At present the MD5 option cannot be enabled by board configs since it has
no Kconfig name. It is generally enabled, so long as FIT support is
present. But not all boards use FIT, particularly in SPL
Fix this and add an option for SPL as well. This allows board code to call
md5() even if FIT support is not enabled.
This patch enables LZMA decompression support for SPL build
Signed-off-by: Weijie Gao <weijie.gao@mediatek.com>
There is no way to select BZIP2 compression method.
Add it under library/compression config where all other
compression related configs are present.
Signed-off-by: Atish Patra <atish.patra@wdc.com>
Move the generic elf loading/validating functions to lib/
so that they can be re-used and accessed by code existing
outside cmd.
While at it remove the duplicate static version of load_elf_image_phdr
under arch/arm/mach-imx/imx_bootaux.c.
Signed-off-by: Keerthy <j-keerthy@ti.com>
Suggested-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
drivers/rng/sandbox_rng.c requires rand() to be defined but configuration
option CONFIG_CONFIG_LIB_RAND selected in drivers/rng/Kconfig does not
exist.
test/lib/test_aes.c requires rand() to be defined.
Fix the selection criteria for choice "Pseudo-random library support type".
SPL and TPL can access information about binman entries using link-time
symbols but this is not available in U-Boot proper. Of course it could be
made available, but the intention is to just read the device tree.
Add support for this, so that U-Boot can locate entries.
Imported from linux kernel v5.3:
x509.asn1 without changes
x509_akid.asn1 without changes
x509_parser.h without changes
x509_cert_parser.c with changes marked as __UBOOT__
x509_public_key.c with changes marked as __UBOOT__
Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
build_OID_registry without changes
oid_registry.h without changes
oid_registry.c with changes marked as __UBOOT__
lib/asn1_decoder.c with changes marked as __UBOOT__
asn1.h without changes
asn1_ber_bytecode.h without changes
asn1_decoder.h without changes
asn1_compiler.c without changes
This host command will be used to create a ASN1 parser, for example,
for pkcs7 messages or x509 certificates. More specifically, it will
generate *byte code* which will be interpreted by asn1 decoder library.
Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
In the next commit, rtc_mktime(), for compatibility with linux, will be
implemented using rtc_mktime(), which is no longer drivers/rtc specific.
So move this file under lib/.
27084c03d36a ("spl: Allow tiny printf() to be controlled in SPL and
TPL") split this option in two for TPL and SPL, but didn't change the
Kconfig names, making them hard to set quickly.
Signed-off-by: Thomas Hebb <tommyhebb@gmail.com>
For better or worse libfdt recent grew a lot of code that checks the
validity of the device tree in great detail. When using unsigned or
unverified data this makes things safer, but it does add to code size.
Add some controls to select the trade-off between safety and code size.
At present there is only one control for this and it is used for both SPL
and TPL. But SPL might have a lot more space than TPL so the extra cost of
a full printf() might be acceptable.
Split the option into two, providing separate SPL and TPL controls. The
TPL setting defaults to the same as SPL.
The USE_TINY_PRINTF symbol only changes things within SPL and TPL
builds, so make it depend on that support. Next, make it default as
within these cases we should rarely have need of more advanced print
formats outside of the debug context.
To do this, in a few cases we need to correct our Kconfig dependencies
as we had cases of non-SPL targets select'ing this symbol. Finally, in
the case of a few boards we really do need the full printf
functionality.
Up to now we had hard coded values for the call depth up to which trace
records are created: 200 for early tracing, 15 thereafter. UEFI
applications reach a call depth of 80 or above.
Provide customizing settings for the call trace depth limit and the early
call trace depth limit. Use the old values as defaults.
Add the zstd library from Linux kernel (only decompression support).
There are minimal changes to build with U-Boot, otherwise the files are
identical to Linux commit dc35da16 from March 2018, the files had not
been touched since in kernel. Also SPDX lincese tags were added.
Signed-off-by: Marek Behún <marek.behun@nic.cz>
This adds the xxhash support from Linux. Files are almost identical to
those added to Linux in commit 5d240522 ("lib: Add xxhash module") (they
haven't been touched since in Linux). The only difference is to add some
includes to be compatible with U-Boot. Also SPDX lincese tags were
added.
commit 95f4bbd581cf ("lib: fdt: Allow LZO and GZIP DT compression in U-Boot")
introduced Kconfig option for gzip in U-Boot, but help text
says gzip for SPL, which is wrong. Fix this.
