During porting to 2016.11 the check of a SD (mmc2) interface
was dropped, this was unintended.
U-Boot has grown to big with the enablement of FIT image. Since we
boot from a separate UBI volume, U-Boot does not need access to the
UBIFS. Also fix the maximum size, also consider the text base offset
in gfxRAM.
Rather than relying on our separate proprietary storage media dependent
boot commands use regular distro boot as a fall back.
Implement optional PCIe EvalBoard initialisation which properly reset the PLX
(now Avago) PEX 8605 PCIe switch plus PCIe devices on the Apalis Evaluation
carrier board.
Please note that you will have to enable the second PCIe port in the dts as well
e.g.:
diff --git a/arch/arm/dts/tegra30-apalis.dts b/arch/arm/dts/tegra30-apalis.dts
index be4f4d6..321c7d6 100644
--- a/arch/arm/dts/tegra30-apalis.dts
+++ b/arch/arm/dts/tegra30-apalis.dts
@@ -59,6 +59,7 @@
pci@2,0 {
+ status = "okay";
nvidia,num-lanes = <1>;
(cherry picked from commit 340f51a210df1da640a57267e6c7fa56b8a852ed)
Just release TPS65911 GPIO1 (EN_CORE_DVFS_N) connected to TPS62362
VSEL1 to switch VDD_CORE back to boot set 1 defaulting to 1.200V.
(cherry picked from commit 622d408fea7af6d2ed778b546de346e90ea1a21f)
Implement early TPS6586X PMIC rail configuration setting SM0 being
VDD_CORE_1.2V to 1.2 volts and SM1 being VDD_CPU_1.0V to 1.0 volts.
While those are PMIC power-up defaults the SoC might have been reset
separately with certain rails being left at lower DVFS states which
is e.g. the case upon watchdog reset while otherwise nearly idling.
(cherry picked from commit f7c3186985ebb244d075b04ed7c055f39f485670)
Enable the display driver on Apalis T30. Unfortunately the PWM pin
muxing wasn't any good neither which made that display stay dark.
(cherry picked from commit 2da21c1d130fa11a5bd9876c8e72fa0d57585106)
On popular request enable the display driver on Colibri T30. A few
notes about some things encountered during porting: While analogue VGA
(e.g. via the on-carrier RAMDAC) worked just fine from the beginning
the EDT display flickered like crazy which turned out to be a pin
muxing issue. Unfortunately the PWM pin muxing wasn't any good neither
which made that display stay dark. Enjoy.
(cherry picked from commit 201cc6d4e4c8213fbd103e74b0f2f2ca591edf54)
On popular request make the display driver from T20 work on T30 as
well. Turned out to be quite straight forward. However a few notes
about some things encountered during porting: Of course the T30 device
tree was completely missing host1x as well as PWM support but it turns
out this can simply be copied from T20. The only trouble compiling the
Tegra video driver for T30 had to do with some hard-coded PWM pin
muxing for T20 which is quite ugly anyway. On T30 this gets handled by
a board specific complete pin muxing table. The older Chromium U-Boot
2011.06 which to my knowledge was the only prior attempt at enabling a
display driver for T30 for whatever reason got some clocking stuff
mixed up. Turns out at least for a single display controller T20 and
T30 can be clocked quite similar. Enjoy.
(cherry picked from commit 5a472ddd7a2a017747d6c05c65eba2cd3804c02f)
Migrate Colibri T20 to U-Boot 2016.11.
(cherry picked from commit 92d747bf338ceb8d6dbdd3e5e5f7f72226ce0792)
Migrate Apalis/Colibri T30 to U-Boot 2016.11.
(cherry picked from commit 81a38df0631cfa6b3a85c97e631abf73dc0a2226)
Migrating our BSPs towards mainline U-Boot I noticed it suddenly booting
slower. With mainline Linux I noticed about a 1 to 2 second increase
while booting downstream L4T takes 10 to 15 seconds longer!
This reverts commit 858530a8c0a7ce7e573e513934804a00d6676813.
drivers/serial/Makefile
(cherry picked from commit 752aae30a791326581efafbb761c0cebaba8d3ea)
drivers/serial/serial_tegra.c
include/configs/tegra-common.h
(cherry picked from commit 4b97c4173ef96cfa4eb3ba4ea9121320efa90091)
There is no need to enumerate USB when trying to boot using DHCP.
Synchronize environment with current layout, order variables by
name.
Set fdtfile to represent the current board. This allows distribution
to load the correct device tree, which in the module case often
deviates from the common fallback ${soc}-${board}${boardver}.dtb...
Add support for distro boot. This is especially helpful for external
devices. There is a global boot command which scans a predefined
list of boot targets:
run distro_bootcmd
As well as direct boot commands such as:
run bootcmd_mmc0
run bootcmd_usb
run bootcmd_dhcp
Refer to doc/README.distro fo details.
run distro_bootcmd
run bootcmd_mmc1
run bootcmd_mmc2
run bootcmd_usb
run bootcmd_dhcp
While at it, remove the CONFIG_DRIVE_TYPES define which has not
been used and was meant to be used for multi device boot support
which is now provided by distroboot.
