path: root/include/configs/tao3530.h
2016-09-16Convert CONFIG_SPL_POWER_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_LIBDISK_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_FAT_SUPPORT to KconfigSimon Glass
2016-09-06TI: Rework SRAM definitions and maximumsTom Rini
On all TI platforms the ROM defines a "downloaded image" area at or near the start of SRAM which is followed by a reserved area. As it is at best bad form and at worst possibly harmful in corner cases to write in this reserved area, we stop doing that by adding in the define NON_SECURE_SRAM_IMG_END to say where the end of the downloaded image area is and make SRAM_SCRATCH_SPACE_ADDR be one kilobyte before this. At current we define the end of scratch space at 0x228 bytes past the start of scratch space this this gives us a lot of room to grow. As these scratch uses are non-optional today, all targets are modified to respect this boundary. Tested on OMAP4 Pandaboard, OMAP3 Beagle xM Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Vaibhav Hiremath <hvaibhav@ti.com> Cc: Lokesh Vutla <lokeshvutla@ti.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Paul Kocialkowski <contact@paulk.fr> Cc: Enric Balletbo i Serra <eballetbo@gmail.com> Cc: Adam Ford <aford173@gmail.com> Cc: Steve Sakoman <sakoman@gmail.com> Cc: Stefan Roese <sr@denx.de> Cc: Thomas Weber <weber@corscience.de> Cc: Hannes Schmelzer <oe5hpm@oevsv.at> Cc: Thomas Chou <thomas@wytron.com.tw> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Simon Glass <sjg@chromium.org> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Sam Protsenko <semen.protsenko@linaro.org> Cc: Heiko Schocher <hs@denx.de> Cc: Samuel Egli <samuel.egli@siemens.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Cc: Ben Whitten <ben.whitten@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Sekhar Nori <nsekhar@ti.com> Cc: Mugunthan V N <mugunthanvnm@ti.com> Cc: "B, Ravi" <ravibabu@ti.com> Cc: "Matwey V. Kornilov" <matwey.kornilov@gmail.com> Cc: Ladislav Michl <ladis@linux-mips.org> Cc: Ash Charles <ashcharles@gmail.com> Cc: "Kipisz, Steven" <s-kipisz2@ti.com> Cc: Daniel Allred <d-allred@ti.com> Signed-off-by: Tom Rini <trini@konsulko.com> Tested-by: Lokesh Vutla <lokeshvutla@ti.com> Acked-by: Lokesh Vutla <lokeshvutla@ti.com> Tested-by: Ladislav Michl <ladis@linux-mips.org>
2016-08-26ARM: Move SYS_CACHELINE_SIZE over to KconfigTom Rini
This series moves the CONFIG_SYS_CACHELINE_SIZE. First, in nearly all cases we are mirroring the values used by the Linux Kernel here. Also, so long as (and in this case, it is true) we implement flushes in hunks that are no larger than the smallest implementation (and given that we mirror the Linux Kernel, again we are fine) it is OK to align higher. The biggest changes here are that we always use 64 bytes for CPU_V7 even if for example the underlying core is only 32 bytes (this mirrors Linux). Second, we say ARM64 uses 64 bytes not 128 (as found in the Linux Kernel) as we do not need multi-platform support (to this degree) and only the Cavium ThunderX 88xx series has a use for such large alignment. Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Stefan Roese <sr@denx.de> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Vaibhav Hiremath <hvaibhav@ti.com> Acked-by: Lokesh Vutla <lokeshvutla@ti.com> Cc: Steve Rae <steve.rae@raedomain.com> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Stefan Agner <stefan.agner@toradex.com> Acked-by: Heiko Schocher <hs@denx.de> Cc: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Cc: Peter Griffin <peter.griffin@linaro.org> Acked-by: Paul Kocialkowski <contact@paulk.fr> Cc: Anatolij Gustschin <agust@denx.de> Acked-by: "Pali Rohár" <pali.rohar@gmail.com> Cc: Adam Ford <aford173@gmail.com> Cc: Steve Sakoman <sakoman@gmail.com> Cc: Grazvydas Ignotas <notasas@gmail.com> Cc: Nishanth Menon <nm@ti.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Robert Baldyga <r.baldyga@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Thomas Weber <weber@corscience.de> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: David Feng <fenghua@phytium.com.cn> Cc: Alison Wang <b18965@freescale.