path: root/lib_ppc/board.c
2010-04-13Move lib_$ARCH directories to arch/$ARCH/libPeter Tyser
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk This change is intended to clean up the top-level directory structure and more closely mimic Linux's directory organization. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-03-11PPC: Record U-Boot's relocated address in RAM and show in bdinfo.Richard Retanubun
This patch uses gd->relocaddr variable to store uboot's relocated address in RAM and shows it in bdinfo command. This patch moves CONFIG_AMIGAONEG3SE style copying of the address in board_init_f to just before relocation is actually done. Signed-off-by: Richard Retanubun <RichardRetanubun@RuggedCom.com> Tested-by: Detlev Zundel <dzu@denx.de>
2010-01-24mpc512x: Add display of reset status registerDetlev Zundel
Content of the RSR is put into gd early so we can output it together with the CPU info. The clearing of gd in board_init_f is redundant for this architecture as it is done in cpu_init_f so we remove it. Signed-off-by: Detlev Zundel <dzu@denx.de>
2009-12-15mpc85xx, mpc86xx: Fix gd->cpu pointer after relocationPeter Tyser
The gd->cpu pointer is set to an address located in flash when the probecpu() function is called while U-Boot is executing from flash. This pointer needs to be updated to point to an address in RAM after relocation has occurred otherwise Linux may not be able to boot due to "fdt board" crashing if flash has been erased or changed. This bug was introduced in commit a0e2066f392782730f0398095e583c87812d97f2. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Reported-by: Ed Swarthout <Ed.Swarthout@freescale.com> Tested-by: Kumar Gala <galak@kernel.crashing.org> Tested on MPC8527DS. Tested by: Ed Swarthout <Ed.Swarthout@freescale.com>
2009-10-16mpc85xx: Fix booting on various boardsAnton Vorontsov
commit 0e870980a64584a591af775bb9c9fe9450124df9 ("8xxx: Removed CONFIG_NUM_CPUS from 85xx/86xx") breaks U-Boot on various boards, namely the ones that call get_sys_info() from board_early_init_f(). get_sys_info() calls cpu_numcores(), which depends on probecpu() being called before. But probecpu() is called after board_early_init_f(), and so cpu_numcores() returns random values, which in turn crashes get_sys_info(). To fix the issue we place probecpu() before board_early_init_f() in an initialization sequence. Booting on the following boards should be revived now: mpc8540ads mpc8541cds mpc8548cds mpc8555cds mpc8560ads mpc8568mds mpc8569mds and maybe more. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-10-10Add bb_miiphy_init call before any ethernet bring-up code.Luigi 'Comio' Mantellini
Signed-off-by: Luigi 'Comio' Mantellini <luigi.mantellini@idf-hit.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-10-03ppc: Remove board.c relocation fixupsPeter Tyser
2009-09-22ppc: Clean up calling of phy_reset() during initPeter Tyser
Remove board-specific #ifdefs for calling phy_reset() during initializtion Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-09-22ppc: Clean up calling of misc_init_r() during initPeter Tyser
Remove board-specific #ifdefs for calling misc_init_r() during initializtion Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Acked-by: Heiko Schocher <hs@denx.de>
2009-09-08ppc/8xxx: relocate cpu pointer in global dataKumar Gala
Now that we have a pointer to the cpu struct we need to relocate it once we get into ram. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-04Consolidate arch-specific mem_malloc_init() implementationsPeter Tyser
2009-09-04Standardize mem_malloc_init() implementationPeter Tyser
This lays the groundwork to allow architectures to share a common mem_malloc_init(). Note that the x86 implementation was not modified as it did not fit the mold of all other architectures. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-09-04Consolidate arch-specific sbrk() implementationsPeter Tyser
2009-08-288xxx: Removed CONFIG_NUM_CPUS from 85xx/86xxPoonam Aggrwal
The number of CPUs are getting detected dynamically by checking the processor SVR value. Also removed CONFIG_NUM_CPUS references from all the platforms with 85xx/86xx processors. This can help to use the same u-boot image across the platforms. Also revamped and corrected few Freescale Copyright messages. Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-26Revert "ppc: Unlock cache-as-ram in a consistent manner"Wolfgang Denk
This reverts commit 982adfc610669482a32127282fe489857a92cfe3. This patch causes problems on MPC83xx boards - flash recognition stops working. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-23ppc: Unlock cache-as-ram in a consistent mannerPeter Tyser