Boards with native ethernet support don't require USB start. This
change lets a board configuration overwrite the NET USB command,
so that U-Boot does not start USB for network boot by default.
Add environment variables for default framebuffer support using a
default VGA mode. Also remove memargs, since we use memory size to
reserve the framebuffer which does not get overwritten by the
Linux kernel.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
Fix the framebuffer location to the very end of the available memory.
This allows to remove the area from available memory for the kernel,
which in turn allows to display the splash screen through the while
Linux kernel boot process.
Ideas has been taken from the sunxi display driver, e.g.
20779ec3a5 ("sunxi: video: Dynamically reserve framebuffer memory")
The Vybrid SoC family has the same display controller unit (DCU)
like the LS1021A SoC. This patch adds platform data, pinmux defines
and clock control to enable the driver for Vybrid based boards too.
Synchronize initramfs related configuration options and improve
memory layout. The memory layout with an offset of 16MiB allows
to boot bigger kernels. With AUTO_ZRELADDR, which is pretty much
the standard nowadays, the kernel relacates itself to PC masked
with 0xf8000000 plus a text offset of 0x8000 (hence 0x80008000 for
Vybrid). With a 16MiB offset from the start of memory and a 16MiB
distance to the device-tree, we allow kernel up to ~16MiB.
u-boot allows modifying a device tree after it is loaded into
memory. Add fdt_fixup hook in u-boot environment which can
facilitate such modifications.
(cherry picked from commit faf1e62bf04b01dc7110a459f558aaf414bfcac0)
Introduce Ethernet update capability via setethupdate which is
automatically tried by setupdate as well should SD and USB update
fail (e.g. neither an SD card nor an USB memory stick with our
flash_blk.img script and accompanying artefacts is inserted.
Our update scripts write the kernel and device tree in seperate
UBI volumes. This allows to use a lot less UBI/UBIFS support in
U-Boot, which should lower the risk of hitting bugs in this area.
Boot times are also slightly faster (measurements showed an
improvement of ~150ms).
Add support for setting the linux,usable-memory in the memory
node of device tree.
Code mostly ported from imx-kobs-5.3.
MTD partitioning is set accordingly.
writebcb: Write Boot Control Block (FCB and DBBT)
[ported to U-Boot 2016.11]
Add writebcb command which creates a NAND Boot Configuration Block
(BCB) at the beginning of the active flash device. The BCB stores
the information for the SoC internal boot ROM where the application
with a valid IVT header can be found on the NAND device. The first
two argument of the command need an offset of the NAND device where
the primary and secondary application can be found.
Typically, U-Boot is the application which gets loaded by the boot
ROM. Hence, the offset address need to be the address where U-Boot
(u-boot.imx along with a 0x400 long prefix) is stored on the device.
At least one location is mandatory.
Currently only the FCB (Firmware Configuration Block) is written to
the device. The DBBT (Discovered Bad Block Table) is optional and
not created by writebcb currently.
Use two separate partitions for the two firmware instances. Also
resize them to be of the same size which also makes the start of
the UBI partition nicely aligned to 0x400000.
In order to detect the new MTD layout and whether we run a U-Boot
with the new BCB format or not, introduce a variable called
"updlevel" which we can use in update/upgrade scripts.
Limit memory used for relocation of FDT or initrd. This is
required to make sure that relocated artifacts are within lowmem.
If fdt_high or initrd_high are not set, U-Boot automatically
relocates artifacts to the end of memory. But this area won't
be part of lowmem and hence will not be accessible by the kernel
during early boot.
With VM split set to 2G/2G (i.MX default), only the 2GB Apalis
iMX6 is affected by that issue. With VM split set to 3G/1G (ARM
default) also modules with 1GB of memory are affected. With the
latter the amount of lowmem will be 760MiB.
The value must also not exceed available memory! Use a safe value
of 512MiB for Apalis and 256MiB for Colibri.
The DFU Kconfig menu entries should be part of the SPL
Kconfig file. Also avoid using the top level Makefile by
moving the config dependent build artifacts to the driver/
and driver/usb/gadget/ Makfiles.
With that, DFU can be built again in SPL if
CONFIG_SPL_DFU_SUPPORT is enabled.
