Patch from Richard Danter, 12 Aug 2005
Patch by Thomas Lange, Aug 11 2005
Patch by Martin Krause, 8 Jun 2006
This patch supports two serial consoles on boards with
a MPC5xxx CPU. The console can be switched at runtime
by setting stdin, stdout and stderr to the desired serial
interface (serial0 or serial1). The PSCs to be used as
console port are definded by CONFIG_PSC_CONSOLE
and CONFIG_PSC_CONSOLE2.
See README.serial_multi for details.
Patch by Martin Krause, 17 Nov 2005
Patch by Martin Krause, 07 Nov 2005
Tested on a STK85XX baseboard. Make sure the PS/2 controller
has been programmed. Jumper Settings: X66 1-2, 9-10; X61 2-3
Make the automatic CS configuration the default.
The dedicated configurations CONFIG_TQM5200_AA, CONFIG_TQM5200_AB
and CONFIG_TQM5200_AC are removed.
"TQM5200_config" is now the default for STK52XX.200 base boards.
On a STK52XX.100 base board "TQM5200_STK100_config" must be used.
Patch by Martin Krause, 27 Oct 2005
Patch by Stefan Roese, 13 Jun 2006
Patch by Scott McNutt, 08 Jun 2006
-When booting from an epcs controller, the epcs bootrom may leave the
slave select in an asserted state causing soft reset hang. This
patch ensures slave select is negated at reset.
-Update base addresses for standard configuration
-Eliminate use of CACHE_BYPASS in board code
-Fix asm/io.h macros
-Eliminate use of CACHE_BYPASS in cpu code
-Eliminate assembler warnings
-Fix mini-app stubs and force no small data
Patch by Stefan Roese, 06 Jun 2006
Patch by Stefan Roese, 02 Jun 2006
- Add IXP4xx NPE ethernet MAC support
- Add support for Intel IXDPG425 board
- Add support for Prodrive PDNB3 board
- Add IRQ support
Patch by Stefan Roese, 23 May 2006
[This patch does not include cpu/ixp/npe/IxNpeMicrocode.c which still
sufferes from licensing issues. Blame Intel.]
Patch by Stefan Roese, 15 May 2006
(needed because of differences in the PCMCIA hardware).
Patch by Stefan Roese, 10 May 2006
Patch by John Otken, 08 May 2006
- Fix OMAP support that omap5912osk compiles in current source tree
- Update with code from "http://omap.spectrumdigital.com/osk5912"
to fix problems with DDR initialization
- Fix timer setup
- Use CFI flash driver and support complete 32MB of onboard flash
- Add "print_cpuinfo()" and "checkboard()" functions to display
CPU (with frequency) and Board infos
reasonable TEXT_BASE, update default environment and enable keyed
autoboot.
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
Patch from Scott McNutt, 11 Aug 2005
Signed-off-by: dzu@denx.de <dzu@denx.de>
- Removed MPC8349ADS port
- Added PCI support to MPC8349ADS
- reworked memory map to allow mapping of all regions with BATs
Patch by Kumar Gala 20 Apr 2006
Patch from Scott McNutt 11, Aug 2005
Patch by Scott McNutt 11, Aug 2005
relocate ichache_State to ram
u-boot can run from internal flash
Add EB+MCF-EV123 board support.
Add m68k Boards to MAKEALL
Patch from Jens Scharsig, 08 Aug 2005
