path: root/include/power
2019-06-11regulator: bd71837: copy the bd71837 pmic driver from NXP imx u-bootMatti Vaittinen
https://source.codeaurora.org/external/imx/uboot-imx cherry picked, styled and merged commits: - MLK-18387 pmic: Add pmic driver for BD71837: e9a3bec2e95a - MLK-18590 pmic: bd71837: Change to use new fdt API: acdc5c297a96 Signed-off-by: Ye Li <ye.li@nxp.com> Signed-off-by: Matti Vaittinen <matti.vaittinen@fi.rohmeurope.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-04-12stpmic1: add NVM update support in fuse commandPatrick Delaunay
Add functions to read/update the non volatile memory of STPMIC1 (8 bytes-register at 0xF8 address) and allow access with fuse command (bank=1, word > 0xF8). For example: STM32MP> fuse read 1 0xf8 8 Reading bank 1: Word 0x000000f8: 000000ee 00000092 000000c0 00000002 Word 0x000000fc: 000000f2 00000080 00000002 00000033 Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2019-04-12stpmic1: update register namesPatrick Delaunay
Alignment with STPMIC1 datasheet s/MAIN_CONTROL_REG/MAIN_CR/g s/MASK_RESET_BUCK/BUCKS_MRST_CR/g s/MASK_RESET_LDOS/LDOS_MRST_CR/g s/BUCKX_CTRL_REG/BUCKX_MAIN_CR/g s/VREF_CTRL_REG/REFDDR_MAIN_CR/g s/LDOX_CTRL_REG/LDOX_MAIN_CR/g s/USB_CTRL_REG/BST_SW_CR/g s/STPMIC1_NVM_USER_STATUS_REG/STPMIC1_NVM_SR/g s/STPMIC1_NVM_USER_CONTROL_REG/STPMIC1_NVM_CR/g and update all the associated defines. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2019-04-12power: rename stpmu1 to official name stpmic1Patrick Delaunay
Alignment with kernel driver name & binding introduced by https://patchwork.kernel.org/cover/10761943/ to use the final marketing name = STPMIC1. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2019-04-12power: stpmu1: rename files to stpmic1Patrick Delaunay
Prepare file modification for kernel alignment and rename driver to stpmic1. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2019-03-11regulator: Add support for ramp delayKrzysztof Kozlowski
Changing voltage and enabling regulator might require delays so the regulator stabilizes at expected level. Add support for "regulator-ramp-delay" binding which can introduce required time to both enabling the regulator and to changing the voltage. Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org> Tested-by: Anand Moon <linux.amoon@gmail.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2019-02-09power: regulator: Introduce regulator_set_enable_if_allowed apiLokesh Vutla
regulator_set_enable() api throws an error in the following three cases: - when requested to disable an always-on regulator - when set_enable() ops not provided by regulator driver - when enabling is actually failed.(Error returned by the regulator driver) Sometimes consumer drivers doesn't want to track the first two scenarios and just need to worry about the case where enabling is actually failed. But it is also a good practice to have an error value returned in the first two cases. So introduce an api regulator_set_enable_if_allowed() which ignores the first two error cases and returns an error as given by regulator driver. Consumer drivers can use this api need not worry about the first two error conditions. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-12-10power: make most tps drivers and the twl4030 driver compatible with DM_I2CJean-Jacques Hiblot
Those driver are not DM drivers per se (not using the PMIC/regulator framework) and are using the legacy I2C API. Make them compatible with the DM_I2C API. This impacts the following drivers: - palmas (used by am57xx/dra7xx evms) - tps65218 (used by am43xx evms) - tps65217 and tps65910 (used by am335x evms and am335x boneblack vboot) - twl4030 (used by omap3_logicpd) - tps65217 (used by brppt1) - twl6030 Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2018-07-19power: regulator: stpmu1: add power off delayChristophe Kerello
This patch adds a delay when regulators are disabled. This delay is set to 5 ms to cover all use cases. The worst use case actually seen is during a SD card power cycle. Signed-off-by: Christophe Kerello <christophe.kerello@st.com> Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-06-27power: pmic: Let PFUZE3000 see all 256 registersTrent Piepho
The PFUZE3000 uses registers addresses up to 0xff. The DM pfuze100 driver supports both pfuze100 and pfuze3000. Allow it to use the device type to return the correct number of registers. Also rename the too generic PMIC_NUM_OF_REGS enumeration value for pfuze3000 to match the other "PFUZE3000_" prefixed enumerations and the pfuze100 enumeration value PFUZE100_NUM_OF_REGS. Cc: Peng Fan <Peng.Fan@freescale.com> Cc: Jaehoon Chung <jh80.chung@samsung.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Trent Piepho <tpiepho@impinj.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2018-05-18pmic: Add support for setting transmission length in uclass private dataLukasz Majewski
The struct uc_pmic_priv's trans_len field stores the number of types to be transmitted per PMIC transfer. Signed-off-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-05-10power: as3722: add as3722_ldo_set_voltage signature to header fileMarcel Ziswiler
