path: root/lib/efi
2020-02-05dm: core: Create a new header file for 'compat' featuresSimon Glass
At present dm/device.h includes the linux-compatible features. This requires including linux/compat.h which in turn includes a lot of headers. One of these is malloc.h which we thus end up including in every file in U-Boot. Apart from the inefficiency of this, it is problematic for sandbox which needs to use the system malloc() in some files. Move the compatibility features into a separate header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-01-17common: Move reset_cpu() to the CPU headerSimon Glass
Move this function out of common.h and into a relevant header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-12-15x86: timer: use a timer base of 0Simon Glass
On x86 platforms the timer is reset to 0 when the SoC is reset. Having this as the timer base is useful since it provides an indication of how long it takes before U-Boot is running. When U-Boot sets the timer base to something else, time is lost and we no-longer have an accurate account of the time since reset. This particularly affects bootstage. Change the default to not read the timer base, leaving it at 0. Add an option for when U-Boot is the secondary bootloader. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-04-23efi_loader: consistent naming of protocol GUIDsHeinrich Schuchardt
We should consistently use the same name for protocol GUIDs as defined in the UEFI specification. Not adhering to this rule has led to duplicate definitions for the EFI_LOADED_IMAGE_PROTOCOL_GUID. Adjust misnamed protocol GUIDs. Adjust the text for the graphics output protocol in the output of the `efidebug dh` command. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2018-12-02efi_loader: typedef struct efi_object *efi_handle_tHeinrich Schuchardt
All our handles point to a struct efi_object. So let's define the efi_handle_t accordingly. This helps us to discover coding errors much more easily. This becomes evident by the corrections to the usage of handles in this patch. Rename variable image_handle to image_obj where applicable. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-11-14sysreset: Remove DM_FLAG_PRE_RELOC flag in various driversBin Meng
When a driver declares DM_FLAG_PRE_RELOC flag, it wishes to be bound before relocation. However due to a bug in the DM core, the flag only takes effect when devices are statically declared via U_BOOT_DEVICE(). This bug has been fixed recently by commit "dm: core: Respect drivers with the DM_FLAG_PRE_RELOC flag in lists_bind_fdt()", but with the fix, it has a side effect that all existing drivers that declared DM_FLAG_PRE_RELOC flag will be bound before relocation now. This may expose potential boot failure on some boards due to insufficient memory during the pre-relocation stage. To mitigate this potential impact, the following changes are implemented: - Remove DM_FLAG_PRE_RELOC flag in the driver, if the driver only supports configuration from device tree (OF_CONTROL) - Keep DM_FLAG_PRE_RELOC flag in the driver only if the device is statically declared via U_BOOT_DEVICE() - Surround DM_FLAG_PRE_RELOC flag with OF_CONTROL check, for drivers that support both statically declared devices and configuration from device tree Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-08-30efi: stub: Pass EFI system table address to U-Boot payloadBin Meng
This updates the EFI stub codes to pass UEFI BIOS's system table address to U-Boot payload so that U-Boot can utilize it. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-07-20efi: app: Add a sysreset driverBin Meng
This adds the DM sysreset driver for EFI application support. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-06-24efi: stub: Move the use_uart assignment immediately after ↵Bin Meng
exit_boot_services() call The use_uart assignment should follow immediately after the call to exit_boot_services(), in case we want some debug output after that. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-06-24efi.h: Do not use config optionsAlexander Graf
Currently efi.h determines a few bits of its environment according to config options. This falls apart with the efi stub support which may result in efi.h getting pulled into the stub as well as real U-Boot code. In that case, one may be 32bit while the other one is 64bit. This patch changes the conditionals to use compiler provided defines instead. That way we always adhere to the build environment we're in and the definitions adjust automatically. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com> [bmeng: added some comments to describe the __x86_64__ check] Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-06-17efi: stub: Pass EFI GOP information to U-Boot payloadBin Meng
If UEFI BIOS has the graphics output protocol (GOP), let's pass its information to U-Boot payload so that U-Boot can utilize it (eg: an EFI framebuffer driver). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-06-17x86: use EFI calling convention for efi_main on x86_64Ivan Gorinov
UEFI specifies the calling convention used in Microsoft compilers; first arguments of a function are passed in (%rcx, %rdx, %r8, %r9). All other compilers use System V ABI by default, passing first integer arguments of a function in (%rdi, %rsi, %rdx, %rcx, %r8, %r9). These ABI also specify different sets of registers that must be preserved across function calls (callee-saved). GCC allows using the Microsoft calling convention by adding the ms_abi attribute to a function declaration. Current EFI implementation in U-Boot specifies EFIAPI for efi_main() in the test apps but uses default calling convention in lib/efi. Save efi_main() arguments in the startup code on x86_64; use EFI calling convention for _relocate() on x86_64; consistently use EFI calling convention for efi_main() everywhere. Signed-off-by: Ivan Gorinov <ivan.gorinov@intel.com> Reviewed-by: Alexander Graf <agraf@suse.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2018-06-13x86: efi: payload: Minor clean up on error message outputBin Meng
