path: root/net
2011-05-19net/tftp.c: fix typoLuca Ceresoli
Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2011-05-19TFTP: add tftpsrv commandLuca Ceresoli
2011-05-19TFTP: net/tftp.c: add server mode receiveLuca Ceresoli
2011-05-19TFTP: rename STATE_RRQ to STATE_SEND_RRQLuca Ceresoli
With the upcoming TFTP server implementation, requests can be either outgoing or incoming, so avoid ambiguities. Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2011-05-19TFTP: replace "server" with "remote" in local variable namesLuca Ceresoli
With the upcoming TFTP server implementation, the remote node can be either a client or a server, so avoid ambiguities. Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2011-05-19net/tftp.c: cosmetic: do not initialise statics to 0 or NULLLuca Ceresoli
This removes the following checkpatch issue: - ERROR: do not initialise statics to 0 or NULL Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de>
2011-05-19net/tftp.c: cosmetic: fix indentationLuca Ceresoli
This removes the following checkpatch issue: - WARNING: suspect code indent for conditional statements Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de>
2011-05-19net/tftp.c: cosmetic: trailing statements should be on next lineLuca Ceresoli
This removes the following checkpatch issue: - ERROR: trailing statements should be on next line Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de>
2011-05-19net/tftp.c: cosmetic: fix brace issuesLuca Ceresoli
This removes the following checkpatch issues: - WARNING: braces {} are not necessary for single statement blocks - WARNING: braces {} are not necessary for any arm of this statement Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de>
2011-05-19net/tftp.c: cosmetic: do not use assignment in if conditionLuca Ceresoli
This removes the following checkpatch issue: - ERROR: do not use assignment in if condition. There is one such error left: ERROR: do not use assignment in if condition #239: FILE: tftp.c:239: + if (!ProhibitMcast + && (Bitmap = malloc(Mapsize)) + && eth_get_dev()->mcast) { which would require an additional nested if to be fixed, resulting in longer and less readable code. Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de>
2011-05-19net/tftp.c: cosmetic: fix pointer syntax issuesLuca Ceresoli
This removes the following checkpatch issues: - ERROR: "foo * bar" should be "foo *bar" - ERROR: "(foo*)" should be "(foo *)" Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de>
2011-05-19net/tftp.c: cosmetic: fix whitespace issuesLuca Ceresoli
This removes the following checkpatch issues: - ERROR: space prohibited before that close parenthesis ')' - ERROR: space required after that ';' (ctx:BxV) - ERROR: space required after that ',' (ctx:VxV) - ERROR: space required after that ';' (ctx:VxV) - ERROR: spaces required around that '<<=' (ctx:VxV) - ERROR: spaces required around that '<' (ctx:VxV) - ERROR: spaces required around that '=' (ctx:VxV) - ERROR: spaces required around that '+=' (ctx:VxV) - ERROR: spaces required around that '=' (ctx:VxW) - WARNING: please, no spaces at the start of a line - WARNING: space prohibited between function name and open parenthesis '(' Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de>
2011-05-19net/tftp.c: cosmetic: fix lines over 80 charactersLuca Ceresoli
2011-05-12net/net.c: cosmetic: do not use assignment in if conditionLuca Ceresoli
This removes the following checkpatch issue: - ERROR: do not use assignment in if condition Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de> Cc: Ben Warren <biggerbadderben@gmail.com>
2011-05-12net/net.c: cosmetic: fix indentationLuca Ceresoli
This removes the following checkpatch issues: - ERROR: switch and case should be at the same indent - WARNING: suspect code indent for conditional statements - WARNING: labels should not be indented Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de> Cc: Ben Warren <biggerbadderben@gmail.com>
2011-05-12net/net.c: cosmetic: parentheses not required for returnLuca Ceresoli
This removes the following checkpatch issue: - ERROR: return is not a function, parentheses are not required Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de> Cc: Ben Warren <biggerbadderben@gmail.com>
2011-05-12net/net.c: cosmetic: fix pointer syntax issuesLuca Ceresoli
This removes the following checkpatch issues: - ERROR: "foo * bar" should be "foo *bar" - ERROR: "(foo*)" should be "(foo *)" Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de> Cc: Ben Warren <biggerbadderben@gmail.com>
