path: root/lib
2013-01-14Merge branch 'u-boot-samsung/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-01-10EXYNOS5: FDT: Add compatible strings for PMICRajeshwari Shinde
Add required compatible information for PMIC Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-01-08arm: move C runtime setup code in crt0.SAlbert ARIBAUD
Move all the C runtime setup code from every start.S in arch/arm into arch/arm/lib/crt0.S. This covers the code sequence from setting up the initial stack to calling into board_init_r(). Also, rewrite the C runtime setup and make functions board_init_*() and relocate_code() behave according to normal C semantics (no jumping across the C stack any more, etc). Some SPL targets had to be touched because they use start.S explicitly or for some reason; the relevant maintainers and custodians are cc:ed. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-01-08EXYNOS5: FDT: Add compatible strings for USBRajeshwari Shinde
Add required compatible information for USB Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-01-08EXYNOS5: FDT: Add compatible strings for SPIRajeshwari Shinde
Add required compatible information for SPI driver. Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-01-08EXYNOS5: FDT: Add compatible strings for soundRajeshwari Shinde
Add required compatible information for sound driver. Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-01-08FDT: Add compatible string for I2CRajeshwari Shinde
Add required compatible information for I2C driver. Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-12-26fdt: exynos5: Add DT node definition for SROM and SMSC9215Hatim RV
Add the compatibility string and constant for the ethernet driver so the device tree parsing code can recognize it. Signed-off-by: Hatim Ali <hatim.rv@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-12-19Merge remote-tracking branch 'u-boot/master' into u-boot-arm-mergedAllen Martin
Conflicts: README arch/arm/cpu/armv7/exynos/clock.c board/samsung/universal_c210/universal.c drivers/misc/Makefile drivers/power/power_fsl.c include/configs/mx35pdk.h include/configs/mx53loco.h include/configs/seaboard.h
2012-12-13env: Add environment variable flagsJoe Hershberger
Currently just validates variable types as decimal, hexidecimal, boolean, ip address, and mac address. If the entry is not found in the env ".flags", then look in the static one. This allows the env to override the static definitions, but prevents the need to have every definition in the environment distracting you. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-12-13env: Add support for callbacks to environment varsJoe Hershberger
Add support for per-variable callbacks to the "hashtable" functions. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> !!!fix comment in callback
2012-12-13env: Hide '.' variables in env print by defaultJoe Hershberger
When printing all variables with env print, don't print variables that begin with '.'. If env print is called with a '-a' switch, then include variables that begin with '.' (just like the ls command). Variables printed explicitly will be printed even without the -a. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-12-13env: Refactor apply into change_okJoe Hershberger
Move the read of the old value to inside the check function. In some cases it can be avoided all together and at the least the code is only called from one place. Also name the function and the callback to more clearly describe what it does. Pass the ENTRY instead of just the name for direct access to the whole data structure. Pass an enum to the callback that specifies the operation being approved. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-12-13env: Consolidate common code in hsearch_r()Joe Hershberger
The same chunk of code was replicated in two places and the following changes will make that chunk grow a bit, so combine into a static func. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-12-13env: Refactor do_apply to a flagJoe Hershberger
Use a flag in hsearch_r for insert mode passed from import to allow the behavior be different based on use. Now that "do_check" is called for all imports, ensure console init is complete before updating the console on relocation import Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-12-13Make linux kernel string funcs available to toolsJoe Hershberger
isspace() and strim() are not in the typical user-mode string.h, so put them in a separate compilation unit so that they can be built into tools that need them independent of the other common string functions. This allows code shared by u-boot and the linux user-mode tools to link. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-12-13vsprintf:fix: Change type returned by ustrtoulLukasz Majewski
