path: root/include/fsl_validate.h
2016-07-21powerpc/mpc85xx: SECURE BOOT- Enable chain of trust in SPLSumit Garg
As part of Chain of Trust for Secure boot, the SPL U-Boot will validate the next level U-boot image. Add a new function spl_validate_uboot to perform the validation. Enable hardware crypto operations in SPL using SEC block. In case of Secure Boot, PAMU is not bypassed. For allowing SEC block access to CPC configured as SRAM, configure PAMU. Reviewed-by: Ruchika Gupta <ruchika.gupta@nxp.com> Signed-off-by: Aneesh Bansal <aneesh.bansal@nxp.com> Signed-off-by: Sumit Garg <sumit.garg@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: York Sun <york.sun@nxp.com>
2016-03-29SECURE BOOT: Change fsl_secboot_validate func to pass image addrSaksham Jain
Use a pointer to pass image address to fsl_secboot_validate(), instead of using environmental variable "img_addr". Signed-off-by: Aneesh Bansal <aneesh.bansal@nxp.com> Signed-off-by: Saksham Jain <saksham.jain@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-03-29SECURE BOOT: Halt execution when secure boot failSaksham Jain
In case of fatal failure during secure boot execution (e.g. header not found), reset is asserted to stop execution. If the RESET_REQ is not tied to HRESET, this allows the execution to continue. Add esbh_halt() after the reset to make sure execution stops. Signed-off-by: Aneesh Bansal <aneesh.bansal@nxp.com> Signed-off-by: Saksham Jain <saksham.jain@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-03-29armv8: fsl-lsch3: Add new header for secure bootSaksham Jain
For secure boot, a header is used to identify key table, signature and image address. A new header structure is added for lsch3. Currently key extension (IE) feature is not supported. Single key feature is not supported. Keys must be in table format. Hence, SRK (key table) must be present. Max key number has increase from 4 to 8. The 8th key is irrevocable. A new barker Code is used. Signed-off-by: Aneesh Bansal <aneesh.bansal@nxp.com> Signed-off-by: Saksham Jain <saksham.jain@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-01-27secure_boot: enable chain of trust for ARM platformsAneesh Bansal
Chain of Trust is enabled for ARM platforms (LS1021 and LS1043). In board_late_init(), fsl_setenv_chain_of_trust() is called which will perform the following: - If boot mode is non-secure, return (No Change) - If boot mode is secure, set the following environmet variables: bootdelay = 0 (To disable Boot Prompt) bootcmd = CONFIG_CHAIN_BOOT_CMD (Validate and execute Boot script) Signed-off-by: Aneesh Bansal <aneesh.bansal@nxp.com> Acked-by: Ruchika Gupta <ruchika.gupta@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-01-25SECURE BOOT: support for validation of dynamic imageAneesh Bansal
Some images to be validated are relocated to a dynamic address at run time. So, these addresses cannot be known befor hand while signing the images and creating the header offline. So, support is required to pass the image address to the validate function as an argument. If an address is provided to the function, the address field in Header is not read and is treated as a reserved field. Signed-off-by: Saksham Jain <saksham@freescale.com> Signed-off-by: Aneesh Bansal <aneesh.bansal@freescale.com> Acked-by: Ruchika Gupta <ruchika.gupta@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-01-25SECURE BOOT: change prototype of fsl_secboot_validate functionAneesh Bansal
The prototype and defination of function fsl_secboot_validate has been changed to support calling this function from another function within u-boot. Only two aruments needed: 1) header address - Mandatory 2) SHA256 string - optional Signed-off-by: Saksham Jain <saksham@freescale.com> Signed-off-by: Aneesh Bansal <aneesh.bansal@freescale.com> Acked-by: Ruchika Gupta <ruchika.gupta@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2015-12-15armv8/ls1043ardb: add SECURE BOOT target for NORAneesh Bansal
LS1043ARDB Secure Boot Target from NOR has been added. - Configs defined to enable esbc_validate. - ESBC Address in header is made 64 bit. - SMMU is re-configured in Bypass mode. Signed-off-by: Aneesh Bansal <aneesh.bansal@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-10-29Pointers in ESBC header made 32 bitAneesh Bansal
For the Chain of Trust, the esbc_validate command supports 32 bit fields for location of the image. In the header structure definition, these were declared as pointers which made them 64 bit on a 64 bit core. Signed-off-by: Aneesh Bansal <aneesh.bansal@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-03-05SECURE BOOT: Add command for validation of imagesgaurav rana
1. esbc_validate command is meant for validating header and signature of images (Boot Script and ESBC uboot client). SHA-256 and RSA operations are performed using SEC block in HW. This command works on both PBL based and Non PBL based Freescale platforms. Command usage: esbc_validate img_hdr_addr [pub_key_hash] 2. ESBC uboot client can be linux. Additionally, rootfs and device tree blob can also be signed. 3. In the event of header or signature failure in validation, ITS and ITF bits determine further course of action. 4. In case of soft failure, appropriate error is dumped on console. 5. In case of hard failure, SoC is issued RESET REQUEST after dumping error on the console. 6. KEY REVOCATION Feature: QorIQ platforms like B4/T4 have support of srk key table and key revocation in ISBC code in Silicon. The srk key table allows the user to have a key table with multiple keys and revoke any key in case of particular key gets compromised. In case the ISBC code uses the key revocation and srk key table to verify the u-boot code, the subsequent chain of trust should also use the same. 6. ISBC KEY EXTENSION Feature: This feature allows large number of keys to be used for esbc validation of images. A set of public keys is being signed and validated by ISBC which can be further used for esbc validation of images. Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> Signed-off-by: Gaurav Rana <gaurav.rana@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