2011-05-12net/net.c: cosmetic: fix brace issuesLuca Ceresoli
This removes the following checkpatch issues: - WARNING: braces {} are not necessary for single statement blocks - WARNING: braces {} are not necessary for any arm of this statement Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de> Cc: Ben Warren <biggerbadderben@gmail.com>
2011-05-12net/net.c: cosmetic: fix whitespace issuesLuca Ceresoli
This removes the following checkpatch issues: - ERROR: space prohibited after that open parenthesis '(' - ERROR: space prohibited before that close parenthesis ')' - ERROR: space prohibited after that open square bracket '[' - ERROR: space prohibited after that '&' (ctx:WxW) - ERROR: spaces required around that '=' (ctx:VxW) - ERROR: space required before the open parenthesis '(' - ERROR: space required after that ',' (ctx:VxV) - ERROR: need consistent spacing around '+' (ctx:WxV) - WARNING: unnecessary whitespace before a quoted newline - WARNING: please, no spaces at the start of a line - WARNING: space prohibited between function name and open parenthesis '(' Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de> Cc: Ben Warren <biggerbadderben@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2011-05-12net/net.c: cosmetic: variable initializationsLuca Ceresoli
This removes the following checkpatch errors: - ERROR: do not initialise globals to 0 or NULL - ERROR: spaces required around that '=' (ctx:VxV) - ERROR: that open brace { should be on the previous line Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de> Cc: Ben Warren <biggerbadderben@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2011-05-12net/net.c: cosmetic: fix lines over 80 charactersLuca Ceresoli
This removes the following checkpatch warning: - WARNING: line over 80 characters There are three such warnings left. The first is hard to fix with cosmetic-only changes without compromising code readability, so I'm leaving it as it is for now: WARNING: line over 80 characters #1537: FILE: net.c:1537: + [4 tabs] memcpy(((Ethernet_t *)NetArpWaitTxPacket)->et_dest, ... The other two cannot be fixed without splitting string literals, so it is preferred to keep them longer than 80 characters. Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de> Cc: Ben Warren <biggerbadderben@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2011-05-12NET: pass source IP address to packet handlersLuca Ceresoli
This is needed for the upcoming TFTP server implementation. This also simplifies PingHandler() and fixes rxhand_f documentation. Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2011-05-12netconsole: remove `serverip' checkSimon Guinot
Netconsole use the environment variable `ncip' to configure the destination IP. `serverip' don't need to be defined. Signed-off-by: Simon Guinot <sguinot@lacie.com>
2011-04-28NET: Correct potential missing goto label in case statement.Gray Remlin
If neither CONFIG_CMD_PING or CONFIG_CMD_SNTP are defined but CONFIG_CMD_DNS is, a compile-time error will occur due to the absence of a goto label. Signed-off-by: Gray Remlin <gryrmln@gmail.com>
2011-04-20Create PHY Lib for U-BootAndy Fleming
Extends the mii_dev structure to participate in a full-blown MDIO and PHY driver scheme. The mii_dev structure and miiphy calls are modified in such a way to allow the original mii command and miiphy infrastructure to work as before, but also to support a new set of APIs which allow (among other things) sharing of PHY driver code and 10G support The mii command will continue to support normal PHY management functions (Clause 22 of 802.3), but will not be changed to support 10G (Clause 45). The basic design is similar to PHY Lib from Linux, but simplified for U-Boot's network and driver infrastructure. We now have MDIO drivers and PHY drivers An MDIO driver provides: read write reset A PHY driver provides: (optionally): probe config - initial setup, starting of auto-negotiation startup - waiting for AN, and reading link state shutdown - any cleanup needed The ethernet drivers interact with the PHY Lib using these functions: phy_connect() phy_config() phy_startup() phy_shutdown() Each PHY driver can be configured separately, or all at once using config_phylib_all_drivers.h (added in the patch which adds the drivers) We also provide generic drivers for Clause 22 (10/100/1000), and Clause 45 (10G) PHYs. We also implement phy_reset(), and call it in phy_connect(). Because phy_reset() is essentially the same as miiphy_reset, but: a) must support 10G PHYs, and b) should use the phylib primitives, we implement miiphy_reset, using phy_reset(), but only when CONFIG_PHYLIB is set. Otherwise, we just use the old version. In this way, we save on compile size, even if we don't manage to save code size. Pulled ethtool.h and mdio.h from: git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6 782d640afd15af7a1faf01cfe566ca4ac511319d With many, many deletions so as to enable compilation under u-boot Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Detlev Zundel <dzu@denx.de>
