The patch fixes the bug of partial initialization of global network
parameters.
Upon u-boot's start up the first ping command causes a failure of the
consequent TFTP command. It happens in the recently added mechanism of
the NetLoop initialization where initialization of global network
parameters is separated in the NetInitLoop routine which is called per
env_id change. Thus, ping request will initialize the network parameters
necessary for ping operation only, afterwards the env_changed_id will be
set to the env_id that will prevent all following initialization requests
from other protocols.
The problem is that the initialized by ping subset of network parameters
is not sufficient for other protocols and particularly for TFTP which
requires the NetServerIp also.
Signed-off-by: Michael Zaidman <michael.zaidman@gmail.com>
NetLoop polls every cycle with getenv some environment variables.
This is horribly slow, especially when the environment is big.
This patch reads only the environment variables in NetLoop,
when they were changed.
Also moved the init part of the NetLoop function in a seperate
function.
This allows code to iterate through the ethernet devices
Signed-off-by: Andy Fleming <afleming@freescale.com>
This patch removes volatile from:
volatile IP_t *ip = (IP_t *)xip;
Due to a bug, avr32-gcc will assume that ip is aligned on a word boundary when
using volatile, which causes an exception since xip isn't aligned on a word
boundary.
Signed-off-by: Gunnar Rangoy <gunnar@rangoy.com>
Signed-off-by: Paul Driveklepp <pauldriveklepp@gmail.com>
Signed-off-by: Olav Morken <olavmrk@gmail.com>
Use the GNU 'date' command to auto-generate a new U-Boot
timestamp on every compile.
The TftpStart() function modifies the 'BootFile'
string when 'BootFile' contains both an IP address
and filename (eg 1.2.3.4:/path/file). This causes
subsequent calls to TftpStart to incorrectly parse
the TFTP filename and server IP address to use.
For example:
=> tftp 0x100000 10.52.0.62:/home/ptyser/non_existant
Speed: 100, half duplex
Using eTSEC1 device
TFTP from server 10.52.0.62; our IP address is 10.52.253.79
^^^^^^^^^^ CORRECT
Filename '/home/ptyser/non_existant'.
^^^^^^^^^^^^^^^^^^^^^^^^^ CORRECT
Load address: 0x100000
Loading: *
TFTP error: 'File not found' (1)
Starting again
eTSEC2: No link.
Using eTSEC1 device
TFTP from server 10.52.0.33; our IP address is 10.52.253.79
^^^^^^^^^^ WRONG
Filename '10.52.0.62'.
^^^^^^^^^^ WRONG
Loading: *
Starting again
TftpStart() was modified to not modify the 'BootFile' string.
Ignore IP packets which have the "more fragments" flag bit
set. This flag indicates the IP packet is fragmented and
must be ignored by U-Boot.
These defines were pulled from the "Add simple
IP/UDP fragmentation support" patch from Frank
Haverkamp <haver@vnet.ibm.com>.
Removed initialization of the driver from net/eth.c
All in-tree IBM/AMCC PPC4xx boards using the EMAC get this new CONFIG
Affected boards:
Several MPC8xx boards
Several MPC8260/MPC8272 boards
Several MPC85xx boards
This patch will move au1x00_eth_initialize from net/eth.c to cpu_eth_init
as a part of ongoing eth_initialize cleanup work. The function ret value
is also fixed as it should be negative on fail.
Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
Also, removed the driver initialization from net/eth.c
There are two aspects of a TFTP transfer involving timeouts:
1. timeout waiting for initial server reply after sending RRQ
2. timeouts while transferring actual data from the server
Since the upcoming auto-update feature attempts a TFTP download during each
boot, it is undesirable to have a long delay when the TFTP server is not
available. Thus, this commit makes the server timeout (1.) configurable by two
global variables:
TftpRRQTimeoutMSecs
TftpRRQTimeoutCountMax
TftpRRQTimeoutMSecs overrides default timeout when trying to connect to a TFTP
server, TftpRRQTimeoutCountMax overrides default number of connection retries.
The total delay when trying to download a file from a non-existing TFTP server
is TftpRRQTimeoutMSecs x TftpRRQTimeoutCountMax milliseconds.