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Simon Glass <sjg@chromium.org> Cc: York Sun <york.sun@nxp.com> Cc: Shengzhou Liu <Shengzhou.Liu@nxp.com> Cc: Mingkai Hu <mingkai.hu@nxp.com> Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Cc: Aneesh Bansal <aneesh.bansal@freescale.com> Cc: Saksham Jain <saksham.jain@nxp.com> Cc: Qianyu Gong <qianyu.gong@nxp.com> Cc: Wang Dongsheng <dongsheng.wang@nxp.com> Cc: Alex Porosanu <alexandru.porosanu@freescale.com> Cc: Hongbo Zhang <hongbo.zhang@nxp.com> Cc: tang yuantian <Yuantian.Tang@freescale.com> Cc: Rajesh Bhagat <rajesh.bhagat@nxp.com> Cc: Josh Wu <josh.wu@atmel.com> Cc: Bo Shen <voice.shen@atmel.com> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Hannes Schmelzer <oe5hpm@oevsv.at> Cc: Thomas Chou <thomas@wytron.com.tw> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Sam Protsenko <semen.protsenko@linaro.org> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Christophe Ricard <christophe-h.ricard@st.com> Cc: Anand Moon <linux.amoon@gmail.com> Cc: Beniamino Galvani <b.galvani@gmail.com> Cc: Carlo Caione <carlo@endlessm.com> Cc: huang lin <hl@rock-chips.com> Cc: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Cc: Xu Ziyuan <xzy.xu@rock-chips.com> Cc: "jk.kernel@gmail.com" <jk.kernel@gmail.com> Cc: "Ariel D'Alessandro" <ariel@vanguardiasur.com.ar> Cc: Kever Yang <kever.yang@rock-chips.com> Cc: Samuel Egli <samuel.egli@siemens.com> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Hans de Goede <hdegoede@redhat.com> Cc: Ian Campbell <ijc@hellion.org.uk> Cc: Siarhei Siamashka <siarhei.siamashka@gmail.com> Cc: Boris Brezillon <boris.brezillon@free-electrons.com> Cc: Andre Przywara <andre.przywara@arm.com> Cc: Bernhard Nortmann <bernhard.nortmann@web.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Ben Whitten <ben.whitten@gmail.com> Cc: Tom Warren <twarren@nvidia.com> Cc: Alexander Graf <agraf@suse.de> Cc: Sekhar Nori <nsekhar@ti.com> Cc: Vitaly Andrianov <vitalya@ti.com> Cc: "Andrew F. Davis" <afd@ti.com> Cc: Murali Karicheri <m-karicheri2@ti.com> Cc: Carlos Hernandez <ceh@ti.com> Cc: Ladislav Michl <ladis@linux-mips.org> Cc: Ash Charles <ashcharles@gmail.com> Cc: Mugunthan V N <mugunthanvnm@ti.com> Cc: Daniel Allred <d-allred@ti.com> Cc: Gong Qianyu <Qianyu.Gong@freescale.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Chin Liang See <clsee@altera.com> Tested-by: Stephen Warren <swarren@nvidia.com> Acked-by: Paul Kocialkowski <contact@paulk.fr>
2016-01-31armv7: add cacheline sizes where missingAlbert ARIBAUD
Some armv7 targets are missing a cache line size declaration. In preparation for "arm: cache: Implement cache range check for v7" patch, add these declarations with the appropriate value for the target's SoC or CPU. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-09-28configs: remove remnants of CONFIG_SYS_NAND_QUIET_TESTIgor Grinberg
The config option has been removed by one of the syncs with the Linux mainline MTD subsystem: ff94bc40af (mtd, ubi, ubifs: resync with Linux-3.14) It has been left inside the config files. Currently does not look to serve any purpose, so remove it now from all the configs. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Cc: Stefan Roese <sr@denx.de> Cc: "Albert ARIBAUD (3ADEV)" <albert.aribaud@3adev.fr> Cc: Peter Barada <peter.barada@logicpd.com> Cc: Steve Sakoman <sakoman@gmail.com> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Simon Glass <sjg@chromium.org> Acked-by: Stefan Roese <sr@denx.de>
2015-08-12ti: drop value from CONFIG_SYS_NAND_BUSWIDTH_16BITStefano Babic
Signed-off-by: Stefano Babic <sbabic@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-03-13ARM: OMAP3: Enable workaround for ARM errata 454179, 430973, 621766Nishanth Menon
Enable the OMAP3 specific errata code for 454179, 430973, 621766 and while at it, remove legacy non-revision checked errata logic. Signed-off-by: Nishanth Menon <nm@ti.com> Tested-by: Matt Porter <mporter@konsulko.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-03-13ARM: OMAP3: Rename omap3.h to omap.h to be generic as all SoCsNishanth Menon
This is in preperation of using generic cross OMAP code. Signed-off-by: Nishanth Menon <nm@ti.com> Tested-by: Matt Porter <mporter@konsulko.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-03-04ti: armv7: Move SPL SDRAM init to the right place, drop unused CONFIG_SPL_STACKSimon Glass
