Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk
This change is intended to clean up the top-level directory structure
and more closely mimic Linux's directory organization.
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
Signed-off-by: Marian Balakowicz <m8@semihalf.com>
Implementation of the do_bootm_linux() and other bootm helper routines is
architecture specific code. As such it resides in lib_<arch> directories
in files named <arch>_linux.c
This patch renames those files to a more clear and accurate
lib_<arch>/bootm.c form.
List of the renamed files:
lib_arm/armlinux.c -> lib_arm/bootm.c
lib_avr32/avr32_linux.c -> lib_avr32/bootm.c
lib_blackfin/bf533_linux.c -> lib_blackfin/bootm.c
lib_i386/i386_linux.c -> lib_i386/bootm.c
lib_m68k/m68k_linux.c -> lib_m68k/bootm.c
lib_microblaze/microblaze_linux.c -> lib_microblaze/bootm.c
lib_mips/mips_linux.c -> lib_mips/bootm.c
lib_nios/nios_linux.c -> lib_nios/bootm.c
lib_nios2/nios_linux.c -> lib_nios2/bootm.c
lib_ppc/ppc_linux.c -> lib_ppc/bootm.c
lib_sh/sh_linux.c -> lib_sh/bootm.c
Modifications are based on the linux kernel approach and
support two use cases:
1) Add O= to the make command line
'make O=/tmp/build all'
2) Set environement variable BUILD_DIR to point to the desired location
'export BUILD_DIR=/tmp/build'
'make'
The second approach can also be used with a MAKEALL script
'./MAKEALL'
Command line 'O=' setting overrides BUILD_DIR environent variable.
When none of the above methods is used the local build is performed and
the object files are placed in the source directory.
- remove trailing white space, trailing empty lines, C++ comments, etc.
- split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c)
* Patches by Kenneth Johansson, 25 Jun 2003:
- major rework of command structure
(work done mostly by Michal Cendrowski and Joakim Kristiansen)
* Add support for INCA-IP Board
