path: root/include/part.h
2020-05-18part: Drop disk_partition_t typedefSimon Glass
We should not be using typedefs and these make it harder to use forward declarations (to reduce header file inclusions). Drop the typedef. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-04-30part: detect EFI system partitionHeinrich Schuchardt
Up to now for MBR and GPT partitions the info field 'bootable' was set to 1 if either the partition was an EFI system partition or the bootable flag was set. Turn info field 'bootable' into a bit mask with separate bits for bootable and EFI system partition. This will allow us to identify the EFI system partition in the UEFI sub-system. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-07-24disk: part: Extend API to get partition infoRuslan Trofymenko
This patch adds part_get_info_by_dev_and_name_or_num() function which allows us to get partition info from its number or name. Partition of interest is specified by string like "device_num:partition_number" or "device_num#partition_name". The patch was extracted from [1]. [1] https://android-review.googlesource.com/c/platform/external/u-boot/+/729880/2 Signed-off-by: Ruslan Trofymenko <ruslan.trofymenko@linaro.org> Signed-off-by: Igor Opaniuk <igor.opaniuk@gmail.com> Reviewed-by: Alistair Strachan <astrachan@google.com> Reviewed-by: Sam Protsenko <semen.protsenko@linaro.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-02-01spl: Kconfig: Replace CONFIG_SPL_EXT_SUPPORT to CONFIG_SPL_FS_EXT4Tien Fong Chee
Replace CONFIG_SPL_EXT_SUPPORT to CONFIG_SPLY_FS_EXT4 so both obj-$(CONFIG_$(SPL_)FS_EXT4) and CONFIG_IS_ENABLED(FS_EXT4) can be used to control the build in both SPL and U-Boot. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-02-01spl: Kconfig: Replace CONFIG_SPL_FAT_SUPPORT with CONFIG_SPL_FS_FATTien Fong Chee
Replace CONFIG_SPL_FAT_SUPPORT with CONFIG_SPL_FS_FAT so obj-$(CONFIG_$(SPL_)FS_FAT) can be used to control the build in both SPL and U-Boot. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Reviewed-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-10-06disk: Provide API to get partition by name for specific typeSam Protsenko
There is already existing function part_get_info_by_name(). But sometimes user is particularly interested in looking for only specific partition type. This patch implements such an API that provides partition searching by name for specified partition type. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-20part: move efi_guid_tRob Clark
Prep work for next patch. Signed-off-by: Rob Clark <robdclark@gmail.com> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2017-09-15fs: add fs_readdir()Rob Clark
Needed to support efi file protocol. The fallback.efi loader wants to be able to read the contents of the /EFI directory to find an OS to boot. Modelled after POSIX opendir()/readdir()/closedir(). Unlike the other fs APIs, this is stateful (ie. state is held in the FS_DIR "directory stream"), to avoid re-traversing of the directory structure at each step. The directory stream must be released with closedir() when it is no longer needed. Signed-off-by: Rob Clark <robdclark@gmail.com> Reviewed-by: Łukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-03part: efi: make gpt_fill_pte take the device descriptorMaxime Ripard
The gpt_fill_pte will need to access the device block size. Let's pass the device descriptor as an argument. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-08-04GPT: read partition table from device into a data structureAlison Chaiken
Make the partition table available for modification by reading it from the user-specified device into a linked list. Provide an accessor function for command-line testing. Signed-off-by: Alison Chaiken <alison@peloton-tech.com> [trini: Make this depend on CMD_GPT_RENAME, as it is the user of this code] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-04GPT: add accessor function for disk GUIDAlison Chaiken
In order to read the GPT, modify the partition name strings, and then write out a new GPT, the disk GUID is needed. While there is an existing accessor for the partition UUIDs, there is none yet for the disk GUID. Changes since v6: none. Signed-off-by: Alison Chaiken <alison@peloton-tech.com>
2017-08-04partitions: increase MAX_SEARCH_PARTITIONS and move to part.hAlison Chaiken
Move MAX_SEARCH_PARTITIONS to part.h so that functions in cmd directory can find it. At the same time, increase the value to 64 since some operating systems use many, and the resources consumed by a larger value are minimal. Changes since v6: none. Signed-off-by: Alison Chaiken <alison@peloton-tech.com>
2017-08-04disk_partition: introduce macros for description string lengthsAlison Chaiken
2017-08-04EFI: replace number with UUID_STR_LEN macroAlison Chaiken
2017-05-11disk: Return the partition number in part_get_info_by_name()Alex Deymo
Similar to what blk_get_device_part_str() does, this patch makes part_get_info_by_name() return the partition number in case of a match. This is useful when the partition number is needed and not just the descriptor. Signed-off-by: Alex Deymo <deymo@google.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-02-17SPL: add support to boot from a partition typeDalon Westergreen
