path: root/include/configs/x600.h
2016-09-26kconfig: introduce kconfig for UBIHeiko Schocher
move the UBI config options into Kconfig. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andrew F. Davis <afd@ti.com> Reviewed by: Evgeni Dobrev <evgeni at studio-punkt.com>
2016-09-16Convert CONFIG_SPL_NOR_SUPPORT to KconfigSimon Glass
2016-07-01autoboot: remove CONFIG_ZERO_BOOTDELAY_CHECKMasahiro Yamada
As the help message of CONFIG_BOOTDELAY says, CONFIG_BOOTDELAY=-2 means the autoboot with no delay, with no abort check even if CONFIG_ZERO_BOOTDELAY_CHECK is defined. To sum up, the autoboot behaves as follows: [1] CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=y autoboot with no delay, but you can abort it by key input [2] CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=n autoboot with no delay, with no check for abort [3] CONFIG_BOOTDELAY=-1 disable autoboot [4] CONFIG_BOOTDELAY=-2 autoboot with no delay, with no check for abort As you notice, [2] and [4] come to the same result, which means we do not need CONFIG_ZERO_BOOTDELAY_CHECK. We can control all the cases only by CONFIG_BOOTDELAY, like this: [1] CONFIG_BOOTDELAY=0 autoboot with no delay, but you can abort it by key input [2] CONFIG_BOOTDELAY=-1 disable autoboot [3] CONFIG_BOOTDELAY=-2 autoboot with no delay, with no check for abort This commit converts the logic as follow: CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=n --> CONFIG_BOOTDELAY=-2 Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Stefan Roese <sr@denx.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Christian Riesch <christian.riesch@omicronenergy.com> Acked-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
2016-05-31arm: spear: x600: Add support for Micrel KSZ9031 PHYStefan Roese
As the old ethernet PHY is not available any more, the x600 board has been redesigned with the Micrel KSZ9031 PHY. This patch adds support to autodetect the PHY and configure the Micrel PHY correctly. Signed-off-by: Stefan Roese <sr@denx.de>
2016-05-17i2c: config: Move SYS_I2C_DW to KconfigStefan Roese
This patch moves all appearances of CONFIG_SYS_I2C_DW from the config header to the defconfig files. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Alexey Brodkin <abrodkin@synopsys.com>
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-12-22net: eth_designware: select PHYLIB in KconfigThomas Chou
Select PHYLIB in drivers/net/Kconfig. And remove CONFIG_PHYLIB from legacy board header files. This fixed the warnings when both ALTERA_TSE and ETH_DESIGNWARE are selected. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reported-by: Pavel Machek <pavel@denx.de> Acked-by: Chin Liang See <clsee@altera.com> Acked-by: Pavel Machek <pavel@denx.de> Tested-by: Pavel Machek <pavel@denx.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-09-11arm: spear: Enable THUMB mode on x600 boardStefan Roese
To reduce the size of the U-Boot image on the x600 board, lets enable the THUMB mode. This reduces the overall size to less than 0x6000 bytes. Fitting it again in the onboard NOR flash. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Viresh Kumar <viresh.kumar@linaro.org>
2015-09-11arm: spear: Add BCH4 SW support to SPEAr600 x600 boardStefan Roese
This board is equipped with a Micron NAND chip (MT29F1G08ABADAH4) that needs 4-bit ECC. But the SPEAr600 only supports 1-bit HW ECC internally. This patch enables the SW 4-bit BCH support for this board. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Viresh Kumar <viresh.kumar@linaro.org>
2015-08-28arm: spear: Some changes / updates to the x600 config headerStefan Roese
This patch brings the following changes to the x600 board support: - Add USB EHCI support - Add VFAT support for USB key file access - Increase malloc size (for UBI / UBIFS usage) - Enable Thumb mode to save some image space - Remove unreferenced CONFIG_STACKSIZE - Remove unreferenced CONFIG_SPL_NO_PRINTF Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Cc: Vipin Kumar <vk.vipin@gmail.com>
2015-08-28arm: spear: Move to common SPL infrastructureStefan Roese
The SPL implementation for SPEAr600 is older than the common SPL infrastructure. This patch now moves the SPEAr600 SPL over to the common SPL code. Tested on the only SPEAr board that currently uses SPL in mainline U-Boot, the x600. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Cc: Vipin Kumar <vk.vipin@gmail.com>
2015-06-08autoboot.c: Move config options to KconfigStefan Roese
This patch moves the following config options to Kconfig: CONFIG_AUTOBOOT_KEYED CONFIG_AUTOBOOT_PROMPT CONFIG_AUTOBOOT_DELAY_STR CONFIG_AUTOBOOT_STOP_STR AUTOBOOT_KEYED_CTRLC Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Drop ip04 and pm9263 configs/ additions, those boards previously set CONFIG_AUTOBOOT_PROMPT but never used it, re-run savedefconfig over all boards that did change. Make digsy_mtc_* string include seconds to match others and not warn. ] Signed-off-by: Tom Rini <trini@konsulko.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-06-02configs: remove CONFIG_NET_MULTILars Poeschel