Currently in some cases SDRAM init requires global_data to be available and soon this will not be available prior to board_init_f(). Adjust the code paths in these cases to be correct. In some cases we had the SPL stack be in DDR as we might have large stacks (due to Falcon Mode + Environment). In these cases switch to CONFIG_SPL_STACK_R. In other cases we had simply been setting CONFIG_SPL_STACK into SRAM. In these cases we no longer need to (CONFIG_SYS_INIT_SP_ADDR is used and is also in SRAM) so drop those lines. Signed-off-by: Simon Glass <sjg@chromium.org> Tested on Beagleboard, Beagleboard xM Tested-by: Matt Porter <mporter@konsulko.com> Tested on Beaglebone Black, AM43xx GP EVM, OMAP5 uEVM, OMAP4 Pandaboard Tested-by: Tom Rini <trini@konsulko.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-12-04MMC SD fs boot partition config coding style and proper descriptionPaul Kocialkowski
CONFIG_SYS_MMC_SD_FS_BOOT_PARTITION ought to be called CONFIG_SYS_MMCSD_FS_BOOT_PARTITION to keep it consistent with other config options such as: CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR. In addition, it is not related to raw mode booting but to fs mode instead. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@ti.com>
2014-11-20ARM: remove CONFIG_ARMV7 definesMasahiro Yamada
Some (not all) of ARMv7 boards define CONFIG_ARMV7, which is useless. Besides, it is never referenced. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-10-27Rename some defines containing FAT in their name to be filesystem genericGuillaume GARDET
Rename some defines containing FAT in their name to be filesystem generic: MMCSD_MODE_FAT => MMCSD_MODE_FS CONFIG_SPL_FAT_LOAD_ARGS_NAME => CONFIG_SPL_FS_LOAD_ARGS_NAME CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME => CONFIG_SPL_FS_LOAD_PAYLOAD_NAME CONFIG_SYS_MMC_SD_FAT_BOOT_PARTITION => CONFIG_SYS_MMC_SD_FS_BOOT_PARTITION Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr> Cc: Tom Rini <trini@ti.com>
2014-08-30omap3: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the OMAP3 board select menu to omap3/Kconfig. Move also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="omap3 Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-07-30include: remove CONFIG_SPL/CONFIG_TPL definition in config headersMasahiro Yamada
Now CONFIG_SPL and CONFIG_TPL are defined in Kconfig. Remove the redundant definition in config headers. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-07-30include: define CONFIG_SPL and CONFIG_TPL as 1Masahiro Yamada
We are about to switch to Kconfig in the next commit. But there are something to get done beforehand. In Kconfig, include/generated/autoconf.h defines boolean CONFIG macros as 1. CONFIG_SPL and CONFIG_TPL, if defined, must be set to 1. Otherwise, when switching to Kconfig, the build log would be sprinkled with warning messages like this: warning: "CONFIG_SPL" redefined [enabled by default] Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-07-25ARM: omap: clean redundant PISMO_xx macros used in OMAP3pekon gupta
PISMO_xx macros were used to define 'Platform Independent Storage MOdule' related GPMC configurations. This patch - Replaces these OMAP3 specific macros with generic CONFIG_xx macros as provided by current u-boot infrastructure. - Removes unused redundant macros, which are no longer required after merging of common platform code in following commit commit a0a37183bd75e74608bc78c8d0e2a34454f95a91 ARM: omap: merge GPMC initialization code for all platform +-----------------+-----------------------------------------------------------+ | Macro | Reason for removal | +-----------------+-----------------------------------------------------------+ | PISMO1_NOR_BASE | duplicate of CONFIG_SYS_FLASH_BASE | +-----------------+-----------------------------------------------------------+ | PISMO1_NAND_BASE| duplicate of CONFIG_SYS_NAND_BASE | +-----------------+-----------------------------------------------------------+ | PISMO1_ONEN_BASE| duplicate of CONFIG_SYS_ONENAND_BASE | +-----------------+-----------------------------------------------------------+ | PISMO1_NAND_SIZE| GPMC accesses NAND device via I/O mapped registers so | | | configuring GPMC chip-select for smallest allowable | | | segment (GPMC_SIZE_16M) is enough. | +-----------------+-----------------------------------------------------------+ | PISMO1_ONEN_SIZE| OneNAND uses a fixed GPMC chip-select address-space of | | | 128MB (GPMC_SIZE_128M) | +-----------------+-----------------------------------------------------------+ +-----------------+-----------------------------------------------------------+ | PISMO1_NOR | Unused Macros | | PISMO1_NAND | | | PISMO2_CS0 | | | PISMO2_CS1 | | | PISMO1_ONENAND | | | PISMO2_NAND_CS0 | | | PISMO2_NAND_CS1 | | | PISMO1_NOR_BASE | | | PISMO1_NAND_BASE| | | PISMO2_CS0_BASE | | +-----------------+-----------------------------------------------------------+ Signed-off-by: Pekon Gupta <pekon@ti.com>