Previously, non-e500 architectures only unlocked their data cache which was used as early RAM when booting to Linux using the "bootm" command. This change causes all PPC boards with CONFIG_SYS_INIT_RAM_LOCK defined to unlock their data cache during U-Boot's initialization. This improves U-Boot performance and provides a common cache state when booting to different OSes. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-07-18stdio/device: rework function naming conventionJean-Christophe PLAGNIOL-VILLARD
So far the console API uses the following naming convention: ======Extract====== typedef struct device_t; int device_register (device_t * dev); int devices_init (void); int device_deregister(char *devname); struct list_head* device_get_list(void); device_t* device_get_by_name(char* name); device_t* device_clone(device_t *dev); ======= which is too generic and confusing. Instead of using device_XX and device_t we change this into stdio_XX and stdio_dev This will also allow to add later a generic device mechanism in order to have support for multiple devices and driver instances. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Edited commit message. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-06-1283xx: Replace CONFIG_MPC83XX with CONFIG_MPC83xxPeter Tyser
Use the standard lowercase "xx" capitalization that other Freescale architectures use for CPU defines to prevent confusion and errors Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-06-12make MODEM SUPPORT generic instead of duplicate itJean-Christophe PLAGNIOL-VILLARD
and fix comment Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Adjusted Copyright message. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-06-12lib_arch/board.c: Move malloc initialization before flash_init()Stefan Roese
This patch moves the malloc initialization before calling flash_init(). Upcoming changes to the NOR FLASH common CFI driver with optional MTD infrastructure and MTD concatenation support will call malloc(). And nothing really speaks against enabling malloc just a little earlier in the boot stage. Some architectures already enable malloc before calling flash_init() so they don't need any changes here. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Scott McNutt <smcnutt@psyent.com> Cc: Shinya Kuribayashi <shinya.kuribayashi@necel.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Cc: Daniel Hellstrom <daniel@gaisler.com> Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: John Rigby <jcrigby@gmail.com>
2009-04-05Update CHANGELOG, coding style cleanup.Wolfgang Denk
2009-04-0185xx/86xx: Ensure MP boot page is not usedKumar Gala
We had a bug on 86xx in which the boot page used to bring up secondary cores was being overwritten and used for the malloc region in u-boot. We need to reserve the region of memory that the boot page is going to be put at so nothing uses it. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Becky Bruce <beckyb@kernel.crashing.org>
2009-03-20powerpc: Only use eth_getenv_enetaddr() if networking is enabledStefan Roese
2009-03-20powerpc: Fix compilation warning in board.cStefan Roese
Fix this warning: board.c: In function 'board_init_r': board.c:653: warning: unused variable 'i' board.c:651: warning: unused variable 'e' Signed-off-by: Stefan Roese <sr@denx.de>
2009-03-20ppc: mark global bi_enet*addr as legacyMike Frysinger
The environment is the canonical storage location of the mac address, so we're killing off the global data location and moving everything to querying the env directly. In the ppc case, these things are part of the legacy ABI, so keep them around but mark them as legacy so no new code will touch them. Also stop calling load_sernum_ethaddr() since all boards now implement this as a stub. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2009-03-20boards: get mac address from env and move load_sernum_ethaddr() to board initMike Frysinger
The environment is the canonical storage location of the mac address, so we're killing off the global data location and moving everything to querying the env directly. Rather than have common ppc code call a board-specific function like load_sernum_ethaddr(), have each board call it in its own board-specific misc_init_r() function. The boards that get converted here are: - kup4k/kup4x - pcs440ep - tqm8xx Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com> CC: Stefan Roese <sr@denx.de>
2009-03-20boards: move board_get_enetaddr() into board-specific initMike Frysinger
The environment is the canonical storage location of the mac address, so we're killing off the global data location and moving everything to querying the env directly. Rather than have the common ppc code have board-specific hooks, move the board_get_enetaddr() function into the board-specific init functions. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2009-03-20nx823: get mac address from environmentMike Frysinger
