path: root/include/e500.h
2013-08-20powerpc: Fix CamelCase checkpatch warningsPrabhakar Kushwaha
85xx, 86xx PowerPC folders have code variables with CamelCase naming conventions. because of this code checkpatch script generates "WARNING: Avoid CamelCase". Convert variables name to normal naming convention and modify board, driver files with updated the new structure. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2012-10-22poweprc/85xx: add QMan frequency info and fdt fixup.Haiying Wang
Starting from QMan3.0, the QMan clock cycle needs be exposed so that the kernel driver can use it to calculate the shaper prescaler and rate. Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2009-09-24ppc/p4080: Determine various chip frequencies on CoreNet platformsKumar Gala
The means to determine the core, bus, and DDR frequencies are completely new on CoreNet style platforms. Additionally on p4080 we can have different frequencies for FMAN and PME IP blocks. We need to keep track of the FMAN & PME frequencies since they are used for time stamping capabilities inside each block. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-288xxx: Removed CONFIG_NUM_CPUS from 85xx/86xxPoonam Aggrwal
The number of CPUs are getting detected dynamically by checking the processor SVR value. Also removed CONFIG_NUM_CPUS references from all the platforms with 85xx/86xx processors. This can help to use the same u-boot image across the platforms. Also revamped and corrected few Freescale Copyright messages. Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-06-1285xx: Add QE clk supportHaiying Wang
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Acked-by: Timur Tabi <Timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-01-23Add secondary CPUs processor frequency for e500 coreHaiying Wang
This patch updates e500 freqProcessor to array based on CONFIG_NUM_CPUS, and prints each CPU's frequency separately. It also fixes up each CPU's frequency in "clock-frequency" of fdt blob. Signed-off-by: James Yang <James.Yang@freescale.com> Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
2008-12-19mpc8[56]xx: Put localbus clock in sysinfo and gdTrent Piepho
Currently MPC85xx and MPC86xx boards just calculate the localbus frequency and print it out, but don't save it. This changes where its calculated and stored to be more consistent with the CPU, CCB, TB, and DDR frequencies and the MPC83xx localbus clock. The localbus frequency is added to sysinfo and calculated when sysinfo is set up, in cpu/mpc8[56]xx/speed.c, the same as the other frequencies are. get_clocks() copies the frequency into the global data, as the other frequencies are, into a new field that is only enabled for MPC85xx and MPC86xx. checkcpu() in cpu/mpc8[56]xx/cpu.c will print out the local bus frequency from sysinfo, like the other frequencies, instead of calculating it on the spot. Signed-off-by: Trent Piepho <tpiepho@freescale.com> Acked-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Jon Loeliger <jdl@freescale.com>
2008-01-09Reworked FSL Book-E TLB macros to be more readableKumar Gala
The old macros made it difficult to know what WIMGE and perm bits were set for a TLB entry. Actually use the bit masks for these items since they are only a single bit. Also moved the macros into mmu.h out of e500.h since they aren't specific to e500. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-09Use FSL Book-E MMU macros from Linux KernelKumar Gala
Grab the FSL Book-E MAS register macros from Linux. Also added defines for page sizes up to 4TB and removed SHAREN since it doesnt really exist. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-12-11Handle Asynchronous DDR clock on 85xxKumar Gala
The MPC8572 introduces the concept of an asynchronous DDR clock with regards to the platform clock. Introduce get_ddr_freq() to report the DDR freq regardless of sync/async mode. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2004-08-01Patch by Jon Loeliger, 16 Jul 2004:wdenk
- support larger DDR memories up to 2G on the PC8540/8560ADS and STXGP3 boards - Made MPC8540/8560ADS be 33Mhz PCI by default. - Removed moldy CONFIG_RAM_AS_FLASH, CFG_FLASH_PORT_WIDTH_16 and CONFIG_L2_INIT_RAM options. - Refactor Local Bus initialization out of SDRAM setup. - Re-implement new version of LBC11/DDR11 errata workarounds. - Moved board specific PCI init parts out of CPU directory. - Added TLB entry for PCI-1 IO Memory - Updated README.mpc85xxads