Just like the already present as3722_sd_set_voltage() add the currently missing signature of the as3722_ldo_set_voltage() function to its header file. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2018-05-10power: as3722: fix ldo_get/set_enable for ldo index bigger than 7Marcel Ziswiler
Fix ldo_get_enable() and ldo_set_enable() functions for LDOs with an index > 7. Turns out there are actually two separate AS3722_LDO_CONTROL registers AS3722_LDO_CONTROL0 and AS3722_LDO_CONTROL1. Actually make use of both. While at it also actually use the enable parameter of the ldo_set_enable() function which now truly allows disabling as opposed to only enabling LDOs. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2018-05-07SPDX: Convert all of our multiple license tags to Linux Kernel styleTom Rini
When U-Boot started using SPDX tags we were among the early adopters and there weren't a lot of other examples to borrow from. So we picked the area of the file that usually had a full license text and replaced it with an appropriate SPDX-License-Identifier: entry. Since then, the Linux Kernel has adopted SPDX tags and they place it as the very first line in a file (except where shebangs are used, then it's second line) and with slightly different comment styles than us. In part due to community overlap, in part due to better tag visibility and in part for other minor reasons, switch over to that style. This commit changes all instances where we have multiple licenses (in these cases, dual license) declared in the SPDX-License-Identifier tag. In this case we change from listing "LICENSE-A LICENSE-B" or "LICENSE-A or LICENSE-B" or "(LICENSE-A OR LICENSE-B)" to "LICENSE-A OR LICENSE-B" as per the Linux Kernel style document. Note that parenthesis are allowed so when they were used before we continue to use them. Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2018-05-06board: ti: am43: Fix DCDC3 voltage for epos-evmKeerthy
A common voltage of 1.35V was being programmed for all am43 board versions. EPOS-EVM Needs 1.20V for LPDDR2. Fixes: fc69d472621b5 (“board: ti: AM43XX: Add ddr voltage rail configuration”) Reported-by: James Doublesin <doublesin@ti.com> Signed-off-by: Keerthy <j-keerthy@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-03-19pmic: add stpmu1 supportPatrick Delaunay
This driver implements register read/write operations for STPMU1. The STPMU1 PMIC provides 4 BUCKs, 6 LDOs, 1 VREF and 2 power switches. It is accessed via an I2C interface. This device is used with STM32MP1 SoCs. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2018-01-24power: regulator: s2mps11: add a regulator driver for s2mps11Jaehoon Chung
exynos5422 has the s2mps11 PMIC. s2mps11 pmic has the 10-BUCK and 38-LDO regulators. Each IP and devices in exynos5422 can be controlled by each regulators. This patch is support for s2mps11 regulator driver. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Anand Moon <linux.amoon@gmail.com>
2017-12-29power: pmic.h: include dm/ofnode.hPeng Fan
Include dm/ofnode.h. Signed-off-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org> Cc: Stefano Babic <sbabic@denx.de> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-12-12power: pmic/regulator: Add basic support for TPS65910Felix Brack
Texas Instrument's TPS65910 PMIC contains 3 buck DC-DC converts, one boost DC-DC converter and 8 LDOs. This patch implements driver model support for the TPS65910 PMIC and its regulators making the get/set API for regulator value/enable available. This patch depends on the patch "am33xx: Add a function to query MPU voltage in uV" to build correctly. For boards relying on the DT include file tps65910.dtsi the v3 patch "power: extend prefix match to regulator-name property" and an appropriate regulator naming is also required. Signed-off-by: Felix Brack <fb@ltec.ch> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-12-12power: extend prefix match to regulator-name propertyFelix Brack
This patch extends pmic_bind_children prefix matching. In addition to the node name the property regulator-name is used while trying to match prefixes. This allows assigning different drivers to regulator nodes named regulator@1 and regulator@10 for example. I have discarded the idea of using other properties then regulator-name as I do not see any benefit in using property compatible or even regulator-compatible. Of course I am open to change this if there are good reasons to do so. Signed-off-by: Felix Brack <fb@ltec.ch> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-01regulator: palmas: disable bypass when the LDO is enabledJean-Jacques Hiblot
Some LDOs have a bypass capability. Make sure that the bypass is disabled when is the LDO is enabled (otherwise the voltage can't be changed). Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Keerthy <j-keerthy@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-07-28dm: power: Convert as3722 to driver modelSimon Glass
