path: root/include/usb_ether.h
2016-01-23usb: eth: add Realtek RTL8152B/RTL8153 DRIVERTed Chen
This patch adds driver support for the Realtek RTL8152B/RTL8153 USB network adapters. Signed-off-by: Ted Chen <tedchen at realtek.com> [swarren, fixed a few compiler warnings] [swarren, with permission, converted license header to SPDX] [swarren, removed printf() spew during probe()] Signed-off-by: Stephen Warren <swarren at nvidia.com>
2015-07-21dm: usb: eth: Support driver model with USB EthernetSimon Glass
At present USB Ethernet does not work with CONFIG_DM_ETH. Add driver model support to this feature, so that it can work alongside other Ethernet devices with driver model. It was found that quite a bit of code is common in most of the USB Ethernet drivers. Add this code to the common layer to reduce the amount of duplicate code needed in USB Ethernet drivers when CONFIG_DM_ETH is used. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-03-24net: Add ethernet FCS length macro in net.hBin Meng
Some ethernet drivers use their own version of ethernet FCS length macro which is really common. We define ETH_FCS_LEN in net.h and replace those custom versions in various places. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2014-12-31usb: eth: add ASIX AX88179 DRIVERRene Griessl
This patch adds driver support for the ASIX AX88179 USB3.0 to GbE network adapter. Driver has been tested on the RECS5250 COM module (similar to ARDALE5250). Testcase was DHCP and PXE boot. Signed-off-by: Rene Griessl <rgriessl@cit-ec.uni-bielefeld.de>
2014-03-12usb: net: introduce support for Moschip USB ethernetGerhard Sittig
introduce an 'mcs7830' driver for Moschip MCS7830 based (7730/7830/7832) USB 2.0 Ethernet Devices see "MCS7830 -- USB 2.0 to 10/100M Fast Ethernet Controller" at http://www.asix.com.tw/products.php?op=pItemdetail&PItemID=109;74;109 the driver was implemented based on the U-Boot Asix driver with additional information gathered from the Moschip Linux driver, development was done on "Delock 61147" and "Logilink UA0025C" dongles Signed-off-by: Gerhard Sittig <gsi@denx.de> Acked-by: Marek Vasut <marex@denx.de>
2014-03-12usb: net: don't ifdef routine declarations in usb_ether.hGerhard Sittig
while compilation of implemented routines and references from calling sites may be optional, declarations in header files should not be unconditionally declare the Asix and SMSC related public USB ethernet driver routines in the usb_ether.h header file Signed-off-by: Gerhard Sittig <gsi@denx.de> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Marek Vasut <marex@denx.de>
2012-09-26net: introduce transparent driver private in ueth_dataLucas Stach
Avoid clutter in ueth_data. Individual drivers should not mess with structures belonging to the core like this. Signed-off-by: Lucas Stach <dev@lynxeye.de> Reviewed-by: Marek Vasut <marex@denx.de> Acked-by: Marek Vasut <marex@denx.de> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2011-08-08Add support for SMSC95XX USB 2.0 10/100MBit Ethernet AdapterSimon Glass
The SMSC95XX is a USB hub with a built-in Ethernet adapter. This adds support for this, using the USB host network framework. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Eric BĂ©nard <eric@eukrea.com>
2011-02-19Add support for ASIX AX88772 USB 2.0 10/100Mbit Ethernet AdaptorSimon Glass
Driver originally written by NVIDIA Corporation, modified to handle odd-length packets. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-02-19Add USB host ethernet adapter supportSimon Glass
This adds support for using USB Ethernet dongles in host mode. This is just the framework - drivers will come later. A new config option called CONFIG_USB_HOST_ETHER can be defined in board config files to switch this on. The was originally written by NVIDIA and was cleaned up for release by the Chromium authors. Signed-off-by: Simon Glass <sjg@chromium.org>
