path: root/include/configs/tegra-common-usb-gadget.h
2018-02-02Kconfig: gadget: Move CONFIG_USB_FUNCTION_MASS_STORAGE to KconfigLukasz Majewski
This commit moves USB_FUNCTION_MASS_STORAGE config to Kconfig. Signed-off-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2016-10-10tegra: usb gadget: fix ci udc operation if not hostpc capableMarcel Ziswiler
The Tegra 2 aka T20 is not host PC capable. Therefore gate the define CONFIG_CI_UDC_HAS_HOSTPC in tegra-common-usb-gadget.h in case of CONFIG_TEGRA20. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-09-27dfu: Migrate to KconfigTom Rini
Introduce a hidden USB_FUNCTION_DFU Kconfig option and select it for CMD_DFU (as we must have the DFU command enabled to do anything DFU). Make all of the entries in drivers/dfu/Kconfig depend on CMD_DFU and add options for all of the back end choices that DFU can make use of. Cc: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com>
2016-04-20usb: gadget Move: CONFIG_G_DNL_* to KconfigSam Protsenko
And also reformat defconfigs using "make savedefconfig" rule. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DOWNLOAD to KconfigSam Protsenko
While at it, remove obsolete CONFIG_USBDOWNLOAD_GADGET option from some config headers. This is also probably fixes am335x_baltos board. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DUALSPEED to KconfigSam Protsenko
Move CONFIG_USB_GADGET_DUALSPEED option to Kconfig and make all UDC controllers select USB_GADGET_DUALSPEED: - add next options to Kconfig selecting USB_GADGET_DUALSPEED: - USB_GADGET_ATMEL_USBA - USB_GADGET_DWC2_OTG - USB_DWC3 - CI_UDC - make USB_MUSB_GADGET select USB_GADGET_DUALSPEED While at it, make some related fixes: - remove DUALSPEED from configs that don't enable gadget support: - kwb.h - tseries.h - add missing USB_GADGET option to next configs: - novena_defconfig - pcm051_rev*_defconfig - xfi3_defconfig Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_VBUS_DRAW to KconfigSam Protsenko
The description was borrowed from kernel. Definitions were added to defconfig files in a way that "make savedefconfig" generates exactly the same file as used defconfig. Boards using 0 mA as CONFIG_USB_GADGET_VBUS_DRAW value were moved to use 2 mA (as minimal allowed by Kconfig). Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-03-25usb: gadget: Move CONFIG_USB_GADGET to KconfigSam Protsenko
The description was borrowed from kernel. "tristate" type was changed to "bool" (I believe we don't support modules for u-boot yet, right?). CONFIG_USB_GADGET requires CONFIG_USB to be defined too, so add it along as well. Definitions were added to defconfig files in a way that "make savedefconfig" generates exactly the same file as used defconfig. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Add zynq_zc702 conversion] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-09-11ARM: tegra: enable DFU for RAMStephen Warren
This allows transferring data directly to/from RAM. For example, one could create a boot script that starts DFU on a RAM region, then once DFU exits (which is under the control of the attached USB host, via a USB bus reset), uses the code/data that was received over DFU. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2015-09-11ARM: tegra: tweak DFU buffer sizesStephen Warren
CONFIG_SYS_DFU_DATA_BUF_SIZE defines the size of chunks transferred across USB. This doesn't need to be particularly large, since it doesn't limit the overall transfer size. CONFIG_SYS_DFU_MAX_FILE_SIZE is used to buffer an entire file before writing it to a filesystem. This define limits the maximum file size that may be transferred. Bump this up to 32MiB in order to support large uncompressed kernel images. Both of these buffers are dynamically allocated, and so the size of both needs to be taken into account when calculating the required malloc region size. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2015-08-13ARM: tegra: allow custom usb manufacturer/product/vendor ids/stringsMarcel Ziswiler
Allow for optional custom USB gadget manufacturer/product/vendor IDs/strings to be specified. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-07-22usb: USB download gadget and functions config options coherent namingPaul Kocialkowski
This introduces a coherent scheme for naming USB download gadget and functions config options. The download USB gadget config option is moved to CONFIG_USB_GADGET_DOWNLOAD for better consistency with other gadgets and each function's config option is moved to a CONFIG_USB_FUNCTION_ prefix. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Tested-by: Lukasz Majewski <l.majewski@samsung.com> Test HW: Odroid_XU3 (Exynos5422), trats (Exynos4210)
2014-08-18ARM: tegra: enable DFU tooStephen Warren
Enable DFU protocol support (via the "dfu" command) on Tegra boards where USB device/gadget mode is enabled. Note that for DFU to operate correctly on Tegra, we still need some DFU fixes/enhancements that are going through the DFU -> USB trees. However, the code builds just fine without those changes, and applying this patch now will allow both sets of patches to meet in the main U-Boot tree much more quickly. In order to run test/dfu/dfu_gadget_test.sh, you would need to add the following to the board configuration: CONFIG_EXT4_WRITE CONFIG_CMD_EXT4_WRITE However, I haven't enabled those here, since I believe the main use-case for DFU on Tegra is raw flash writing, rather than filesystem access, so we don't need the additional code-size hit. However, I could be persuaded otherwise! We should probably add a separate test script for raw flash access. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
