path: root/include/jffs2
2013-10-09cmd_mtdparts: use 64 bits for flash size, partition size & offsetPaul Burton
This matches the 64 bit size in struct mtd_info and allows the mtdparts command to function correctly with a flash >= 4GiB. Format specifiers for size & offset are given the ll length, matching its use in drivers/mtd in absence of something like inttypes.h/PRIx64. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Acked-by: Stefan Roese <sr@denx.de>
2010-03-21fdt_support: add partitions fixup in mtd nodeAnatolij Gustschin
Allow overwriting defined partitions in the device tree blob using partition info defined in the 'mtdparts' environment variable. Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Gerald Van Baren <vanbaren@cideas.com>
2010-01-15JFFS2: drop support for LZARI compression modeWolfgang Denk
Support for LZARI compression mode was added based on a MTD CVS snapshot of March 13, 2005. However, fs/jffs2/compr_lzari.c contains contradictory licensing terms: the original copyright clause says "All rights reserved. Permission granted for non-commercial use.", but later reference to the file 'LICENCE' in the jffs2 directory was added which says GPL v2 or later. As no boards ever used LZARI compression, and this file is also not present in recent MTD code, we resolve this conflict by removing the conflicting file and references to it. Also copy the referenced but missing file 'LICENCE' from the current MTD source tree. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-12-09jffs2: summary supportIlya Yanok
This patch adds support for reading fs information from summary node instead of scanning full eraseblock. Signed-off-by: Ilya Yanok <yanok@emcraft.com>
2008-12-09jffs2: add sector_size field to part_info structureIlya Yanok
This patch adds sector_size field to part_info structure (used by new JFFS2 code). Signed-off-by: Ilya Yanok <yanok@emcraft.com>
2008-11-19UBI: Add basic UBI support to U-Boot (Part 6/8)Kyungmin Park
This patch adds basic UBI (Unsorted Block Image) support to U-Boot. It's based on the Linux UBI version and basically has a "OS" translation wrapper that defines most Linux specific calls (spin_lock() etc.) into no-ops. Some source code parts have been uncommented by "#ifdef UBI_LINUX". This makes it easier to compare this version with the Linux version and simplifies future UBI ports/bug-fixes from the Linux version. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-09-06Add JFFS2 command support on OneNANDKyungmin Park
2005-08-08Add common (with Linux) MTD partition scheme and "mtdparts" commandWolfgang Denk
Old, obsolete and duplicated code was cleaned up and replace by the new partitioning method. There are two possible approaches now: * define a single, static partition * use mtdparts command line option and dynamic partitioning Default is static partitioning.
2005-05-12* Fix debug code in omap5912osk flash driverLABEL_2005_05_13_0050wdenk
* Add support for MPC8247 based "IDS8247" board.
2005-05-05It's better to handle LZO and LZARI compression mdoes for JFFS2 withLABEL_2005_05_05_1920wdenk
a single #define.
2005-05-05Major upate of JFFS2 code; now in sync with snapshot of MTD CVS ofwdenk
March 13, 2005); new configuration options CONFIG_JFFS2_LZO and CONFIG_JFFS2_LZARI are added. Both are undefined by default.
2004-01-04* Fix problems caused by Robert Schwebel's cramfs patchwdenk
* Patch by Scott McNutt, 02 Jan 2004: Add support for the Nios Active Serial Memory Interface (ASMI) on Cyclone devices * Patch by Andrea Marson, 16 Dec 2003: Add support for the PPChameleon ME and HI modules * Patch by Yuli Barcohen, 22 Dec 2003: Add support for Motorola DUET ADS board (MPC87x/88x)
2003-09-10* Patches by Denis Peter, 9 Sep 2003:U-Boot-0_4_8wdenk
add FAT support for IDE, SCSI and USB * Patches by Gleb Natapov, 2 Sep 2003: - cleanup of POST code for unsupported architectures - MPC824x locks way0 of data cache for use as initial RAM; this patch unlocks it after relocation to RAM and invalidates the locked entries. * Patch by Gleb Natapov, 30 Aug 2003: new I2C driver for mpc107 bridge. Now works from flash. * Patch by Dave Ellis, 11 Aug 2003: - JFFS2: fix typo in common/cmd_jffs2.c - JFFS2: fix CFG_JFFS2_SORT_FRAGMENTS option - JFFS2: remove node version 0 warning - JFFS2: accept JFFS2 PADDING nodes - SXNI855T: add AM29LV800 support - SXNI855T: move environment from EEPROM to flash - SXNI855T: boot from JFFS2 in NOR or NAND flash * Patch by Bill Hargen, 11 Aug 2003: fixes for I2C on MPC8240 - fix i2c_write routine - fix iprobe command - eliminates use of global variables, plus dead code, cleanup.
2002-03-08Initial revisionwdenk
2002-01-27Initial revisionwdenk