The ustrtoul shall convert string defined size (e.g. 1GiB) to unsigned long type (as its name implies). Up till now it had returned int, which might cause problems with large numbers (GiB range), when interpreted as U2 signed numbers. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2012-12-11Add strcasecmp() and strncasecmp()Simon Glass
strncasecmp() is present as strnicmp() but disabled. Make it available and define strcasecmp() also. There is a only a small performance penalty to having strcasecmp() call strncasecmp(), so do this instead of a standalone function, to save code space. Update the prototype in arch-specific headers as needed to avoid warnings. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-12-11sha256: Use const where possible and add watchdog functionSimon Glass
In preparation for making the hash function common, we may as well use const where we can. Also add a watchdog version of the hashing function. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-12-11sha1: Use const where possible, and unsigned for input lenSimon Glass
In preparation for making the hash function common, we may as well use const where we can. Also the input length cannot be negative, but may be very large, so use unsigned. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-12-07Merge branch 'master' of git://git.denx.de/u-boot-x86Tom Rini
2012-12-06Introduce arch_phys_memset which works like memset but on physical memoryGabe Black
The default implementation of this function is just memset, but other implementations will be needed when physical memory isn't accessible by U-Boot using normal addressing mechanisms. Signed-off-by: Gabe Black <gabeblack@chromium.org> Signed-off-by: Che-Liang Chiou <clchiou@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2012-12-06lzma: update to lzma sdk 9.20Stefan Reinauer
Updated code taken from latest lzma sdk release 9.20 at http://downloads.sourceforge.net/sevenzip/lzma920.tar.bz2 This generates quite a lot of checkpatch warnings, but I guess we need to keep the code style as is to avoid a massive job each time we update this. Signed-off-by: Stefan Reinauer <reinauer@google.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2012-11-19tegra: Add SOC support for display/lcdWei Ni
Add support for the LCD peripheral at the Tegra2 SOC level. A separate LCD driver will use this functionality to configure the display. Signed-off-by: Mayuresh Kulkarni <mkulkarni@nvidia.com> Mayuresh Kulkarni: - changes to remove bitfields and clean up for submission Signed-off-by: Simon Glass <sjg@chromium.org> Simon Glass: - simplify code, move clock control into here, clean-up Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-11-19tegra: Add support for PWMSimon Glass
The pulse width/frequency modulation peripheral supports generating a repeating pulse. It is useful for controlling LCD brightness. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-11-12fdt: Remove fdtdec_find_alias_node() functionSimon Glass
This function is not needed, since fdt_path_offset() performs the same service. Remove it. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-11-12fdt: Add polarity-aware gpio functions to fdtdecSean Paul
Add get and set gpio functions to fdtdec that take into account the polarity field in fdtdec_gpio_state.flags. Signed-off-by: Sean Paul <seanpaul@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2012-11-12fdt: Add fdtdec_get_uint64 to decode a 64-bit value from a propertyChe-Liang Chiou
It decodes a 64-bit value from a property that is at least 8 bytes long. Signed-off-by: Che-Liang Chiou <clchiou@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2012-11-12fdt: Add function to read boolean propertyGabe Black
Signed-off-by: Vincent Palatin <vpalatin@chromium.org> Commit-Ready: Vincent Palatin <vpalatin@chromium.org> Commit-Ready: Gabe Black <gabeblack@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2012-11-12fdt: Export fdtdec_lookup() and fix the nameGerald Van Baren
The name of this function is not consistent, so fix it, and export the function for external use. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-11-12fdt: Add function for decoding multiple gpios globally availableAbhilash Kesavan
Samsung's SDHCI bindings require multiple gpios to be parsed and configured at a time. Export the already available fdtdec_decode_gpios for this purpose. Signed-off-by: Abhilash Kesavan <a.kesavan@samsung.com> Commit-Ready: Che-Liang Chiou <clchiou@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2012-11-12fdt: Add fdtdec_decode_region() to decode memory regionSimon Glass
A memory region has a start and a size and is often specified in a node by a 'reg' property. Add a function to decode this information from the fdt. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-11-12fdt: Add function to get a config string from device treeSimon Glass
