path: root/include
2017-10-03apalis-tk1: support v1.2 hardware revisionColibri-iMX7_LXDE-Image_2.7b4-20171005Colibri-iMX6_LXDE-Image_2.7b4-20171005Colibri-VF_LXDE-Image_2.7b4-20171005Colibri-T30_LXDE-Image_2.7b4-20171005Colibri-T20_LXDE-Image_2.7b4-20171005Apalis-iMX6_LXDE-Image_2.7b4-20171005Apalis-TK1_LXDE-Image_2.7b4-20171007Apalis-TK1-Mainline_LXDE-Image_2.7b4-20171005Apalis-T30_LXDE-Image_2.7b4-20171005Marcel Ziswiler
Support the V1.2 hardware revision with the following pin muxing changes: Ddc_scl_pv4 and ddc_sda_pv5 previously used as Apalis GPIO3 and GPIO4 are now used as DDC pins. Gen2_i2c_scl_pt5 and gen2_i2c_sda_pt6 previously used as DDC pins are now used as USB power enable signals. Usb_vbus_en0_pn4 and usb_vbus_en1_pn5 previously used as USB power enable signals are now used as GPIO3 and GPIO4. Additionally a new device tree file tegra124-apalis-v1.2-eval.dtb is loaded on V1.2 and later modules and resp. USB power enable signals activated. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-10-03colibri-imx6ull.h: unify with changes in colibri_imx7.hMax Krummenacher
Remove m4boot options not available on i.MX 6ULL. Cleanup U-Boot environment settings. This undefs CONFIG_ISO_PARTITION. This removes NAND torture no longer needed after bringup. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-10-03colibri-imx6ull.h: cleanup whitespaceMax Krummenacher
Cleanup whitespace and unify order with colibri_imx7.h. No functional change intended. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-10-03colibri-imx6ull.h: remove unused configsMax Krummenacher
Remove/change two NAND releated configs. They are not used in the GPMI driver and likely confuse readers. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-10-02colibri_imx7_emmc: legacy sdboot from external sd cardMarcel Ziswiler
Just like the following commit for distro boot also use the 2nd instance for legacy sdboot: colibri_imx7_emmc: distro boot from external SD card 93ef92091832128259ab342a314d0f3e844bb331 Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-10-02apalis/colibri_imx6: fix white spaceMarcel Ziswiler
2017-10-02apalis-tk1/colibri_t20: fix and synchronize mount options 2ndMarcel Ziswiler
Finish the work started by the following commit: apalis/colibri: fix and synchronize mount options 6ed47e0f143df1c80426edb3b705c87c443c27f7 Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-10-02colibri_imx7_emmc: distro boot from external SD cardStefan Agner
Currently distro boot is only used for external media. Use mmc 1 which is the external SD card when booting using distro boot. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-10-02colibri_imx7_emmc: fix environment storageMarcel Ziswiler
Store U-Boot environment in eMMC, before config block at the end of 1st "boot sector". Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-10-02colibri_imx7_emmc: fix boot commandsMarcel Ziswiler
Use proper emmc specific device tree and boot from eMMC by default rather than from NAND aka ubi. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-10-02colibri_imx7_emmc: clean-up config header fileMarcel Ziswiler
Clean-up config header file. Re-order boot commands. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-10-02colibri_imx7: get rid of environment in mmc optionMarcel Ziswiler
2017-10-02colibri_imx7: clean-up config header fileMarcel Ziswiler
2017-10-02apalis/colibri: fix and synchronize mount optionsStefan Agner
The kernel does not know about rw,noatime. The string rw by itself is valid, and to pass additional arguments rootflags=noatime can be used. The kernel mounts ext3/ext4 file systems by default ro, hence so far the kernel mounted the rootfs read-only. The init manager systemd then remounts the rootfs after file system checking. This makes sense and does not add measureable boot time. Let the kernel explicitly mount ro on block device based rootfs. The root mount flag noatime is only relevant when re-mounting read-write, hence it needs to be present in /etc/fstab. UBIFS used on raw NAND devices has no user space file checking, hence there is no value to mount it in read-only first. Also mount time for UBIFS is larger, and mounting first read-only and then read-write has higher boot time (300ms, likely due to missing block cache). Let the kernel explicitly mount rw on raw NAND based rootfs. UBIFS has no atime support, hence no root mount flags needed. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-08-31colibri_imx7_emmc: add Colibri iMX7 Dual 1GB (eMMC) supportStefan Agner
