path: root/include/mpc85xx.h
2015-04-20powerpc/mpc85xx: Don't relocate exception vectorsScott Wood
Booke does not require exception vectors to be located at address zero. U-Boot was doing so anyway, simply because that's how it had been done on other PPC. The downside of this is that once the OS is loaded to address zero, the exception vectors have been overwritten -- which makes it difficult to diagnose a crash that happens after that point. The IVOR setup and trap entry code is simplified somewhat as a result. Also, there is no longer a need to align individual exceptions on 0x100 byte boundaries. Signed-off-by: Scott Wood <scottwood@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2011-09-29powerpc/85xx: introduce and document CONFIG_SYS_CCSRBAR macrosTimur Tabi
Introduce the CONFIG_SYS_CCSRBAR_PHYS_HIGH and CONFIG_SYS_CCSRBAR_PHYS_LOW macros, which contain the high and low portions of CONFIG_SYS_CCSRBAR_PHYS. This is necessary for the assembly-language code that relocates CCSR, since the assembler does not understand 64-bit constants. CONFIG_SYS_CCSRBAR_PHYS is automatically defined from the CONFIG_SYS_CCSRBAR_PHYS_HIGH and CONFIG_SYS_CCSRBAR_PHYS_LOW macros, so it should not be defined in a board header file. Similarly, CONFIG_SYS_CCSRBAR_DEFAULT is defined for each SOC in config_mpc85xx.h, so it should also not be defined in the board header file. CONFIG_SYS_CCSR_DO_NOT_RELOCATE is a "short-cut" macro that guarantees that CONFIG_SYS_CCSRBAR_PHYS is set to the same value as CONFIG_SYS_CCSRBAR_DEFAULT, and so CCSR will not be relocated. Since CONFIG_SYS_CCSRBAR_DEFAULT is locked to a fixed value, multi-stage U-Boot builds (e.g. NAND) are required to relocate CCSR only during the last stage (i.e. the "real" U-Boot). All other stages should define CONFIG_SYS_CCSR_DO_NOT_RELOCATE to ensure that CCSR is not relocated. README is updated with descriptions of all the CONFIG_SYS_CCSRBAR_xxx macros. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-1683xx/85xx/86xx: LBC register cleanupBecky Bruce
Currently, 83xx, 86xx, and 85xx have a lot of duplicated code dedicated to defining and manipulating the LBC registers. Merge this into a single spot. To do this, we have to decide on a common name for the data structure that holds the lbc registers - it will now be known as fsl_lbc_t, and we adopt a common name for the immap layouts that include the lbc - this was previously known as either im_lbc or lbus; use the former. In addition, create accessors for the BR/OR regs that use in/out_be32 and use those instead of the mismash of access methods currently in play. I have done a successful ppc build all and tested a board or two from each processor family. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Acked-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-06-1083xx/85xx: further localbus cleanupsAnton Vorontsov
move the BRx_* and ORx_* left behind in mpc85xx.h The same is needed for mpc8xx.h and mpc8260.h (defines are almost the same, just few differences which needs some attention though). But the bad news for mpc8xx and mpc8260 is that there are a lot of users of these defines. So this cleanup I'll leave for the "better times". Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-06-1083xx/85xx/86xx: factor out Freescale Localbus defines out of mpc83xx.hAnton Vorontsov
This patch moves Freescale Localbus defines out of mpc83xx.h, so we could use it on MPC85xx and MPC86xx processors. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Acked-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-1485xx start.S cleanup and exception supportAndy Fleming
From: Ed Swarthout <Ed.Swarthout@freescale.com> Support external interrupts from platform to eliminate system hangs. Define CONFIG_INTERRUPTS board configure option to enable. Enable ecm, ddr, lbc, and pci/pcie error interrupts in PIC. Remove extra cpu initialization redundant with hardware initialization. Whitespace cleanup. Define and use _START_OFFSET consistent with other processors using ppc_asm.tmpl Move additional code from .text to boot page to make room for exception vectors at start of image. Handle Machine Check, External and Critical exceptions. Fix e500 machine check error determination in traps.c TEXT_BASE can now be 0xfffc_0000 - which cuts binary image in half. Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com> Acked-by: Andy Fleming <afleming@freescale.com>
2007-06-22[ppc] Fix build breakage for all non-4xx PowerPC variants.Rafal Jaworowski
- adapt to the more generic EXCEPTION_PROLOG and CRIT_EXCEPTION macros - minor 4xx cleanup
2006-03-12Add (some) definitions for the MPC85xx local bus controllerWolfgang Denk
Patch by Murray Jensen, 08 Jul 2005
2004-07-09Patch by Jon Loeliger, 17 June 2004:wdenk
Completion of the 8540ADS/8560ADS updates: Fix some PCI and Rapid I/O memory maps, Initialize both TSEC 1 and 2, Initialize SDRAM Update MAINTAINER for 85xx boards and README.mpc85xxads