Fixes: 6ad6102246d8 ("usb:gadget: Disallow DFU in SPL for now")
Acked-by: Lukasz Majewski <l.majewski@samsung.com>
(cherry picked from commit 5991703e88f320767d9390d64a6a9bd62560696b)
Specify standard padding for payload to 68KB. This is derived from
the maximum header size plus maximum SPL size. It matches the
already defined offset for SD/eMMC devices (69KB) too. This allows
to use the u-boot-with-spl.imx build target to generate a directly
flashable image which can be flashed using:
dd if=u-boot-with-spl.imx of=/dev/mmcblk0 bs=512 skip=2
While the patch has been created with SD/eMMC in mind, this also
works with other boot media. The board file needs to configure the
media specific (absolute) payload offset accordingly. Especially
the IVT offset is boot media specific and can be retrieved from the
reference manual (Table 8-25. Image Vector Table Offset and Initial
Load Region Size). For NAND boot a define like this should do the
job:
#define CONFIG_SYS_NAND_U_BOOT_OFFS (SPL_PAD_TO + 0x400)
(cherry picked from commit 0405092bd21a44f5af22f17aeb0b82a0a11e1252)
Basically running the following script:
tools/moveconfig.py CONFIG_TEGRA_MMC
Note that I left the SPL specific handling in
include/configs/tegra-common-post.h unchanged.
This patch adds board support for the Toradex Apalis TK1 a computer on
module which can be used on different carrier boards.
The module consists of a Tegra TK1 SoC, a PMIC solution, 2 GB of DDR3L
RAM, a bunch of level shifters, an eMMC, a TMP451 temperature sensor
chip, an I210 gigabit Ethernet controller and a SGTL5000 audio codec.
Furthermore, there is a Kinetis MK20DN512 companion micro controller for
analogue, CAN and resistive touch functionality.
For the sake of ease of use we do not distinguish between different
carrier boards for now as the base module features are deemed
sufficient enough for regular booting.
The following functionality is working so far:
- eMMC boot, environment storage and Toradex factory config block
- Gigabit Ethernet
- MMC/SD cards (both MMC1 as well as SD1 slot)
- USB client/host (dual role OTG port as client e.g. for DFU/UMS or host,
other two ports as host)
This adds board support for the Toradex module family Colibri iMX6.
The familiy consists of a module with i.MX6 DualLite, i.MX6 Solo, both
with a version for commercial and industrial temperature range.
(cherry picked from commit a02d517b0182f83771565eba1329fb323674ec58)
This adds board support for the Toradex module family Apalis iMX6.
The familiy consists of a module with i.MX6 Dual, i.MX6 Quad with
(cherry picked from commit 592f4aed6db765172e21f228800b49f9a27ff201)
Commit 35c204d8a9d0 ("nand: reinstate lazy bad block scanning")
introduced lazy BBT scanning. However, some controller do parts
of the initialization (mxs_nand.c) during scan_bbt, hence for
those controllers the BBT must be scanned at initialization time.
In most situation the U-Boot environment gets read first, and
the U-Boot environment code checks for bad blocks first. Checking
for bad blocks will ask for scan_bbt before reading the first page,
hence in most situation the issue does not appear in practice.
However, when there is no environment configured, other code might
access NAND first which does not explicitly checks for bad blocks,
in those cases ECC reads will fail always.
Cc: Rostislav Lisovy <lisovy@gmail.com>
Add serial platform data to board file.
Enable driver model for PXA serial driver.
(cherry picked from commit 136179bec19f4bc84227cba138214ea392a723ea)
With em humble DM and Kconfig migraters U-Boot binary size keeps
increasing. Drop a bunch of less needed stuff to save another precious
20+ KB.
(cherry picked from commit fc127d184aea293ec415dd66e3282dba0b66c5f3)
Optional driver model handling integration.
(cherry picked from commit cbfa67a16b345cfb94840a41ee2fa0f728be296a)
Migrate the PXA serial driver to be configured via Kconfig.
(cherry picked from commit d804a5e1c369e59f23723cd21e1e422b7702a0ac)
remove now unused CONFIG_TRDX_PID_XXX
(cherry picked from commit 877ea607a8e07a9ed308e44a58e8e2b9028f01f2)
Now with the config block handling in place move the U-Boot environment
location before the config block at the end of 1st "boot sector" as
deployed during production using our downstream BSP.
(cherry picked from commit 74b19ad1c180fe32a01bccc35b0be1425132d927)
With our common code in place actually make use of it across all our
modules.
(cherry picked from commit b891d01038abcc8b25f12e1b91ff889b06eb07a2)
Like [1], reset the FLP burst timing for the KSZ9031 to the 16ms
specified by the IEEE802.3 standard from the chip's default of 8ms.
For more details, see the "Auto-Negotiation Timing" section of the
KSZ9031RNX datasheet.
[1] https://patchwork.kernel.org/patch/6558371/
Signed-off-by: Ash Charles <ash.charles@savoirfairelinux.com>
As the upcoming driver model integration takes up some more precious flash
space first make sure to drop expensive LZMA support.
Cover-Letter: Fixes several spelling errors for the words "resetting",
"extended", "occur", and "multiple".
Signed-off-by: Vagrant Cascadian <vagrant@debian.org>
Not all networks have a DHCP server configured properly, so these
scripts make it easier to boot in that scenario.
