path: root/include/fb_nand.h
2019-06-14fastboot: Use const qualifier for char *part_nameSam Protsenko
In fastboot_*_get_part_info() functions we can use stronger typing by expecting const strings. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2018-05-30net: fastboot: Merge AOSP UDP fastbootAlex Kiernan
Merge UDP fastboot support from AOSP: https://android.googlesource.com/platform/external/u-boot/+/android-o-mr1-iot-preview-8 Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Signed-off-by: Alex Deymo <deymo@google.com> Signed-off-by: Jocelyn Bohr <bohr@google.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-05-30fastboot: Rename public fb_ functions to fastboot_Alex Kiernan
Rename fb_mmc_flash_write/fb_mmc_erase/fb_nand_flash_write/fb_nand_erase to fastboot_... as they form a public interface Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-05-30fastboot: Refactor fastboot_okay/fail to take responseAlex Kiernan
Add the response string as a parameter to fastboot_okay/fail, instead of modifying a global, to match the contract expected by the AOSP U-Boot code. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2016-06-27fastboot: sparse: resync common/image-sparse.c (part 2)Steve Rae
- update fastboot_okay() and fastboot_fail() This file originally came from upstream code. While retaining the storage abstraction feature, this is the second set of the changes required to resync with the cmd_flash_mmc_sparse_img() in the file aboot.c from https://us.codeaurora.org/cgit/quic/la/kernel/lk/plain/app/aboot/aboot.c?h=LE.BR.1.2.1 Signed-off-by: Steve Rae <srae@broadcom.com>
2016-06-27fastboot: sparse: remove session-id logicSteve Rae
This "session-id" alogrithm is not required, and currently corrupts the stored image whenever more the one "session" is required. Signed-off-by: Steve Rae <srae@broadcom.com>
2015-11-12fastboot: Implement NAND backendMaxime Ripard
So far the fastboot code was only supporting MMC-backed devices for its flashing operations (flash and erase). Add a storage backend for NAND-backed devices. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
