path: root/include/faraday
2014-01-24include: delete unused header filesMasahiro Yamada
2013-12-08mmc: add Faraday FTSDC021 SDHCI controller supportKuo-Jung Su
Faraday FTSDC021 is a controller which is compliant with SDHCI v3.0, SDIO v2.0 and MMC v4.3. However this driver is only verified with SD memory cards. Signed-off-by: Kuo-Jung Su <dantesu@faraday-tech.com> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com> CC: Andy Fleming <afleming@gmail.com>
2013-07-25Merge branch 'master' of git://git.denx.de/u-boot-nds32Tom Rini
2013-07-24pci: move pci_ftpci100.h to include/faraday/ftpci100.hGabor Juhos
Even though the header files is used only by the pci_ftpci100 driver, it contains declaration for a function which is used by external code. Move the header file to a common location which lets external code use it. Compile tested only. Cc: Macpaul Lin <macpaul@andestech.com> Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
2013-05-15mmc: update Faraday FTSDC010 for rw performanceKuo-Jung Su
Faraday FTSDC010 is a MMC/SD host controller. Although there is already a driver in current u-boot release, which is modified from eSHDC and contributed by Andes Tech. Its performance is too terrible on Faraday A36x SoC platforms, so I turn to implement this new version of driver which is 10+ times faster than the old one. It's carefully designed to be compatible with Andes chips, so it should be safe to replace it. Signed-off-by: Kuo-Jung Su <dantesu@faraday-tech.com> CC: Andy Fleming <afleming@gmail.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2011-09-04ftsdc010: add support of ftsdc010 mmc controllerMacpaul Lin
Faraday FTSDC010 controller is a SD/MMC controller for SoC chip. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-05-12ftpmu010.h: fix some missing declaration in headerMacpaul Lin
Fix some missing declaration in header. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-05-12ftsmc020: add missing definitionsMacpaul Lin
Add missing definitions in header file according to datasheet. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-05-12ftsmc020: un-nest the register structure in headerMacpaul Lin
Un-nestted the register structure in ftsmc020.h Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-05-12ftsdmc021: add register definitions of ftsdmc021Macpaul Lin
Support registers definitions of ftsdmc021 SDRAM controller. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-05-12ftahbc020s: Faraday FTAHBC020s AHB Bus ControllerMacpaul Lin
ftahbc020s.h provides basic definitions of this controller to help a SoC which use this AHB Controller could do scalable software settings in lowlevel_init.S. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-04-27ftsmc020: move ftsmc020 static mem controller to driver/mtdMacpaul Lin
Move the header file and definitions of ftsmc020 static memory control unit from a320 SoC folder to "drivers/mtd" folder. This change will let other SoC which also use ftsmc020 could share the same header file. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-04-27ftsdmc020: move ftsdmc020.h to include/faradayMacpaul Lin
Move the header file "ftsdmc020.h" (SDRAM Controller) to "include/faraday" folder. This change will let other SoC which also use ftsdmc020 could share the same header file. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-04-27fttmr010: move fttmr010 header to include/faradayMacpaul Lin
Move the header file and definitions of fttmr010 power control unit from a320 SoC folder to "include/faraday" folder. This change will let other SoC which also use fttmr010 could share the same header file. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-04-27ftpmu010.h: add asm support used by lowlevel_initMacpaul Lin
Add asm support which is ususally used in lowlevel_init to set power related parameters to sdram controller and static memory controller. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-04-27ftpmu010: fix relocation and enhance featuresMacpaul Lin
1. ftpmu010.h: fix and add definitions Enhanced for more features and asm related support according to datasheet. Note: - FTPMU010_PDLLCR0_HCLKOUTDIS is "incorrect" in datasheet. - FTPMU010_PDLLCR0_DLLFRANG is only 1 bit at bit #19. (not 20-19) - FTPMU010_PDLLCR0_HCLKOUTDIS is 4 bits at bit #20. (not 24-21) 2. ftpmu010.c: enhance features and fix relocation - The following functions is added for pmu features. ftpmu010_mfpsr_select_dev() ftpmu010_sdramhtc_set() - This patch also fix the declare statement for relocation. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-04-27power: ftpmu010: move drivers/power/ftpmu010.h to include/faradayPo-Yu Chuang
Also add API declarations. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com> Signed-off-by: Albert Aribaud <albert.aribaud@free.fr>
2011-04-12ftwdt010_wdt: move header to include/faraday and enhanceMacpaul Lin
1. Move header to include/faraday 2. Fix include path in ftwdt010_wdt.c 3. Fix function prototype and declaration to - ftwdt010_wdt_settimeout - ftwdt010_wdt_reset - ftwdt010_wdt_disable 4. Add "#if definde (CONFIG_HW_WATCHDOG)" let user have flexibilty to choose which better to his product. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