This adds support for Colibri iMX7 Dual 1GB modules which come with on-board eMMC storage (whereas the other Colibri iMX7 modules use raw NAND). A subselection (variant) for the Colibri iMX7 target is used to maximize sharing. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-08-31toradex: remove ISO partition supportStefan Agner
The ISO partition support is mainly useful for CD drives which are not really common in embedded space and in general anymore. Removing ISO partition support saves 1.5kB and gets rid of the somewhat confusing message when no partition table is present: ** First descriptor is NOT a primary desc on 0:1 ** Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-08-31colibri-imx6ull: add initialMax Krummenacher
The resulting U-Boot boots at least from serial downloader mode. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-08-31colibri_imx7: remove unused config optionMax Krummenacher
CONFIG_SYS_NAND_MX7_GPMI_62_ECC_BYTES is no longer used in code. Remove it. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-08-31colibri_imx7.h: do not deploy nand torture cmdMax Krummenacher
The nand torture command is a potentially destructive command used for board bring up and qualification. Do not deploy it regularly. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-08-31net: Use packed structures for networkingDenis Pynkin
PXE boot is broken with GCC 7.1 due option '-fstore-merging' enabled by default for '-O2': BOOTP broadcast 1 data abort pc : [<8ff8bb30>] lr : [<00004f1f>] reloc pc : [<17832b30>] lr : [<878abf1f>] sp : 8f558bc0 ip : 00000000 fp : 8ffef5a4 r10: 8ffed248 r9 : 8f558ee0 r8 : 8ffef594 r7 : 0000000e r6 : 8ffed700 r5 : 00000000 r4 : 8ffed74e r3 : 00060101 r2 : 8ffed230 r1 : 8ffed706 r0 : 00000ddd Flags: nzcv IRQs off FIQs off Mode SVC_32 Resetting CPU ... Core reason is usage of structures for network headers without packed attribute. Reviewed-by: Yauheni Kaliuta <yauheni.kaliuta@redhat.com> Signed-off-by: Denis Pynkin <denis.pynkin@collabora.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> (cherry picked from commit 704f3acfcf55343043bbed01c5fb0a0094a68e8a) Conflicts: include/net.h upstream changed magic numbers with define Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-08-31configs: apalis-tk1: Use ext4 file system by defaultSanchayan Maity
Use ext4 file system by default. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-08-31apalis_t30: fix optional pcie port reset for reliable pcie operationMarcel Ziswiler
Allow optionally bringing up the Apalis type specific 4 lane PCIe port as well as the PCIe switch as found on the Apalis Evaluation board. In order to avoid violating the PCIe reset timing do this by overriding the tegra_pcie_board_port_reset() function. Note however that both the Apalis type specific 4 lane PCIe port as well as the regular Apalis PCIe port are also left disabled in the device tree by default. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2017-08-31pci: tegra: introduce weak tegra_pcie_board_port_reset() functionMarcel Ziswiler
Introduce a weak tegra_pcie_board_port_reset() function by default calling the existing tegra_pcie_port_reset() function. Additionally add a tegra_pcie_port_index_of_port() function to retrieve the specific PCIe port index if required. This allows overriding the PCIe port reset functionality from board specific code as e.g. required for Apalis T30 and Apalis TK1. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Stephen Warren <swarren@nvidia.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2017-09-01configs: apalis_imx6: Use ext4 file system by defaultSanchayan Maity
Use ext4 file system by default. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-09-01configs: colibri_imx6: Use ext4 file system by defaultSanchayan Maity
2017-06-18colibri_imx7: set default vidargs to VGA resolutionColibri-iMX7_LXDE-Image_2.7b3-20170630Colibri-iMX6_LXDE-Image_2.7b3-20170630Colibri-VF_LXDE-Image_2.7b3-20170630Colibri-T30_LXDE-Image_2.7b3-20170630Colibri-T20_LXDE-Image_2.7b3-20170630Apalis-iMX6_LXDE-Image_2.7b3-20170630Apalis-TK1_LXDE-Image_2.7b3-20170630Apalis-T30_LXDE-Image_2.7b3-20170630Bhuvanchandra DV
Set vidargs default to VGA resolution Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-06-18configs: apalis-tk1: fix boot failure using ext4 rootfsSanchayan Maity
