path: root/include/ps2mult.h
2009-04-03Rename common ns16550 constants with UART_ prefix to prevent conflictsDetlev Zundel
Fix problems introduced in commit 7b5611cdd12ca0cc33f994f0d4a4454788fc3124 [inka4x0: Add hardware diagnosis functions for inka4x0] which redefined MSR_RI which is already used on PowerPC systems. Also eliminate redundant definitions in ps2mult.h. More cleanup will be needed for other redundant occurrences though. Signed-off-by: Detlev Zundel <dzu@denx.de>
2004-01-16[Strange. I _did_ check these in before. Seems SF restored an oldwdenk
version of the repository???] * Patch by Reinhard Meyer, 09 Jan 2004: - add RTC support for MPC5200 based boards (requires RTC_XTAL) * Add support for IDE LED on BMS2003 board (exclusive with status LED!) * Add support for PS/2 keyboard (used with PS/2 multiplexor on BMS2003 board) * Patches by Reinhard Meyer, 4 Jan 2004 + 7 Jan 2004: Add common files for "emk" boards