The environment is the canonical storage location of the mac address, so we're killing off the global data location and moving everything to querying the env directly. For the nx823, the serial number is moved out of load_sernum_ethaddr() and into misc_init_r() as is the env setup. This lets us kill off the former function in the process. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2009-03-188xx, icache: enabling ICache not before running from RAMHeiko Schocher
with the new CONFIG_SYS_DELAYED_ICACHE config option, ICache is not enabled before code runs from RAM. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-03-02i2c, dtt: move dtt_init () to board_init_r ()Heiko Schocher
it is not necessary to init the DTTs so early, so move this init to board_init_r (). Signed-off-by: Heiko Schocher <hs@denx.de>
2009-02-16Add MMC FrameworkAndy Fleming
Here's a new framework (based roughly off the linux one) for managing MMC controllers. It handles all of the standard SD/MMC transactions, leaving the host drivers to implement only what is necessary to deal with their specific hardware. This also hooks the infrastructure into the PowerPC board code (similar to how the ethernet infrastructure now hooks in) Some of this code was contributed by Dave Liu <daveliu@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2009-02-10ppc: Move CONFIG_MAX_MEM_MAPPED to common config.hKumar Gala
Moved CONFIG_MAX_MEM_MAPPED to the asm/config.h so its kept consistent between the two current users (lib_ppc/board.c, 44x SPD DDR2). Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Stefan Roese <sr@denx.de>
2009-02-10mpc86xx: Add support to populate addr map based on BATsBecky Bruce
If CONFIG_ADDR_MAP is enabled, update the address map whenever we write a bat. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
2009-01-27SATA: do not auto-initialize during bootMike Frysinger
Rather than have the board code initialize SATA automatically during boot, make the user manually run "sata init". This brings the SATA subsystem in line with common U-Boot policy. Rather than having a dedicated weak function "is_sata_supported", people can override sata_initialize() to do their weird board stuff. Then they can call the actual __sata_initialize(). Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-12-1985xx: Add support to populate addr map based on TLB settingsKumar Gala
2008-11-10lib_ppc: Move trap_init to occur earlierBecky Bruce
Doing trap_init immediately once we're running from RAM means we're no longer dependent on the physical location of the flash on non-BookE platforms. Before trap_init, those platforms switch to real mode and go to 0xfff00100 on exception. After the switch, they go to 0x00000100 This makes it easier to move the flash location. Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
2008-10-18Adds two more ethernet interface to 83xxrichardretanubun
Added as a convenience for other platforms that uses MPC8360 (has 8 UCC). Six eth interface is chosen because the platform I am using combines UCC1&2 and UCC3&4 as 1000 Eth and the other four UCCs as 10/100 Eth. Signed-off-by: Richard Retanubun <RichardRetanubun@RugggedCom.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-10-15Fix compiler warning in lib_ppc/board.cHeiko Schocher
Fix compiler warning introduced by commit 0f8cbc18 Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-10-14Do not init SATA when disabled on 8536DS.Jason Jin
SGMII and SATA share the serdes on MPC8536 CPU, When SATA disabled and the driver still try to access the SATA registers, the cpu will hangup. This patch try to fix this by reading the serdes status before the SATA initialize. Signed-off-by: Jason Jin <Jason.jin@freescale.com> Acked-by: Andy Fleming <afleming@freescale.com>
2008-09-10rename CFG_ENV_IS_NOWHERE in CONFIG_ENV_IS_NOWHEREJean-Christophe PLAGNIOL-VILLARD
2008-09-10rename CFG_ENV_IS_IN_NVRAM in CONFIG_ENV_IS_IN_NVRAMJean-Christophe PLAGNIOL-VILLARD
2008-09-10cmd_mac: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
finish remaning CFG_ID_EEPROM in CONFIG_ID_EEPROM start in commit ad8f8687b78c3e917b173f038926695383c55555 Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-08-21Consolidate strmhz() implementationHaavard Skinnemoen
ARM, i386, m68k and ppc all have identical implementations of strmhz(). Other architectures don't provide this function at all. This patch moves strmhz() into lib_generic, reducing code duplication and providing a more unified API across architectures. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-07-14Fix printf() format issues with sizeof_t types by using %zuWolfgang Denk
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-07-10Fix some more print() format errors.Wolfgang Denk
2008-07-06ppc4xx: Rename CONFIG_XILINX_ML300 to CONFIG_XILINX_405Michal Simek
This change helps with better handling with others Xilinx based platform. Signed-off-by: Michal Simek <monstr@monstr.eu> Acked-by: Stefan Roese <sr@denx.de>
2008-07-01Move conditional compilation of MPC8XXX SPI driver to MakefileBen Warren