Trying to boot from an ext4 rootfs fails due to us defaulting to ext3. While the downstream T20/T30 L4T kernel has issues with ext4 later TK1 L4T should work just fine with it. Hence enable ext4 for sdboot and usbboot on TK1. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-06-05colibri_imx7: enable bad block table in U-BootStefan Agner
Use the same on-flash bad block table in U-Boot as we already use/maintain in Linux. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Brandon Shibley <brandon.shibley@toradex.com>
2017-05-29apalis/colibri_t30: improve vdd core pmic handlingMarcel Ziswiler
Make sure TPS62362 set 0 defaults to 1.200V as the Linux kernel may switch to set 0 using TPS65911 GPIO1 (EN_CORE_DVFS_N) connected to TPS62362 VSEL1 prior to actually setting it to a sane value dependent on the current CPU frequency. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2017-03-30ARM: vf610: move to standard arch/board approachStefan Agner
Move Freescale/NXP Vybrid to a standard arch/board approach, similar to what has been done to i.MX 6 earlier in commit 89ebc82137be ("ARM: mx6: move to a standard arch/board approach"). Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-03-30colibri_imx7: use device-tree for MTD partitionsStefan Agner
Use device-tree fixup to communicate the MTD partitions to the kernel. Remove mtdparts from the kernel command line. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-01-18imx: move imximage header to common locationStefan Agner
Move the imximage.h header file to a common location so we can make use of it from U-Boot too. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-18usb: gadget: add SDP driverStefan Agner
Add SDP (Serial Downloader Protocol) implementation for U-Boot. The protocol is used in NXP SoCs boot ROM and allows to download program images. Beside that, it can also be used to read/write registers and download complete Device Configuration Data (DCD) sets. Currently, this implementation only supports downloading images and reading registers. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11apalis_imx6: use both sd/mmc interfaces for setsdupdateMax Krummenacher
During porting to 2016.11 the check of a SD (mmc2) interface was dropped, this was unintended. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-01-11colibri_vf: disable UBIFS support by defaultStefan Agner
U-Boot has grown to big with the enablement of FIT image. Since we boot from a separate UBI volume, U-Boot does not need access to the UBIFS. Also fix the maximum size, also consider the text base offset in gfxRAM. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11apalis/colibri t20/t30/tk1: distro boot integrationMarcel Ziswiler
Rather than relying on our separate proprietary storage media dependent boot commands use regular distro boot as a fall back. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11apalis_t30: add optional pcie evalboard initialisationMarcel Ziswiler
Implement optional PCIe EvalBoard initialisation which properly reset the PLX (now Avago) PEX 8605 PCIe switch plus PCIe devices on the Apalis Evaluation carrier board. Please note that you will have to enable the second PCIe port in the dts as well e.g.: diff --git a/arch/arm/dts/tegra30-apalis.dts b/arch/arm/dts/tegra30-apalis.dts index be4f4d6..321c7d6 100644 --- a/arch/arm/dts/tegra30-apalis.dts +++ b/arch/arm/dts/tegra30-apalis.dts @@ -59,6 +59,7 @@ }; pci@2,0 { + status = "okay"; nvidia,num-lanes = <1>; }; Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com> (cherry picked from commit 340f51a210df1da640a57267e6c7fa56b8a852ed)
2017-01-11apalis/colibri_t30: vdd core pmic handlingMarcel Ziswiler
Just release TPS65911 GPIO1 (EN_CORE_DVFS_N) connected to TPS62362 VSEL1 to switch VDD_CORE back to boot set 1 defaulting to 1.200V. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com> (cherry picked from commit 622d408fea7af6d2ed778b546de346e90ea1a21f)
2017-01-11colibri_t20: implement early pmic rail configurationMarcel Ziswiler
Implement early TPS6586X PMIC rail configuration setting SM0 being VDD_CORE_1.2V to 1.2 volts and SM1 being VDD_CPU_1.0V to 1.0 volts. While those are PMIC power-up defaults the SoC might have been reset separately with certain rails being left at lower DVFS states which is e.g. the case upon watchdog reset while otherwise nearly idling. (cherry picked from commit f7c3186985ebb244d075b04ed7c055f39f485670)