the socfpga bootrom supports mmc booting from either a raw image starting at 0x0, or from a partition of type 0xa2. This patch adds support for locating the boot image in the first type 0xa2 partition found. Assigned a partition number of -1 will cause a search for a partition of type CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION_TYPE and use it to find the u-boot image Signed-off-by: Dalon Westergreen <dwesterg@gmail.com>
2016-10-01disk: part: refactor generic name creation for DOS and ISOPetr Kulhavy
In both DOS and ISO partition tables the same code to create partition name like "hda1" was repeated. Code moved to into a new function part_set_generic_name() in part.c and optimized. Added recognition of MMC and SD types, name is like "mmcsda1". Signed-off-by: Petr Kulhavy <brain@jikos.cz> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Steve Rae <steve.rae@raedomain.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-01fastboot: add support for writing MBRPetr Kulhavy
Add special target "mbr" (otherwise configurable via CONFIG_FASTBOOT_MBR_NAME) to write MBR partition table. Partitions are now searched using the generic function which finds any partiiton by name. For MBR the partition names hda1, sda1, etc. are used. Signed-off-by: Petr Kulhavy <brain@jikos.cz> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Steve Rae <steve.rae@raedomain.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-01disk: part: implement generic function part_get_info_by_name()Petr Kulhavy
So far partition search by name has been supported only on the EFI partition table. This patch extends the search to all partition tables. Rename part_get_info_efi_by_name() to part_get_info_by_name(), move it from part_efi.c into part.c and make it a generic function which traverses all part drivers and searches all partitions (in the order given by the linked list). For this a new variable struct part_driver.max_entries is added, which limits the number of partitions searched. For EFI this was GPT_ENTRY_NUMBERS. Similarly the limit is defined for DOS, ISO, MAC and AMIGA partition tables. Signed-off-by: Petr Kulhavy <brain@jikos.cz> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Steve Rae <steve.rae@raedomain.com>
2016-05-17dm: mmc: Add support for driver-model block devicesSimon Glass
Add support for enabling CONFIG_BLK with MMC. This involves changing a few functions to use struct udevice and adding a MMC block device driver. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-05-17dm: part: Drop the get_dev() methodSimon Glass
This is now handled by the legacy block driver. The get_dev() method is no-longer used. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-05-17dm: sandbox: Drop the host_get_dev() functionSimon Glass
This function is implemented by the legacy block functions now. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-05-17dm: systemace: Drop the get_dev() functionSimon Glass
2016-05-17dm: sata: Drop the get_dev() functionSimon Glass
This function is implemented by the legacy block functions now. Drop it. We cannot yet make sata_dev_desc[] private to common/sata.c as it is used by the SATA drivers. This will require the SATA interface to be reworked. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-05-17dm: scsi: Drop the get_dev() functionSimon Glass
2016-05-17dm: mmc: Drop the get_dev() functionSimon Glass
2016-05-17dm: ide: Drop the get_dev() functionSimon Glass
2016-05-17dm: usb: Drop the get_dev() functionSimon Glass
2016-04-11disk: part: Enable get_info pointer for CONFIG_SPL_FAT_SUPPORTMichal Simek
The patch "dm: part: Convert partition API use to linker lists" (sha1: 96e5b03c8ab749b6547f6a3ceb4d4b9f274211aa) is adding new dependency for enabling SPL_EXT_SUPPORT to be able to get information about DOS partition. get_info is also required for FAT support only which is used on Xilinx Zynq boards. Reported-by: Nathan Rossi <nathan@nathanrossi.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-03-15disk/part.c: Expose list of available block driversAlexander Graf
We have a pretty nice and generic interface to ask for a specific block device. However, that one is still based around the magic notion that we know the driver name. In order to be able to write fully generic disk access code, expose the currently internal list to other source files so that they can scan through all available block drivers. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2016-03-14dm: part: Rename some partition functionsSimon Glass
Rename three partition functions so that they start with part_. This makes it clear what they relate to. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-03-14dm: part: Convert partition API use to linker listsSimon Glass
We can use linker lists instead of explicitly declaring each function. This makes the code shorter by avoiding switch() statements and lots of header file declarations. While this does clean up the code it introduces a few code issues with SPL. SPL never needs to print partition information since this all happens from commands. SPL mostly doesn't need to obtain information about a partition either, except in a few cases. Add these cases so that the code will be dropped from each partition driver when not needed. This avoids code bloat. I think this is still a win, since it is not a bad thing to be explicit about which features are used in SPL. But others may like to weigh in. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-03-14dm: blk: Rename get_device_and_partition()Simon Glass