Add a function to look up a configuration string such as board name and returns its value. We look in the "/config" node for this. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-11-12fdt: Add function to get config int from device treeAbhilash Kesavan
Add a function to look up a configuration item such as machine id and return its value. Note: The code has been taken as is from the Chromium u-boot development tree and needs Simon Glass' sign-off. Signed-off-by: Abhilash Kesavan <a.kesavan@samsung.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2012-11-04lib/vsprintf.c: sparse fixesKim Phillips
vsprintf.c:31:12: warning: symbol 'hex_asc' was not declared. Should it be static? vsprintf.c:398:18: warning: Using plain integer as NULL pointer Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2012-11-04lib/zlib: sparse fixesKim Phillips
define Z_NULL to (void *)0 include/u-boot/zlib.h to get rid of most of the NULL pointer warnings. inflate.c:942:1: warning: non-ANSI definition of function 'inflateEnd' inflate.c:9:1: warning: non-ANSI definition of function 'inflateReset' inflate.c:12:17: warning: Using plain integer as NULL pointer inflate.c:12:42: warning: Using plain integer as NULL pointer inflate.c:15:17: warning: Using plain integer as NULL pointer inflate.c:21:19: warning: Using plain integer as NULL pointer inflate.c:35:1: warning: non-ANSI definition of function 'inflateInit2_' inflate.c:38:20: warning: Using plain integer as NULL pointer inflate.c:41:17: warning: Using plain integer as NULL pointer inflate.c:42:17: warning: Using plain integer as NULL pointer inflate.c:50:18: warning: Using plain integer as NULL pointer inflate.c:65:23: warning: Using plain integer as NULL pointer inflate.c:69:21: warning: Using plain integer as NULL pointer inflate.c:78:1: warning: non-ANSI definition of function 'inflateInit_' inflate.c:86:1: warning: non-ANSI definition of function 'fixedtables' inflate.c:108:26: warning: Using plain integer as NULL pointer inflate.c:109:1: warning: non-ANSI definition of function 'updatewindow' inflate.c:112:30: warning: Using plain integer as NULL pointer inflate.c:339:1: warning: non-ANSI definition of function 'inflate' inflate.c:349:17: warning: Using plain integer as NULL pointer inflate.c:349:42: warning: Using plain integer as NULL pointer inflate.c:350:27: warning: Using plain integer as NULL pointer inflate.c:369:42: warning: Using plain integer as NULL pointer inflate.c:376:32: warning: Using plain integer as NULL pointer inflate.c:401:54: warning: Using plain integer as NULL pointer inflate.c:419:32: warning: Using plain integer as NULL pointer inflate.c:426:32: warning: Using plain integer as NULL pointer inflate.c:433:32: warning: Using plain integer as NULL pointer inflate.c:444:36: warning: Using plain integer as NULL pointer inflate.c:449:37: warning: Using plain integer as NULL pointer inflate.c:450:38: warning: Using plain integer as NULL pointer inflate.c:457:40: warning: Using plain integer as NULL pointer inflate.c:458:47: warning: Using plain integer as NULL pointer inflate.c:480:40: warning: Using plain integer as NULL pointer inflate.c:481:50: warning: Using plain integer as NULL pointer inflate.c:491:37: warning: Using plain integer as NULL pointer inflate.c:492:37: warning: Using plain integer as NULL pointer inflate.c:501:40: warning: Using plain integer as NULL pointer inflate.c:502:53: warning: Using plain integer as NULL pointer inflate.c:512:37: warning: Using plain integer as NULL pointer inflate.c:513:40: warning: Using plain integer as NULL pointer inflate.c:525:32: warning: Using plain integer as NULL pointer inflate.c:529:52: warning: Using plain integer as NULL pointer inflate.c:543:54: warning: Using plain integer as NULL pointer inflate.c:932:17: warning: Using plain integer as NULL pointer inflate.c:932:42: warning: Using plain integer as NULL pointer inflate.c:935:26: warning: Using plain integer as NULL pointer inflate.c:940:19: warning: Using plain integer as NULL pointer adler32.c:58:5: warning: non-ANSI definition of function 'adler32' adler32.c:81:16: warning: Using plain integer as NULL pointer zutil.c:53:9: warning: non-ANSI definition of function 'zcalloc' zutil.c:64:9: warning: non-ANSI definition of function 'zcfree' inffast.c:70:1: warning: non-ANSI definition of function 'inflate_fast' inftrees.c:33:1: warning: non-ANSI definition of function 'inflate_table' Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2012-11-02lib/vsprintf.c: don't special-case pointers to address nullWolfgang Denk