CONFIG_TRACE_BUFFER_SIZE
CONFIG_TRACE_EARLY_SIZE
CONFIG_TRACE_EARLY
CONFIG_TRACE_EARLY_ADDR
CONFIG_TRACE
Runtime tests are provided as a test_fdtdec command implementation. Add
a Kconfig symbol that allows this command to be built so that the tests
can be used.
Signed-off-by: Thierry Reding <treding@nvidia.com>
Add required Kconfig symbols, Makefile bits and macro fixes in a
few places to support LZO and DT compression in U-Boot. This can
save a lot of space with multi-DTB fitImages.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Signed-off-by: Chris Packham <judge.packham@gmail.com>
In some cases U-Boot is compressed and it is useful to be able to
decompress it in SPL. Add a Kconfig and Makefile change to allow this.
Note that this does not actually implement decompression.
Introduce a new Kconfig option for architecture codes to control
whether it provides io{read,write}{8,16,32} I/O accessor functions.
In some cases (e.g. sandbox with verified boot) it is useful to support
libfdt in TPL. Update the Kconfig to handle this.
At present the tpm can only be used in U-Boot proper. Updated it to work
in SPL and TPL also.
fdt_fixup_mtdparts() calls mtdparts_init() and device_find(),
which are defined in cmd/mtdparts.c
The combination of FDT_FIXUP_PARTITIONS=y and CMD_MTDPARTS=n
emits the following link error:
common/fdt_support.c:903: undefined reference to `mtdparts_init'
common/fdt_support.c:914: undefined reference to `device_find'
Integrate libavb into the build system. Introduce CONFIG_LIBAVB
build option.
Signed-off-by: Igor Opaniuk <igor.opaniuk@linaro.org>
Often during debugging session it's very interesting to see
what data we were dealing with. For example what we write or read
to/from memory or peripherals.
This change introduces functions that allow to dump binary
data with one simple function invocation like:
------------------->8----------------
print_hex_dump_bytes("", DUMP_PREFIX_OFFSET, buf, len);
which gives us the following:
00000000: f2 b7 c9 88 62 61 75 64 72 61 74 65 3d 31 31 35 ....baudrate=115
00000010: 32 30 30 00 62 6f 6f 74 61 72 67 73 3d 63 6f 6e 200.bootargs=con
00000020: 73 6f 6c 65 3d 74 74 79 53 33 2c 31 31 35 32 30 sole=ttyS3,11520
00000030: 30 6e 38 00 62 6f 6f 74 64 65 6c 61 79 3d 33 00 0n8.bootdelay=3.
00000040: 62 6f 6f 74 66 69 6c 65 3d 75 49 6d 61 67 65 00 bootfile=uImage.
00000050: 66 64 74 63 6f 6e 74 72 6f 6c 61 64 64 72 3d 39 fdtcontroladdr=9
00000060: 66 66 62 31 62 61 30 00 6c 6f 61 64 61 64 64 72 ffb1ba0.loadaddr
00000070: 3d 30 78 38 32 30 30 30 30 30 30 00 73 74 64 65 =0x82000000.stde
00000080: 72 72 3d 73 65 72 69 61 6c 30 40 65 30 30 32 32 rr=serial0@e0022
00000090: 30 30 30 00 73 74 64 69 6e 3d 73 65 72 69 61 6c 000.stdin=serial
000000a0: 30 40 65 30 30 32 32 30 30 30 00 73 74 64 6f 75 0@e0022000.stdou
000000b0: 74 3d 73 65 72 69 61 6c 30 40 65 30 30 32 32 30 t=serial0@e00220
000000c0: 30 30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00..............
Source of hexdump.c was copied from Linux kernel v4.7-rc2.
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Cc: Mario Six <mario.six@gdsys.cc>
Cc: Stefan Roese <sr@denx.de>
Introduce CONFIG_IMAGE_SPARSE and CONFIG_CMD_MMC_SWRITE so the "mmc
swrite" command is separated from the fastboot code.
Move image-sparse from common to lib so it's clear it's library code.
Rename CONFIG_FASTBOOT_FLASH_FILLBUF_SIZE to CONFIG_IMAGE_SPARSE_FILLBUF_SIZE
and migrate it to Kconfig.