CONFIG_NET_MULTI is not used anywhere and thus can safely be removed from the configs. Acked-by: Marek Vasut <marex@denx.de> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Lars Poeschel <poeschel@lemonage.de>
2015-04-18Kconfig: Move CONFIG_DESIGNWARE_ETH to KconfigSimon Glass
Move this to Kconfig and clean up board config files that use it. Also rename it to CONFIG_ETH_DESIGNWARE to fit with the naming that exists in drivers/net/Kconfig. Signed-off-by: Simon Glass <sjg@chromium.org> Version 1: Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-03-05arm: spear: Move to generic board supportStefan Roese
Without this change the board support for these SPEAr boards would be dropped soon. Generic board support seems to work just fine. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Vipin Kumar <vk.vipin@gmail.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
2014-10-29i2c: designware: Convert driver to multibus/multiadapter frameworkStefan Roese
In preparation for the SoCFPGA support of the designware I2C driver, convert this driver to the common CONFIG_SYS_I2C framework. This patch converts all users of this driver, this is: - ST spearxxx boards - AXS101 (ARC700 platform) I couldn't test this patch on those boards. Only compile tested for all spear boards. And tested on SoCFPGA. Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Marek Vasut <marex@denx.de> Acked-by: Alexey Brodkin <abrodkin@synopsys.com> Tested-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Heiko Schocher <hs@denx.de> Cc: Vipin Kumar <vk.vipin@gmail.com> Cc: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-10-27Use __stringify() instead of xstr()Anatolij Gustschin
Some boards still use xstr(). Replace remaining occurrences of xstr() by commonly used __stringify(). Signed-off-by: Anatolij Gustschin <agust@denx.de>
2014-07-30include: remove CONFIG_SPL/CONFIG_TPL definition in config headersMasahiro Yamada
Now CONFIG_SPL and CONFIG_TPL are defined in Kconfig. Remove the redundant definition in config headers. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-07-30include: define CONFIG_SPL and CONFIG_TPL as 1Masahiro Yamada
We are about to switch to Kconfig in the next commit. But there are something to get done beforehand. In Kconfig, include/generated/autoconf.h defines boolean CONFIG macros as 1. CONFIG_SPL and CONFIG_TPL, if defined, must be set to 1. Otherwise, when switching to Kconfig, the build log would be sprinkled with warning messages like this: warning: "CONFIG_SPL" redefined [enabled by default] Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-05-20fpga: Guard the LOADMK functionality with CMD_FPGA_LOADMKSiva Durga Prasad Paladugu
Guard the LOADMK functionality with config to provide an option to enable or disable it. Enable it for all platforms in mainline which enable CONFIG_CMD_FPGA. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-02-20spear: move CONFIG_SYS_I2C_BASE from arch-spear/hardware to board configsAlexey Brodkin
Having CONFIG_SYS_I2C_BASE requires DW I2C driver to explicitly include <arch/hardware.h> which other platforms may not have at all. It's always good to have a driver platform-independent. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Tom Rini <trini@ti.com> Cc: Heiko Schocher <hs@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Vipin Kumar <vipin.kumar@st.com> Cc: Armando Visconti <armando.visconti@st.com>
2014-02-19configs: Delete unused CONFIG_SYS_64BIT_{VSPRINTF, STRTOUL}Masahiro Yamada
2014-02-07x600: Switch to CONFIG_PHYLIBTom Rini
Now that the designware ethernet driver uses phylib we need to turn it on here. Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-03-04ubifs: Allow ubifsmount volume reference by numberJoe Hershberger
UBI can mount volumes by name or number The current code forces you to name the volume by prepending every name with "ubi:". >From fs/ubifs/super.c * There are several ways to specify UBI volumes when mounting UBIFS: * o ubiX_Y - UBI device number X, volume Y; * o ubiY - UBI device number 0, volume Y; * o ubiX:NAME - mount UBI device X, volume with name NAME; * o ubi:NAME - mount UBI device 0, volume with name NAME. Now any name passed in any of the above forms are allowed. Also update the configs that referenced ubifsmount. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-10-04ARM: Add X600 board support (SPEAr600 based)Stefan Roese
This patch adds support for the X600 SPEAr600 based board. Its also the first SPEAr600 board that uses the newly introduced SPEAr600 SPL support. Xloader is not necessary any more. By using the new "u-boot.spr" make target, one image will generated containing both, U-Boot SPL (with mkimage header as needed by the SPEAr BootROM, and the main U-Boot with mkimage header. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Amit Virdi <amit.virdi@st.com> Cc: Vipin Kumar <vipin.kumar@st.com>