2014-07-25ARM: omap: tao3530: Convert to generic boardStefan Roese
Use generic board setup functions by defining CONFIG_SYS_GENERIC_BOARD. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Tom Rini <trini@ti.com>
2014-06-06omap3: remove remnant macros GPMC_NAND_ECC_LP_x8_LAYOUT and ↵pekon gupta
GPMC_NAND_ECC_LP_x16_LAYOUT OMAP3 used GPMC_NAND_ECC_LP_x8_LAYOUT and GPMC_NAND_ECC_LP_x16_LAYOUT macros to configure GPMC controller for x7 or x8 bit device connected to its interface. Now this information is encoded in CONFIG_SYS_NAND_DEVICE_WIDTH macro, so above macros can be completely removed. Signed-off-by: Pekon Gupta <pekon@ti.com>
2014-06-06mtd: nand: omap: add CONFIG_SYS_NAND_BUSWIDTH_16BIT to indicate NAND device ↵pekon gupta
bus-width GPMC controller needs to be configured based on bus-width of the NAND device connected to it. Also, dynamic detection of NAND bus-width from on-chip ONFI parameters is not possible in following situations: SPL: SPL NAND drivers does not support ONFI parameter reading. U-boot: GPMC controller iniitalization is done in omap_gpmc.c:board_nand_init() which is called before probing for devices, hence any ONFI parameter information is not available during GPMC initialization. Thus, OMAP NAND driver expected board developers to explicitely write GPMC configurations specific to NAND device attached on board in board files itself. But this was troublesome for board manufacturers as they need to dive into lengthy platform & SoC documents to find details of GPMC registers and appropriate configurations to get NAND device working. This patch instead adds existing CONFIG_SYS_NAND_BUSWIDTH_16BIT to board config hich indicates that connected NAND device has x16 bus-width. And then based on this config GPMC driver itself initializes itself based on NAND bus-width. This keeps board developers free from knowing GPMC controller specific internals. Signed-off-by: Pekon Gupta <pekon@ti.com>
2014-02-21arm: omap3: Fix tao3530/omap3_ha SPL boot hangup (GPIO clocks not enabled)Stefan Roese
Patch f33b9bd3 [arm: omap3: Enable clocks for peripherals only if they are used] breaks SPL booting on tao3530. Since some gpio input's are read to detect the board revision. But with this patch above, the clocks to the GPIO subsystems are not enabled per default any more. The GPIO banks need to be configured specifically now. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Tom Rini <trini@ti.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Reviewed-by: Stefano Babic <sbabic@denx.de>
2013-12-12arm: omap3: Remove bootargs mem_size handlingStefan Roese
The memory size is autodetected and is passed to the Linux kernel either via ATAGs or device-tree (dtb). So there is no need to pass it via the bootargs. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Tapani Utriainen <tapani@technexion.com> Cc: Thorsten Eisbein <thorsten.eisbein@head-acoustics.de> Cc: Tom Rini <trini@ti.com>
2013-12-12arm: omap3: Add SPL support to tao3530Stefan Roese
Add SPL support for the Technexion TAO3530 SOM to replace x-loader. Tested with the Thunder baseboard. Currently this is only tested with the TAO3530 SOM revision (Ax/Bx). Tested by booting via MMC and NAND. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Tapani Utriainen <tapani@technexion.com> Cc: Thorsten Eisbein <thorsten.eisbein@head-acoustics.de> Cc: Tom Rini <trini@ti.com>
2013-12-12arm, omap3: Add support for TechNexion modulesTapani Utriainen
Add support for TechNexion TAO3530 SoM This patch has been posted quite a long time ago. I ported it to the latest mainline U-Boot version. With some additional cleanup and enhancements. Signed-off-by: Tapani Utriainen <tapani@technexion.com> CC: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Stefan Roese <sr@denx.de> Cc: Thorsten Eisbein <thorsten.eisbein@head-acoustics.de> Cc: Tom Rini <trini@ti.com>
