path: root/include/vxworks.h
2015-10-21cmd: bootvx: Pass E820 information to an x86 VxWorks kernelBin Meng
E820 is critical to the kernel as it provides system memory map information. Pass it to an x86 VxWorks kernel. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Tested-by: Jian Luo <jian.luo4@boschrexroth.de>
2015-10-21cmd: bootvx: Always get VxWorks bootline from envBin Meng
So far VxWorks bootline can be contructed from various environment variables, but when these variables do not exist we get these from corresponding config macros. This is not helpful as it requires rebuilding U-Boot, and to make sure these config macros take effect we should not have these environment variables. This is a little bit complex and confusing. Now we change the logic to always contruct the bootline from environments (the only single source), by adding two new variables "bootdev" and "othbootargs", and adding some comments about network related settings mentioning they are optional. The doc about the bootline handling is also updated. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> Tested-by: Hannes Schmelzer <oe5hpm@oevsv.at>
2013-12-16common/cmd_bootm: extend do_bootm_vxworks to support the new VxWorks boot ↵Miao Yan
interface. The next version VxWorks adopts device tree (for PowerPC and ARM) as its hardware description mechanism. For PowerPC, the boot interface conforms to the ePAPR standard, which is: void (*kernel_entry)(ulong fdt_addr, ulong r4 /* 0 */, ulong r5 /* 0 */, ulong r6 /* EPAPR_MAGIC */, ulong r7 /* IMA size */, ulong r8 /* 0 */, ulong r9 /* 0 */) For ARM, the boot interface is: void (*kernel_entry)(void *fdt_addr) Signed-off-by: Miao Yan <miao.yan@windriver.com> [trini: Fix build error when !CONFIG_OF_FDT is set, typo on PowerPC, missing extern ft_fixup_num_cores] Signed-off-by: Tom Rini <trini@ti.com>
2012-10-15ppc4xx: Remove IOP480 supportStefan Roese
Since the IOP480 (PPC401/3 variant from PLX) is only used on 2 boards that are not actively maintained, lets remove support for it completely. This way the ppc4xx code will get a bit cleaner. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu> Acked-by: Marek Vasut <marex@denx.de>
2008-12-09vxworks.h: Fix build problem introduced by commits 29a4c24d/e9084b23Wolfgang Denk
2008-12-07Add vxworks.h to handle CONFIG_SYS_VXWORKS parametersNiklaus Giger
Signed-off-by: Niklaus Giger <niklaus.giger@member.fsf.org>