Rename this function to blk_get_device_part_str(). This is a better name because it makes it clear that the function returns a block device and parses a string. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-03-14dm: blk: Rename get_device() to blk_get_device_by_str()Simon Glass
The current name is too generic. The function returns a block device based on a provided string. Rename it to aid searching and make its purpose clearer. Also add a few comments. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-03-14dm: blk: Rename get_dev() to blk_get_dev()Simon Glass
The current name is too generic. Add a 'blk_' prefix to aid searching and make its purpose clearer. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-03-14dm: blk: Add comments to a few functionsSimon Glass
The block interface is not well documented in the code. Pick two important functions and add comments. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-03-14dm: Add a new header for block devicesSimon Glass
At present block devices are tied up with partitions. But not all block devices have partitions within them. They are in fact separate concepts. Create a separate blk.h header file for block devices. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-03-14dm: part: Drop the common.h headerSimon Glass
We should not include <common.h> in header files. Each C file should include it if needed. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-03-14dm: Drop the block_dev_desc_t typedefSimon Glass
Use 'struct' instead of a typdef. Also since 'struct block_dev_desc' is long and causes 80-column violations, rename it to struct blk_desc. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-01-25part: Drop duplication declaration of block_dev_desc_tSimon Glass
This is already defined in ide.h, which part.h includes. So we don't need the duplicate typedef. At least with my old blackfin gcc 4.3.5 tool chain, this causes an error. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
2016-01-13mmc: store hwpart in the block deviceStephen Warren
This will allow us to have multiple block device structs each referring to the same eMMC device, yet different HW partitions. For now, there is still a single block device per eMMC device. As before, this block device always accesses whichever HW partition was most recently selected. Clients wishing to make use of multiple block devices referring to different HW partitions can simply take a copy of this block device once it points at the correct HW partition, and use each one as they wish. This feature will be used by the next patch. In the future, perhaps get_device() could be enhanced to return a dynamically allocated block device struct, to avoid the client needing to copy it in order to maintain multiple block devices. However, this would require all users to be updated to free those block device structs at some point, which is rather a large change. Most callers of mmc_switch_part() wish to permanently switch the default MMC block device's HW partition. Enhance mmc_switch_part() so that it does this. This removes the need for callers to do this. However, common/env_mmc.c needs to save and restore the current HW partition. Make it do this more explicitly. Replace use of mmc_switch_part() with mmc_select_hwpart() in order to remove duplicate code that skips the call if that HW partition is already selected. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-01-13block: pass block dev not num to read/write/erase()Stephen Warren
This will allow the implementation to make use of data in the block_dev structure beyond the base device number. This will be useful so that eMMC block devices can encompass the HW partition ID rather than treating this out-of-band. Equally, the existence of the priv field is crying out for this patch to exist. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-11-23gpt: part: Definition and declaration of GPT verification functionsLukasz Majewski
This commit provides definition and declaration of GPT verification functions - namely gpt_verify_headers() and gpt_verify_partitions(). The former is used to only check CRC32 of GPT's header and PTEs. The latter examines each partition entry and compare attributes such as: name, start offset and size with ones provided at '$partitions' env variable. Signed-off-by: Lukasz Majewski <l.majewski@majess.pl> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Przemyslaw Marczak <p.marczak@samsung.com>
2015-11-12gpt: add optional parameter type in gpt commandPatrick Delaunay
code under flag CONFIG_PARTITION_TYPE_GUID add parameter "type" to select partition type guid example of use with gpt command : partitions = uuid_disk=${uuid_gpt_disk}; \ name=boot,size=0x6bc00,uuid=${uuid_gpt_boot}; \ name=root,size=0x7538ba00,uuid=${uuid_gpt_root}, \ type=0fc63daf-8483-4772-8e79-3d69d8477de4; gpt write mmc 0 $partitions Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
2014-12-18fastboot: handle flash write to GPT partitionsSteve Rae
Implement a feature to allow fastboot to write the downloaded image to the space reserved for the Protective MBR and the Primary GUID Partition Table. Additionally, prepare and write the Backup GUID Partition Table. Signed-off-by: Steve Rae <srae@broadcom.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com> [Test HW: Exynos4412 - Trats2]
2014-06-05disk: part_efi: add get_partition_info_efi_by_name()Steve Rae
Add function to find a GPT table entry by name. Tested on little endian ARMv7 and ARMv8 configurations Signed-off-by: Steve Rae <srae@broadcom.com>