Timeouts during file transfers (2.) are unaffected.
Signed-off-by: Rafal Czubak <rcz@semihalf.com>
Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
Enforce millisecond semantics of the first argument to NetSetTimeout() --
the change is transparent for well-behaving boards (CFG_HZ == 1000 and
get_timer() countiing in milliseconds).
Rationale for this patch is to enable millisecond granularity for
network-related timeouts, which is needed for the upcoming automatic
software update feature.
Summary of changes:
- do not scale the first argument to NetSetTimeout() by CFG_HZ
- change timeout values used in the networking code to milliseconds
Added as a convenience for other platforms that uses MPC8360 (has 8 UCC).
Six eth interface is chosen because the platform I am using combines
UCC1&2 and UCC3&4 as 1000 Eth and the other four UCCs as 10/100 Eth.
Signed-off-by: Richard Retanubun <RichardRetanubun@RugggedCom.com>
If a board has a variable number of flash banks, there are empty entries
in flash_info[] and CFG_DIRECT_FLASH_TFTP is set, tftp boot fails with
"Outside available Flash". This patch skips flash banks with unknown
flash ids.
Signed-off-by: Jochen Friedrich <jochen@scram.de>
Affected boards:
db64360
db64460
katmai
taihu
taishan
yucca
cpc45
cpu87
eXalion
elppc
debris
kvme080
mpc8315erdb
integratorap
ixdp425
oxc
pm826
pm828
pm854
pm856
ppmc7xx
sc3
sc520_spunk
sorcery
tqm8272
tqm85xx
utx8245
Also, wrapped contents of pci_eth_init() by CONFIG_PCI.
Affected boards:
cu824
bab7xx
adciop
dasa_sim
mousse
mpc8540eval
musenki
mvblue
pcippc2/pcippc6
sbc8240
stxssa
Affected boards:
ap1000
mvbc_p
PM854
Affected boards:
purple
Removed initialization of controller from net/eth.c
Modified board_eth_init() functions of boards that have this FEC in addition
to other Ethernet controllers.
Affected boards:
bc3450
icecube
mvbc_p
o2dnt
pm520
total5200
tq5200
Added a cpu_eth_init() function to MPC512x CPU directory and
removed code from net/eth.c
Affected boards:
IncaIP
Affected boards:
AmigaOneG3SE
Affected boards:
EVB64260
P3G4
ZUMA
Affected boards:
PN62
sc520_cdp
Affected boards:
a3000
Affected boards:
bc3450
cpci5200
mecp5200
pf2000
icecube
o2dnt
pm520
sandpoint8245
total5200
tqm5200
Affected boards:
mpc7448hpc2
Affected boards:
hidden_dragon
MPC8544DS
MPC8610HPCN
R2DPLUS
TB0229
Affected boards:
linkstation
r7780mp
Removed at91sam9_eth_initialize() from net/eth.c
DM644x is just one of a series of DaVinci chips that use the EMAC driver.
By replacing all the function names that start with dm644x_* to davinci_*
we make these function more portable. I have tested this change on my EVM.
DM6467 is another DaVinci SOC which uses the EMAC driver and i will
be sending patches that add DaVinci DM6467 support to the list soon.
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
The DHCP handler has 1 state that is not listed in this case, causing a
failure message when there is actually no failure.
Signed-off-by: Remy Bohmer <linux@bohmer.net>
The option CONFIG_BOOTP_RANDOM_DELAY does not compile, because of a
missing extern inside the net/bootp.h header
The only board using this driver is the SL8245 board.
Removed initialization for the driver from net/eth.c
The only board using this driver is the Freescale MPC8610HPCD board.
Added board_eth_init() function to bf537-stamp board.
Removed initialization for the Blackin EMAC driver from net/eth.c
Added a cpu_eth_init() function to leon2/leon3 CPU directories and
Added a cpu_eth_init() function to coldfire CPU directories and
Added a cpu_eth_init() function to cpu/mcf547x_8x directory and
Renamed initialization functions for atngw100 and atstk1000.
Removed initializations for these boards from net/eth.c
Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