Convert this PMIC driver to driver model and fix up other users. The regulator and GPIO functions are now handled by separate drivers. Update nyan-big to work correct. Three boards will need to be updated by the maintainers: apalis-tk1, cei-tk1-som. Also the TODO in the code re as3722_sd_set_voltage() needs to be completed. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <lukma@denx.de> Tested-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Tested-on: Jetson-TK1 Tested-by: Stephen Warren <swarren@nvidia.com>
2017-07-28power: Add a GPIO driver for the as3722 PMICSimon Glass
This pmic includes GPIOs which should have their own driver. Add a driver to support these. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <lukma@denx.de> Tested-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Tested-on: Beaver, Jetson-TK1 Tested-by: Stephen Warren <swarren@nvidia.com>
2017-07-28power: Add a regulator driver for the as3722 PMICSimon Glass
This pmic includes regulators which should have their own driver. Add a driver to support these. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <lukma@denx.de> Tested-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Tested-on: Beaver, Jetson-TK1 Tested-by: Stephen Warren <swarren@nvidia.com>
2017-07-19regulator: Change get_enable return type to integer from boolKeerthy
Change get_enable return type to int so errors can be returned. Signed-off-by: Keerthy <j-keerthy@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-11power: regulator: rk8xx: Allow input current/charger shutdown configurationWadim Egorov
The RK818 PMIC contains a charger. Add very basic charger functionality to be able to regulate the USB input current and charger shutdown limits. Signed-off-by: Wadim Egorov <w.egorov@phytec.de> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-06-09Fixup bug in PMIC TPS65217 register address definitionBrock Zheng Techyauld Ltd
The addresses of the registers in TI TPS65217 are not continuous. There is a gap between ENABLE(0x16) and DEFUVLO(0x18). No 0x17 register available. Fixup the enum values by adding a 'reserved' placeholder to correct the addresses higher than 0x17. Series-to: Heiko Schocher <hs@denx.de> Signed-off-by: Brock Zheng Techyauld Ltd <yzheng@techyauld.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2017-06-09power: pmic: lp87565: Add the basic pmic supportKeerthy
Add support to bind the regulators/child nodes with the pmic. Signed-off-by: Keerthy <j-keerthy@ti.com> Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
2017-06-09board: ti: AM43XX: Add ddr voltage rail configurationKeerthy
Add ddr voltage rail (dcdc3) configuration. Set the dcdc3 DDR supply to 1.35V. Signed-off-by: Keerthy <j-keerthy@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2017-06-01dm: pmic: Convert uclass to livetreeSimon Glass
Update the pmic uclass and all pmics to support a live device tree. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-29power: pmic: tps65218: Fix tps65218_voltage_update functionKeerthy
Currently while setting the vsel value for dcdc1 and dcdc2 the driver is wrongly masking the entire 8 bits in the process clearing PFM (bit7) field as well. Hence describe an appropriate mask for vsel field and modify only those bits in the vsel mask. Source: http://www.ti.com/lit/ds/symlink/tps65218.pdf Signed-off-by: Keerthy <j-keerthy@ti.com> Fixes: 86db550b38 ("power: Add support for the TPS65218 PMIC") Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2017-05-12arm: am33xx: Fix MPU opp selectionLokesh Vutla
Update MPU frequencies and voltages as per the latest DM[1] dated: OCT 2011 Revised APRIL 2016, Section 5.4. Below is the consolidated data: MPU values for PG 2.0 and later(Package ZCZ and ZCE): ------------------------------------------------------- | | ZCZ | ZCE | |-------------------------------------------------------| | | VDD[V] | ARM [MHz] | VDD[V] | ARM [MHz] | |-------|----------|------------|----------|------------| | NITRO | 1.325 | 1000 | NA | NA | |-------|----------|------------|----------|------------| | TURBO | 1.26 | 800 | NA | NA | |-------|----------|------------|----------|------------| |OPP120 | 1.20 | 720 | NA | NA | |-------|----------|------------|----------|------------| |OPP100 | 1.10 | 600 | 1.10 | 600 | |-------|----------|------------|----------|------------| | OPP50 | 0.95 | 300 | 0.95 | 300 | ------------------------------------------------------- There is no eFuse blown on PG1.0 Silicons due to which there is no way to detect the maximum frequencies supported. So default to OPP100 for which both frequency and voltages are common on both the packages. [1] http://www.ti.com/lit/ds/symlink/am3356.pdf Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-05-10power: rk808: rename to rk8xxJacob Chen
Since this driver can be used for rk8xx series pmic, let's rename rk808 to rk8xx, to make it clear. Configs parts are done by sed -i "s/RK808/RK8XX/g" `grep RK808 -lr ./` Signed-off-by: Jacob Chen <jacob-chen@iotwrt.com>
2017-05-10power: pmic: rk808: add RK818 supportJacob Chen