If GetMemoryMap() fails, we really want to know EFI_BITS_PER_LONG instead of BITS_PER_LONG. A space and LF are added in places where error message is output to improve readability. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-06-13x86: efi: payload: Enforce toolchain to generate 64-bit EFI payload stub codesBin Meng
Attempting to use a toolchain that is preconfigured to generate code for the 32-bit architecture (i386), for example, the i386-linux-gcc toolchain on kernel.org, to compile the 64-bit EFI payload does not build. This updates the makefile fragments to ensure '-m64' is passed to toolchain when building the 64-bit EFI payload stub codes. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-04-27Remove unnecessary instances of DECLARE_GLOBAL_DATA_PTRTom Rini
We have a large number of places where while we historically referenced gd in the code we no longer do, as well as cases where the code added that line "just in case" during development and never dropped it. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-03-30efi_stub: Fix GDT_NOTSYS checkAlexander Graf
The get_codeseg32() wants to know if a passed in descriptor has flag GDT_NOTSYS set (desc & GDT_NOTSYS), not whether desc and GDT_NOTSYS are not != 0 (desk && GDT_NOTSYS). This is an obvious typo. Fix it up. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-12-05efi_stub: Use efi_uintn_tAlexander Graf
Commit f5a2a93892f ("efi_loader: consistently use efi_uintn_t in boot services") changed the internal EFI API header without adapting its existing EFI stub users. Let's adapt the EFI stub as well. Fixes: f5a2a93892f ("efi_loader: consistently use efi_uintn_t in boot services") Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2017-07-27spl: make SPL and normal u-boot stage use independent SYS_MALLOC_F_LENAndy Yan
Some platforms have very limited SRAM to run SPL code, so there may not be the same amount space for a malloc pool before relocation in the SPL stage as the normal U-Boot stage. Make SPL and (the full) U-Boot stage use independent SYS_MALLOC_F_LEN, so the size of pre-relocation malloc pool can be configured memory space independently. Signed-off-by: Andy Yan <andy.yan@rock-chips.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> [fixed up commit-message:] Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2016-11-14x86: Tidy up selection of building the EFI stubSimon Glass
At present we use a CONFIG option in efi.h to determine whether we are building the EFI stub or not. This means that the same header cannot be used for EFI_LOADER support. The CONFIG option will be enabled for the whole build, even when not building the stub. Use a different define instead, set up just for the files that make up the stub. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2016-08-30x86: efi: payload: Make EFI payload build againBin Meng
Since commit 73c5c39 "Makefile: Drop unnecessary -dtb suffixes", EFI payload does not build anymore. This fixes the build. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-03-27efi_stub: Move carriage return before line feed in putc()Bin Meng
A carriage return needs to execute before a line feed. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-10-21debug_uart: Adjust the declaration of debug_uart_init()Simon Glass
We want to be able to add other common code to this function. So change the driver's version to have an underscore before it, just like _debug_uart_putc(). Define debug_uart_init() to call this version. Update all drivers to this new method. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-05efi: Add functions for decoding the EFI tablesSimon Glass
The EFI stub can pass a table to U-Boot with information about the memory map Potentially other things will follow. Add a way to access this table. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-05efi: Add 64-bit payload supportSimon Glass
Most EFI implementations use 64-bit. Add a way to build U-Boot as a 64-bit EFI payload. The payload unpacks a (32-bit) U-Boot and starts it. This can be enabled for x86 boards at present. Signed-off-by: Simon Glass <sjg@chromium.org> Improvements to how the payload is built: Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-05efi: Add support for loading U-Boot through an EFI stubSimon Glass
It is useful to be able to load U-Boot onto a board even if is it already running EFI. This can allow access to the U-Boot command interface, flexible booting options and easier development. The easiest way to do this is to build U-Boot as a binary blob and have an EFI stub copy it into RAM. Add support for this feature, targeting 32-bit initially. Also add a way to detect when U-Boot has been loaded via a stub. This goes in common.h since it needs to be widely available so that we avoid redoing initialisation that should be skipped. Signed-off-by: Simon Glass <sjg@chromium.org> Improvements to how the payload is built: Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-05efi: Add start-up library codeSimon Glass
When running as an EFI application, U-Boot must request memory from EFI, and provide access to the boot services U-Boot needs. Add library code to perform these tasks. This includes efi_main() which is the entry point from EFI. U-Boot is built as a shared library. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
