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Chin Liang See <clsee@altera.com> --- V2: Update the defconfig as per Tom's request
