path: root/include/os.h
2020-02-05sandbox: Drop os_realloc()Simon Glass
Due to recent changes this function is no-longer used. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-04-23sandbox: Improve debugging in initcall_run_list()Simon Glass
At present if one of the initcalls fails on sandbox the address printing is not help, e.g.: initcall sequence 0000557678967c80 failed at call 00005576709dfe1f (err=-96) This is because U-Boot gets relocated high into memory and the relocation offset (gd->reloc_off) does not work correctly for sandbox. Add support for finding the base address of the text region (at least on Linux) and use that to set the relocation offset. This makes the output better: initcall sequence 0000560775957c80 failed at call 0000000000048134 (err=-96) Then you use can use grep to see which init call failed, e.g.: $ grep 0000000000048134 u-boot.map stdio_add_devices Of course another option is to run it with a debugger such as gdb: $ gdb u-boot ... (gdb) br initcall.h:41 Breakpoint 1 at 0x4db9d: initcall.h:41. (2 locations) Note that two locations are reported, since this function is used in both board_init_f() and board_init_r(). (gdb) r Starting program: /tmp/b/sandbox/u-boot [Thread debugging using libthread_db enabled] Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1". U-Boot 2018.09-00264-ge0c2ba9814-dirty (Sep 22 2018 - 12:21:46 -0600) DRAM: 128 MiB MMC: Breakpoint 1, initcall_run_list (init_sequence=0x5555559619e0 <init_sequence_f>) at /scratch/sglass/cosarm/src/third_party/u-boot/files/include/initcall.h:41 41 printf("initcall sequence %p failed at call %p (err=%d)\n", (gdb) print *init_fnc_ptr $1 = (const init_fnc_t) 0x55555559c114 <stdio_add_devices> (gdb) Signed-off-by: Simon Glass <sjg@chromium.org>
2018-11-20sandbox: Add a function to read a host fileSimon Glass
Add a way to read a file from the host filesystem. This can be useful for reading test data, for example. Also fix up the writing function which was not the right version, and drop the debugging lines. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-10-09sandbox: Restore blocking I/O on exitSimon Glass
At present sandbox sets non-blocking I/O as soon as any input is read from the terminal. However it does not restore the previous state on exit. Fix this and drop the old os_read_no_block() function. This means that we always enable blocking I/O in sandbox (if input is a terminal) whereas previously it would only happen on the first call to tstc() or getc(). However, the difference is likely not important. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-10-09sandbox: Add a way to write data to the host filesystemSimon Glass
For debugging it is sometimes useful to write out data for inspection using an external tool. Add a function which can write this data to a given file. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-10-09sandbox: Support file truncation with os_open()Simon Glass
At present files are not truncated on writing. This is a useful feature. Add support for this. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-10-08sandbox: Unprotect DATA regions in bus testsSimon Glass
On my Ubuntu 18.04.1 machine two driver-model bus tests have started failing recently. The problem appears to be that the DATA region of the executable is protected. This does not seem correct, but perhaps there is a reason. To work around it, unprotect the regions in these tests before accessing them. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-09-23sandbox: Fix setjmp/longjmpAlexander Graf
In sandbox, longjmp returns to itself in an endless loop because os_longjmp() calls into longjmp() which is provided by U-Boot which again calls os_longjmp(). Setjmp on the other hand must not return because otherwise the return freees up stack elements that we need during longjmp(). The only straight forward fix that doesn't involve nasty hacks I could find is to directly link against the system setjmp/longjmp implementations. That means we just provide the compiler with hints that the symbol will be available and actually fill them out with versions from libc. This approach should be reasonably platform agnostic Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-09-23sandbox: Add support for calling abort()Simon Glass
This function is useful to signal that the application needs to exit immediate. It can be caught with a debugger (e.g. gdb). Add a stub for it so that it can be called from within sandbox when an internal error occurs. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-06-03sandbox: Add a setjmp() implementationSimon Glass
Add an implementation of setjmp() and longjmp() which rely on the underlying host C library. Since we cannot know how large the jump buffer needs to be, pick something that should be suitable and check it at runtime. At present we need access to the underlying struct as well. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2017-12-07Revert "sandbox: remove os_putc() and os_puts()"Simon Glass
While sandbox works OK without the special-case code, it does result in console output being stored in the pre-console buffer while sandbox starts up. If there is a crash or a problem then there is no indication of what is going on. For ease of debugging it seems better to revert this change. This reverts commit 47b98ad0f6779485d0f0c14f337c3eece273eb54. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-07-28sandbox: remove os_putc() and os_puts()Masahiro Yamada
They are unused since commit d8c6fb8cedbc ("sandbox: Drop special case console code for sandbox"). Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-11sandbox/fs: Free memory allocated by os_dirent_lsStefan Brüns
Signed-off-by: Stefan Brüns <stefan.bruens@rwth-aachen.de> Acked-by: Simon Glass <sjg@chromium.org>
2016-07-14sandbox: Allow chaining from SPL to U-Boot properSimon Glass
SPL is expected to load and run U-Boot. This needs to work with sandbox also. Provide a function to locate the U-Boot image, and another to start it. This allows SPL to function on sandbox as it does on other archs. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-06-04sandbox: Tidy up terminal restoreSimon Glass
For some reason 'u-boot -D' does not restore the terminal correctly when the 'reset' command is used. Call the terminal restore function explicitly in this case. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2015-05-05dm: sandbox: Add os_localtime() to obtain the system timeSimon Glass
