path: root/include/libtizen.h
2016-05-25exynos: Allow tizen to be built without an LCDSimon Glass
This file currently requires an LCD. Adjust it to work without one. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-05-25create lib/tizen directoryDonghwa Lee
This directory includes tizen logo data, common tizen library and so on. Signed-off-by: Donghwa Lee <dh09.lee@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Minkyu Kang <mk7.kang@samsung.com> [ agust: change to conditionally build lib/tizen directory ] Signed-off-by: Anatolij Gustschin <agust@denx.de>
