path: root/lib/gzip.c
2015-09-11Move malloc_cache_aligned() to its own headerSimon Glass
At present malloc.h is included everywhere since it recently was added to common.h in this commit: 4519668 mtd/nand/ubi: assortment of alignment fixes This seems wasteful and unnecessary. We have been trying to trim down common.h and put separate functions into separate header files and that change goes in the opposite direction. Move malloc_cache_aligned() to a new header so that this can be avoided. The header would perhaps be better named as alignmem.h but it needs to be included after common.h and people might be confused by this. With the name memalign.h it fits nicely after malloc() in most cases. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2015-08-28mtd/nand/ubi: assortment of alignment fixesMarcel Ziswiler
Various U-Boot adoptions/extensions to MTD/NAND/UBI did not take buffer alignment into account which led to failures of the following form: ERROR: v7_dcache_inval_range - start address is not aligned - 0x1f7f0108 ERROR: v7_dcache_inval_range - stop address is not aligned - 0x1f7f1108 Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Scott Wood <scottwood@freescale.com> [trini: Add __UBOOT__ hunk to lib/zlib/zutil.c due to malloc.h in common.h] Signed-off-by: Tom Rini <trini@konsulko.com>
2012-09-29lib: add gzip lib function callbackLei Wen
Signed-off-by: Lei Wen <leiwen@marvell.com>