2017-01-11apalis_t30: enable display driverMarcel Ziswiler
Enable the display driver on Apalis T30. Unfortunately the PWM pin muxing wasn't any good neither which made that display stay dark. (cherry picked from commit 2da21c1d130fa11a5bd9876c8e72fa0d57585106)
2017-01-11colibri_t30: enable display driverMarcel Ziswiler
On popular request enable the display driver on Colibri T30. A few notes about some things encountered during porting: While analogue VGA (e.g. via the on-carrier RAMDAC) worked just fine from the beginning the EDT display flickered like crazy which turned out to be a pin muxing issue. Unfortunately the PWM pin muxing wasn't any good neither which made that display stay dark. Enjoy. (cherry picked from commit 201cc6d4e4c8213fbd103e74b0f2f2ca591edf54)
2017-01-11tegra: lcd: video: integrate display driver for t30Marcel Ziswiler
On popular request make the display driver from T20 work on T30 as well. Turned out to be quite straight forward. However a few notes about some things encountered during porting: Of course the T30 device tree was completely missing host1x as well as PWM support but it turns out this can simply be copied from T20. The only trouble compiling the Tegra video driver for T30 had to do with some hard-coded PWM pin muxing for T20 which is quite ugly anyway. On T30 this gets handled by a board specific complete pin muxing table. The older Chromium U-Boot 2011.06 which to my knowledge was the only prior attempt at enabling a display driver for T30 for whatever reason got some clocking stuff mixed up. Turns out at least for a single display controller T20 and T30 can be clocked quite similar. Enjoy. (cherry picked from commit 5a472ddd7a2a017747d6c05c65eba2cd3804c02f)
2017-01-11colibri_t20: migrateMarcel Ziswiler
Migrate Colibri T20 to U-Boot 2016.11. (cherry picked from commit 92d747bf338ceb8d6dbdd3e5e5f7f72226ce0792)
2017-01-11apalis/colibri_t30: migrateMarcel Ziswiler
Migrate Apalis/Colibri T30 to U-Boot 2016.11. (cherry picked from commit 81a38df0631cfa6b3a85c97e631abf73dc0a2226)
2017-01-11Revert "dm: tegra: Enable driver model for serial"Marcel Ziswiler
Migrating our BSPs towards mainline U-Boot I noticed it suddenly booting slower. With mainline Linux I noticed about a 1 to 2 second increase while booting downstream L4T takes 10 to 15 seconds longer! This reverts commit 858530a8c0a7ce7e573e513934804a00d6676813. Conflicts: drivers/serial/Makefile (cherry picked from commit 752aae30a791326581efafbb761c0cebaba8d3ea) Conflicts: drivers/serial/serial_tegra.c include/configs/tegra-common.h (cherry picked from commit 4b97c4173ef96cfa4eb3ba4ea9121320efa90091)
2017-01-11colibri_imx7: disable usb start when using distroboot DHCPStefan Agner
There is no need to enumerate USB when trying to boot using DHCP. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11colibri_vf: synchronize environmentStefan Agner
Synchronize environment with current layout, order variables by name. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11colibri_imx7/vf: set fdtfile for distrobootStefan Agner
Set fdtfile to represent the current board. This allows distribution to load the correct device tree, which in the module case often deviates from the common fallback ${soc}-${board}${boardver}.dtb... Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11colibri_vf/imx7: add distroboot supportStefan Agner
Add support for distro boot. This is especially helpful for external devices. There is a global boot command which scans a predefined list of boot targets: run distro_bootcmd As well as direct boot commands such as: run bootcmd_mmc0 run bootcmd_usb run bootcmd_dhcp ... Refer to doc/README.distro fo details. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11apalis/colibri_imx6: add distroboot supportStefan Agner
Add support for distro boot. This is especially helpful for external devices. There is a global boot command which scans a predefined list of boot targets: run distro_bootcmd As well as direct boot commands such as: run bootcmd_mmc1 run bootcmd_mmc2 run bootcmd_usb run bootcmd_dhcp ... Refer to doc/README.distro fo details. While at it, remove the CONFIG_DRIVE_TYPES define which has not been used and was meant to be used for multi device boot support which is now provided by distroboot. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
