path: root/include/mk48t59.h
2007-07-09include/: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
Mostly removed from comments here. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-07-04include/ non-config: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2002-03-08Initial revisionwdenk