The %p format of printf() would print a pointer to address null as "(null)". This makes sense in a real OS where a NULL pointer must never be dereferenced, but this is a bootloader, and there are cases where accessing the data at address null makes perfect sense. Remove the special case in lib/vsprintf.c using "#if 0" with a comment to make clear this was an intentional change and to stop re-adding this code. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2012-10-22Merge branch 'next'Gerald Van Baren
2012-10-15libfdt: Add helper function to create a trivial, empty treeGerald Van Baren
The libfdt read/write functions are now usable enough that it's become a moderately common pattern to use them to build and manipulate a device tree from scratch. For example, we do so ourself in our rw_tree1 testcase, and qemu is starting to use this model when building device trees for some targets such as e500. However, the read/write functions require some sort of valid tree to begin with, so this necessitates either having a trivial canned dtb to begin with or, more commonly, creating an empty tree using the serial-write functions first. This patch adds a helper function which uses the serial-write functions to create a trivial, empty but complete and valid tree in a supplied buffer, ready for manipulation with the read/write functions. Signed-off-by: David Gibson <david@gibson.dropbear.id.au> From git://git.jdl.com/software/dtc.git patch hash be6026838 with adaptations to include/libfdt.h and lib/libfdt/Makefile for the U-Boot environment. Signed-off-by: Gerald Van Baren <vanbaren@cideas.com>
2012-10-15libfdt: Add support for appending the values to a existing propertyMinghuan Lian
Some properties may contain multiple values, these values may need to be added to the property respectively. this patch provides this functionality. The main purpose of fdt_append_prop() is to append the values to a existing property, or create a new property if it dose not exist. Signed-off-by: Minghuan Lian <Minghuan.Lian@freescale.com> Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
2012-10-15lib: vsprintf.c: replace NUM_TYPE with s64/u64 typesDaniel Schwierzeck
This fixes warnings when compiling with ELDK-5.2.1 for MIPS64: vsprintf.c: In function 'put_dec': vsprintf.c:258:9: warning: comparison of distinct pointer types lacks a cast [enabled by default] vsprintf.c:258:3: warning: passing argument 1 of '__div64_32' from incompatible pointer type [enabled by default] include/div64.h:22:17: note: expected 'uint64_t *' but argument is of type 'long long unsigned int *' Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2012-10-15lib: vsprintf.c: fix checkpath.pl warningsDaniel Schwierzeck
2012-10-15ARM: prevent misaligned array initsAlbert ARIBAUD
Under option -munaligned-access, gcc can perform local char or 16-bit array initializations using misaligned native accesses which will throw a data abort exception. Fix files where these array initializations were unneeded, and for files known to contain such initializations, enforce gcc option -mno-unaligned-access. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> [trini: Switch to usign call cc-option for -mno-unaligned-access as Albert had done previously as that's really correct] Signed-off-by: Tom Rini <trini@ti.com>
2012-10-01OMAP: networking support for SPLIlya Yanok
This patch adds support for networking in SPL. Some devices are capable of loading SPL via network so it makes sense to load the main U-Boot binary via network too. This patch tries to use existing network code as much as possible. Unfortunately, it depends on environment which in turn depends on other code so SPL size is increased significantly. No effort was done to decouple network code and environment so far. Signed-off-by: Ilya Yanok <ilya.yanok@cogentembedded.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Tom Rini <trini@ti.com>
2012-09-29lib: add gzip lib function callbackLei Wen
Signed-off-by: Lei Wen <leiwen@marvell.com>
2012-09-29lib: zlib: remove the limitation for cannot using 0 as startLei Wen
We often need the requirement that compressing those memory range start from 0, but the default deflate code in zlib prevent us to do this. Considering the special case of uboot, that it could access all memory range, it is reasonable to be able to also take the address space from 0 into compression. Signed-off-by: Lei Wen <leiwen@marvell.com>
2012-09-29lib: zlib: include deflate into zlib buildLei Wen
Add a new config CONFIG_GZIP_ENABLED, if enabled, the uboot bin would include zlib's deflate method which could be used for compressing. Signed-off-by: Lei Wen <leiwen@marvell.com>
2012-09-29lib: zlib: import trees file from 1.2.5Lei Wen
2012-09-29lib: zlib: import deflate source file from 1.2.5Lei Wen
2012-09-21Merge branch 'agust@denx.de' of git://git.denx.de/u-boot-stagingTom Rini
