path: root/include/fastboot.h
2018-05-30fastboot: Add support for 'oem format' commandAlex Kiernan
Introduce 'oem format' which matches the USB implementation, guard this with CONFIG_FASTBOOT_CMD_OEM_FORMAT so that you can configure it out. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-05-30net: fastboot: Merge AOSP UDP fastbootAlex Kiernan
Merge UDP fastboot support from AOSP: https://android.googlesource.com/platform/external/u-boot/+/android-o-mr1-iot-preview-8 Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Signed-off-by: Alex Deymo <deymo@google.com> Signed-off-by: Jocelyn Bohr <bohr@google.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-05-30fastboot: Extract common definitions from USB fastbootAlex Kiernan
Move FASTBOOT_VERSION to include/fastboot.h so when we merge the UDP code we only have one definition. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-05-30fastboot: Rename fb_set_reboot_flag to fastboot_set_reboot_flagAlex Kiernan
Rename fb_set_reboot_flag to fastboot_set_reboot_flag so it matches all other fastboot code in the global name space. Fix the guards around them so that they're dependent on FASTBOOT, not just USB_FUNCTION_FASTBOOT. Move the weak implementation of fastboot_set_reboot_flag to fb_common.c so we can call it from non-USB fastboot code. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-05-30fastboot: Extract fastboot_okay/fail to fb_common.cAlex Kiernan
Add drivers/fastboot/fb_common.c, where fastboot_okay/fail are implemented so we can call them from a non-USB implementation. Introduce fastboot_response which takes varargs parameters so we can use it to generate formatted response strings. Refactor fastboot_okay/fail to use it. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2018-05-30fastboot: Refactor fastboot_okay/fail to take responseAlex Kiernan
Add the response string as a parameter to fastboot_okay/fail, instead of modifying a global, to match the contract expected by the AOSP U-Boot code. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2016-06-27fastboot: sparse: resync common/image-sparse.c (part 2)Steve Rae
- update fastboot_okay() and fastboot_fail() This file originally came from upstream code. While retaining the storage abstraction feature, this is the second set of the changes required to resync with the cmd_flash_mmc_sparse_img() in the file aboot.c from https://us.codeaurora.org/cgit/quic/la/kernel/lk/plain/app/aboot/aboot.c?h=LE.BR.1.2.1 Signed-off-by: Steve Rae <srae@broadcom.com>
2015-11-12fastboot: Move fastboot response functions to fastboot coreMaxime Ripard
The functions and a few define to generate a fastboot message to be sent back to the host were so far duplicated among the users. Move them all to a common place. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