The RK818 chip is a Power Management IC (PMIC) for multimedia and handheld devices. For boards use rk818, the input current should be set in the early stage, before ddr initialization. Signed-off-by: Jacob Chen <jacob-chen@iotwrt.com>
2017-05-10power: pmic: append rk818 regs to rk808Jacob Chen
Both RK808 and RK818 chips are using a similar register map, so we can reuse them. I have also add reg prefix to exist registers, to keep them same style. Signed-off-by: Jacob Chen <jacob-chen@iotwrt.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-01-18pmic: pmic_mc34vr500: Add APIs to set/get SWx voltHou Zhiqiang
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-18pmic: pmic_mc34vr500: Add a driver for the mc34vr500 pmicHou Zhiqiang
This patch adds a simple pmic driver for the mc34vr500 pmic which is used in conjunction with the fsl T1 and LS1 series SoC. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-12-16power: pmic: Add Voltage configuration macroBreno Lima
Add pfuze3000 voltage configuration macro for SW1AB, SW3 and VLDO1/2 according to tables 53, 57 and 62 on PF3000 datasheet. Signed-off-by: Breno Lima <breno.lima@nxp.com>
2016-11-25power: regulator: Introduce regulator_set_value_force functionKeerthy
In case we want to force a particular value on a regulator irrespective of the min/max constraints for testing purposes one can call regulator_set_value_force function. Signed-off-by: Keerthy <j-keerthy@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-11power: pmic: lp873x: Add the base pmic supportKeerthy
Add support to bind the regulators/child nodes with the pmic. Signed-off-by: Keerthy <j-keerthy@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-11power: pmic: Palmas: Add the base pmic supportKeerthy
Add support to bind the regulators/child nodes with the pmic. Also adds the pmic i2c based read/write funtions to access pmic registers. Signed-off-by: Keerthy <j-keerthy@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-11power: regulator: Add ctrl_reg and volt_reg fields for pmicKeerthy
The ctrl reg contains bit fields to enable and disable regulators, and volt_reg has the bit fields to configure the voltage values. The registers are frequently accessed hence make them part of dm_regulator_uclass_platdata structure. Signed-off-by: Keerthy <j-keerthy@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-11power: regulator: Add support for gpio regulatorsKeerthy
Add support for gpio regulators. As of now this driver caters to gpio regulators with one gpio. Supports setting voltage values to gpio regulators and retrieving the values. Signed-off-by: Keerthy <j-keerthy@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-07power: pmic: add Ricoh RN5T567 PMIC supportStefan Agner
Add device model enabled PMIC driver for Ricoh RN5T567 PMIC used on Colibri iMX7. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-07-27dm: Convert users from dm_scan_fdt_node() to dm_scan_fdt_dev()Simon Glass
This new function is more convenient for callers, and handles pre-relocation situations automatically. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-06-09power, tps65217: add some definesHeiko Schocher
add the following defines, needed for the upcoming shc board support: Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-02-24pmic: tps65218: add useful functions and definesNikita Kiryanov
Add the following functions: tps65218_reg_read() for accessing redisters tps65218_toggle_fseal() for toggling the fseal bit tps65218_lock_fsea() for locking the fseal bit to 1 Add the following defines: All status register bits Cc: Tom Rini <trini@konsulko.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-01-21power: Add base support for the RK808 PMICSimon Glass
This Rockchip PMIC provides features suitable for battery-powered applications. It is commonly used with Rockchip SoCs. Add a driver which provides register access. The regulator driver will use this. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-13power: pmic.h: Drop include <spi.h>Jagan Teki
include/power/pmic.h never used any generic spi code from include/spi.h, but this has been added in below commit. "dm: pmic: add implementation of driver model pmic uclass" (sha1: 4d9057e82be11a862db411c4867e859fe0d4ca2a) Adding functionalities in include/spi.h will trigger a build issue as this been added used in include/power/pmic.h Build issue on trats2 with adding BIT macro on spi.h: ---------------------------------------------------- CC lib/asm-offsets.s In file included from include/power/pmic.h:15:0, from include/power/max77686_pmic.h:11, from include/configs/trats2.h:212, from include/config.h:5, from include/common.h:18, from lib/asm-offsets.c:15: include/spi.h: In function 'spi_w8r8': include/spi.h:327:2: warning: implicit declaration of function 'BIT' [-Wimplicit-function-declaration] Cc: Simon Glass <sjg@chromium.org> Cc: Przemyslaw Marczak <p.marczak@samsung.com> Reported-by: Tom Rini <trini@konsulko.com> Signed-off-by: Jagan Teki <jteki@openedev.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Simon Glass <sjg@chromium.org>