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
Acked-by: Jassi Brar <jaswinder.singh@linaro.org>
The overlay code is only useful when OF_LIBFDT is set, so mark it as
depending on that first.
Enable the FDT library overlay support for all TI SOC family.
Without this option, when Loading fdt from FIT image, the
following warning is seen.
"config with overlays but CONFIG_OF_LIBFDT_OVERLAY not set".
Signed-off-by: Praneeth Bajjuri <praneeth@ti.com>
Suggested-by: Andrew F.Davis <afd@ti.com>
Reviewed-by: Sam Protsenko <semen.protsenko@linaro.org>
When SPL serial is disabled, callers who need sprintf or strtoul fail
because their inclusion is guarded by CONFIG_SPL_SERIAL_SUPPORT/
CONFIG_TPL_SERIAL_SUPPORT.
Split printf, sprintf and strto into their own entries and then select
all of them if SERIAL_SUPPORT is enabled to match the current behaviour.
Include panic.o unconditionally as it can be called from anywhere which
uses BUG_ON().
In January some commits were introduced to mitigate the U-Boot image
size issues we encountered on sunxi builds.
Now with the MMC environment removed we can bring them back, as we
practically don't have a size limit anymore.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Acked-by: Maxime Ripard <maxime.ripard@bootlin.com>
Reviewed-by: Jagan Teki <jagan@openedev.com>
This patch adds code to lib to enable sharing of useful OPTEE code between
board-ports and architectures. The code on lib/optee/optee.c comes from the
TI omap2 port. Eventually the OMAP2 code will be patched to include the
shared code. The intention here is to add more useful OPTEE specific code
as more functionality gets added.
Signed-off-by: Bryan O'Donoghue <bryan.odonoghue@linaro.org>
Cc: Harinarayan Bhatta <harinarayan@ti.com>
Cc: Andrew F. Davis <afd@ti.com>
Cc: Kever Yang <kever.yang@rock-chips.com>
Cc: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Cc: Peng Fan <peng.fan@nxp.com>
Tested-by: Peng Fan <peng.fan@nxp.com>
Add CONFIG prefix to DYNAMIC_CRC_TABLE and implement it in
Kconfig.
Signed-off-by: Faiz Abbas <faiz_abbas@ti.com>
config_fallback.h has some logic that checks a variety of options
and selects LIB_UUID if it hasn't already been selected. This
will all LIB_UUID in Kconfig and select this option for the list
of options to allow us to remove the logic from fallbacks
config_fallbacks.h had some logic to automatically select
LIB_RAND if RANDOM_UUID or CMD_UUID were set if LIB_HW_RAND wasn't
already selected. By migrating LIB_HW_RAND to Kconfig, we can
remove this check from config_fallbacks.h and put it into Kconfig
Reviewed-by: Lukasz Majewski <lukma@denx.de>
[trini: Turn into a choice, add NET_RANDOM_ETHADDR]
The sunXi arm64 build has overflown, leading to the main U-boot binary
overwriting the environment when flashing the new image, or even worse,
overwriting itself when we're calling saveenv.
Disable this option that is not critical until we can adress the issue
properly.
Reviewed-by: Andre Przywara <andre.przywara@arm.com>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Freescale (NXP) boards have lots of defconfig files per board.
I used "imply PANIC_HANG" for them.
Reviewed-by: York Sun <york.sun@nxp.com>
Add support for S35392A RTC. The driver supports both U-Boot driver
models.
Signed-off-by: Nandor Han <nandor.han@ge.com>
Signed-off-by: Martyn Welch <martyn.welch@collabora.co.uk>
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
This is needed for BTRFS.
Signed-off-by: Marek Behun <marek.behun@nic.cz>
create mode 100644 lib/crc32c.c
Add Kconfig option SPL_GZIP and SPL_ZLIB to enable gunzip support for
SPL boot, eg. falcon boot compressed kernel image.
Signed-off-by: York Sun <york.sun@nxp.com>
CONFIG_BCH
s/notes/nodes
With the changes to split SPL/TPL for the RK3368, I apparently missed
some needed adjustments to the RK3188 Kconfig and rock_defconfig.
This fixes build-issues for the rock board after applying the RK3368
enablement (and SPL/TPL) set that resulted from TPL_SERIAL_SUPPORT,
TPL_ROCKCHIP_BACK_TO_BROM and TPL_TINY_MEMSET being separate symbols
now.
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
