path: root/include/mc34704.h
2015-03-02mc34704: Add the definition of ONOFFA bitFabio Estevam
ONOFFA is the bit 3 of the GENERAL2 register. Add its definition. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-10-26pmic: Add support for mc34704Fabio Estevam
Add the register layout for the MC34704 PMIC from Freescale. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