Add a function to read the system time into U-Boot. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18sandbox: Fix comment for os_open()Simon Glass
This has the wrong #define in the function comment. Fix it. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2014-11-23sandbox: Prepare API change for files greater than 2GBSuriyan Ramasami
Change the internal sandbox functions to use loff_t for file offsets. Signed-off-by: Suriyan Ramasami <suriyan.r@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-03-17sandbox: Allow Ctrl-C to work in sandboxSimon Glass
It is useful for Cltl-C to be handled by U-Boot as it is on other boards. But it is also useful to be able to terminate U-Boot with Ctrl-C. Add an option to enable signals while in raw mode, and make this the default. Add an option to leave the terminal cooked, which is useful for redirecting output. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-17sandbox: Add os_jump_to_image() to run another executableSimon Glass
For some tests it is useful to be able to run U-Boot again but pass on the same memory contents. Add a function to achieve this. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-07unit-test: make "test -e" test independent of $CWDStephen Warren
The unit-test for hush's "test -e" currently relies upon being run in the U-Boot build directory, because it tests for the existence of a file that exists in that directory. Fix this by explicitly creating the file we use for the existence test, and deleting it afterwards so that multiple successive unit-test invocations succeed. This required adding an os.c function to erase files. Reported-by: Simon Glass <sjg@chromium.org> Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
2014-01-24sandbox: fix the return type of os_free() functionMasahiro Yamada
The function os_free() returns nothing. Its return type should be "void" rather than "void *". Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-01-08sandbox: Allow reading/writing of RAM bufferSimon Glass
It is useful to be able to save and restore the RAM contents of sandbox U-Boot either for setting up tests, for later analysys, or for chaining together multiple tests which need to keep the same memory contents. Add a function to provide a memory file for U-Boot. This is read on start-up and written when shutting down. If the file does not exist on start-up, it will be created when shutting down. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-01-08sandbox: Allow the console to work earlierSimon Glass
With sandbox, errors and problems may be reported before console_init_f() is executed. For example, an argument may not parse correctly or U-Boot may panic(). At present this output is swallowed so there is no indication what is going wrong. Adjust the console to deal with a very early sandbox setup, by detecting that there is no global_data yet, and calling os functions in that case. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-01-08sandbox: Improve/augment memory allocation functionsSimon Glass
Implement realloc() and free() for sandbox, by adding a header to each block which contains the block size. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Che-Liang Chiou <clchiou@chromium.org> Reviewed-by: Hung-ying Tyan <tyanh@chromium.org>
2013-11-21sandbox: Use uint64_t instead of u64 for timeSimon Glass
The uint64_t type is defined in linux/types.h, so is safer than u64, which is not actually a Linux type. Change-Id: Ifc9a369e6543250c49117b8d3cb3a676eee43e04 Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-04sandbox: Add a way of obtaining directory listingsSimon Glass
This implementation uses opendir()/readdir() to access the directory information and then puts it in a linked list for the caller's use. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@ti.com>
2013-02-28sandbox: Improve sandbox serial port keyboard interfaceTaylor Hutt
Implements the tstc() interface for the serial driver. Multiplexing the console between the serial port and a keyboard uses a polling method of checking if characters are available; this means that the serial console must be non-blocking when attempting to read characters. Signed-off-by: Taylor Hutt <thutt@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2012-03-12sandbox: mark os_exit as noreturnMike Frysinger
2012-03-12sandbox: add getopt supportSimon Glass
This adds simple command-line parsing to sandbox. The idea is that it sets up the state with options provided, and this state can then be queried later, as needed. New flags are declared with the SB_CMDLINE_OPT_SHORT helper macro, pointers are automatically gathered up in a special section, and then the core code takes care of gathering them up and processing at runtime. This way there is no central place where we have to store a list of flags with ifdefs. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-03-12sandbox: add flags for open() callSimon Glass
This provides a way for callers to create files for writing. The flags are translated at runtime, for the ones we support. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-03-12sandbox: add lseek helperMike Frysinger
Follow up patches want to be able to seek fd's. Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-03-12sandbox: add ifdef protection to os.hMike Frysinger
2011-12-10sandbox: Add timer simulationMatthias Weisser
Making sleep command work Signed-off-by: Matthias Weisser <weisserm@arcor.de> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-12-10sandbox: Add improved RAM simulationMatthias Weisser
Using mmap to allocate memory from the OS for RAM simulation we can use u-boot own malloc implementation. Tested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Matthias Weisser <weisserm@arcor.de> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-11-03sandbox: put stdin into raw modeMike Frysinger
This allows us to act like a serial device: we get tab chars and CTRL+C and respond appropriately. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Tested-by: Simon Glass <sjg@chromium.org>
2011-10-17sandbox: Add OS dependent layerSimon Glass
We want to keep all OS-dependent code in once place, with a simple interface to U-Boot. For now, this is that place. Signed-off-by: Simon Glass <sjg@chromium.org>
