path: root/include/inttypes.h
2018-12-05Add inttypes.hSimon Glass
Even if U-Boot does not use this, some libraries do. Add back this header file so that the build does not fall back to using the host version, which may include stdint.h and break the build due to conflicts with uint64_t, etc. This partially reverts commit dee37fc99d94 ("Remove <inttypes.h> includes and PRI* usages in printf() entirely") The only change from the file that was in U-Boot until recently is that it now comes twice as close to passing checkpatch. The remaining warnings pertain to the typedefs, which checkpatch does not like. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-09-10Remove <inttypes.h> includes and PRI* usages in printf() entirelyMasahiro Yamada
In int-ll64.h, we always use the following typedefs: typedef unsigned int u32; typedef unsigned long uintptr_t; typedef unsigned long long u64; This does not need to match to the compiler's <inttypes.h>. Do not include it. The use of PRI* makes the code super-ugly. You can simply use "l" for printing uintptr_t, "ll" for u64, and no modifier for u32. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-09-10Remove CONFIG_USE_STDINTMasahiro Yamada
You do not need to use the typedefs provided by compiler. Our compilers are either IPL32 or LP64. Hence, U-Boot can/should always use int-ll64.h typedefs like Linux kernel, whatever the typedefs the compiler internally uses. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2014-10-27Add some standard headers external code might needGabe Black
inttypes.h defines format specifiers for printf which work with data types of particular sizes. stdlib.h is currently just a passthrough to malloc.h which has declarations of the various *alloc functions. Add the required #define to common.h so that these printf format specifiers will be made available. Signed-off-by: Gabe Black <gabeblack@google.com> Reviewed-by: Gabe Black <gabeblack@chromium.org> Tested-by: Gabe Black <gabeblack@chromium.org> Reviewed-by: Bill Richardson <wfrichar@google.com> Signed-off-by: Simon Glass <sjg@chromium.org> (Replaced with a GPL version from glibc)
