The 405EZ only supports 512 bytes of rx-/tx-fifo EMAC sizes. But
currently 4k/2k is configured. This patch fixes this issue.
Thanks to Thomas Kindler <tkindler@lenord.de> for pointing this out.
Adds PCI support for MPC5121
Tested with drivers/net/rtl8139.c
Support is conditional since PCI on old silicon does not work.
ads5121_PCI_config turns on PCI
In this version, condition compilation of PCI code has been moved
from ifdef in board/ads5121/pci.c to board/ads5121/Makefile as
suggested by Jean-Christophe PLAGNIOL-VILLARD
Signed-off-by: John Rigby <jrigby@freescale.com>
Sync register definitions with linux
targets.
The previous patch was lacking of i386, microblaze, nios and nios2. This
patch tries to fix them.
Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
targets.
Olaf Hering [Wed, 17 Oct 2007 06:27:13 +0000 (23:27 -0700)]
Remove the __STRICT_ANSI__ check from the __u64/__s64 declaration on
32bit targets.
GCC can be made to warn about usage of long long types with ISO C90
(-ansi), but only with -pedantic. You can write this in a way that even
then it doesn't cause warnings, namely by:
#ifdef __GNUC__
__extension__ typedef __signed__ long long __s64;
__extension__ typedef unsigned long long __u64;
#endif
The __extension__ keyword in front of this switches off any pedantic
warnings for this expression.
Signed-off-by: Olaf Hering <olh@suse.de>
Cc: <linux-arch@vger.kernel.org>
The Linux commit fac8b209b1084bc85748bd54e13d00c1262b220f ("Remove
final traces of long-deprecated "ramdisk" kernel parm") makes these
changes neccessary.
Signed-off-by: Detlev Zundel <dzu@denx.de>
Some boards (e.g. lwmon5) may use rather small watchdog intervals, so
causing it to reboot the board if U-Boot does a long busy-wait with
udelay(). Thus, for these boards we have to restart WD more
frequently.
This patch splits the busy-wait udelay() into smaller, predefined,
intervals, so that the watchdog timer may be resetted with the
configurable (CONFIG_WD_PERIOD) interval.
Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
Adds configuration option for ATI Radeon 9200 card
support to sequoia config file. If CONFIG_VIDEO
is enabled, TEXT_BASE should be changed to 0xFFF80000.
A few duplicate of the ARRAY_SIZE macro sneaked in since we put
the define in common.h.
Signed-off-by: Rafal Jaworowski <raj@semihalf.com>
Back in commit 975a083a5ef785c414b35f9c5b8ae25b26b41524 where
I tried to "8610HPCD: Fix typos in two PCI setup registers", I
botched it due to not realizing that 8610 and 8641 had different
Global Utility Register defintions, one of which was like 85xx,
and the other wasn't. Correct this problem by introducing two
symbols, one for each 86xx SoC, but neither of which is named
anything like 85xx.
My bad. Lovely Wednesday with git bisect. You know.
Without an actual supported video card hooked up, enabling
the CONFIG_VIDEO by default just makes it look broken by
routing all console output to the video card. Don't.
The two symbols MPC86xx_PORDEVSR_IO_SEL and MPC86xx_PORBMSR_HA
were erroneously present as 85xx names and values, leftover from
the clone wars. Fix this by removing the 85xx cruft from the
86xx codebase.
This is the proper fix for a missing closing brace in the function
ft_cpu_setup() noticed by joe.hamman <at> embeddedspecialties.com.
The ft_cpu_setup() function in mpc8641hpcn.c should have been
removed earlier as it was under the obsolete CONFIG_OF_FLAT_TREE,
but was missed. Only, the sbc8641d was nominally still using it.
It all got ripped out, and the funcality that was in ft_board_setup()
was refactored to remove the CPU portions into the new file
cpu/mpc86xx/fdt.c instead. Make sbc8641d use this now.
Based loosely on an original patch from joe.hamman@embeddedspecialties.com
- hcu4.h: Removed define of CONFIG_PPC405GPr
- Corrected phy addresses
- Fix boot variables
- Respect line length of 80 chars
Signed-off-by: Niklaus Giger <niklaus.giger@netstal.com>
Signed-off-by: Larry Johnson <lrj@acm.org>
Adds ATI Radeon 9200 support for 1280x1024, 1024x768,
800x600, 640x480 at 24, 16 and 8 bpp.
common/cmd_reginfo.c
Makefile
doc/README.standalone
The address of SH7722 is wrong by old document.
This patch fixes this problem.
Update global_data to define i2c1_clk and i2c2_clk to 85xx and 86xx.
Update the get_clocks() function in 85xx and 86xx to determine the I2C
clock frequency and store it in gd->i2c1_clk and gd->i2c2_clk.
Get board name consistent with Linux and elsewhere;
get rid of local network definitions etc.
R29 was an unlucky choice as with recent toolchains (gcc-4.2.x) gcc
will refuse to use load/store multiple insns; instead, it issues a
list of simple load/store instructions upon function entry and exit,
resulting in bigger code size, which in turn makes the build for a
few boards fail.
Use r2 instead.
Kimmo Leppala / Sysart and
Timo Tuunainen / Sysart
Signed-off-by: Stelian Pop <stelian@popies.net>
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
update comments
Fix coding style
These replace direct structure references for IMMR sections.