2011-04-13Fix bad padding of bootp request packetSimon Glass
This seems to pad to one byte longer than required Signed-off-by: Simon Glass <sjg@chromium.org>
2011-02-19Fix compile warning in net/eth.cRemy Bohmer
Signed-off-by: Remy Bohmer <linux@bohmer.net>
2011-02-19Add USB host ethernet adapter supportSimon Glass
This adds support for using USB Ethernet dongles in host mode. This is just the framework - drivers will come later. A new config option called CONFIG_USB_HOST_ETHER can be defined in board config files to switch this on. The was originally written by NVIDIA and was cleaned up for release by the Chromium authors. Signed-off-by: Simon Glass <sjg@chromium.org>
2010-11-28string_to_VLAN: constify "var" argMike Frysinger
2010-11-28copy_filename: constify "src" argMike Frysinger
2010-11-15Net: clarify board/cpu_eth_init callsBen Warren
This has always been confusing, and the idea of these functions returning the number of interfaces initialized was half-baked and ultimately pointless. Instead, act more like regular functions and return < 0 on failure, >= 0 on success. This change shouldn't break anything. Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-11-14net: Fix potential empty DHCP Parameter Request ListJason Liu
Can't get IP address with dhcp due to the dhcp server not allow the empty param list request under some network env This patch is based on Gray Remlin's initial patch. Signed-off-by: Jason Liu <r64343@freescale.com> Signed-off-by: Gray Remlin <g_remlin@rocketmail.com>
2010-10-11rarp: Condtionally compile rarp supportPeter Tyser
Most people don't use the 'rarpboot' command, so only enable it when CONFIG_CMD_RARP is defined. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-10-11Net: Remove redundant CONFIG_NET_MULTI directivesBen Warren
All are within an #ifdef CONFIG_NET_MULTI block already Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-08-09Fix compile warnings for const correctnessBen Warren
Commit 6e37b1a3a25004d3df5867de49fff6b3fc9c4f04 modifies several net calls to take a (const char *) parameter instead of (char *), but in some cases the modified functions call other functions taking (char *). The end result is warnings about discarding the const qualifier. This patch fixes these other function signatures. Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-07-12net: warn about spaces in device namesMike Frysinger
Some commands operate on eth device names (like 'mii'), but those cannot be passed on the command line as one argument. So detect devices like these and warn about them so someone will fix it. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-06-20net/eth.c: eth_mac_skip() is only needed when CONFIG_NET_MULTI is setWolfgang Denk
Move it inside the #ifdef CONFIG_NET_MULTI to avoid eth.c:64: warning: 'eth_mac_skip' defined but not used messages from a number of old, non-CONFIG_NET_MULTI boards. Signed-off-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-06-20ip/defrag: fix processing of last short fragmentFillod Stephane
TFTP'ing a file of size 1747851 bytes with CONFIG_IP_DEFRAG and CONFIG_TFTP_BLOCKSIZE set to 4096 fails with a timeout, because the last fragment is not taken into account. This patch fixes IP fragments having less than 8 bytes of payload. Signed-off-by: Stephane Fillod <stephane.fillod@grassvalley.com> Acked-by: Alessandro Rubini <rubini@gnudd.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-05-03Program net device MAC addresses after initializingBen Warren
Add a new function to the eth_device struct for programming a network controller's hardware address. After all network devices have been initialized and the proper MAC address for each has been determined, make a device driver call to program the address into the device. Only device instances with valid unicast addresses will be programmed. Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Acked-by: Detlev Zundel <dzu@denx.de> Tested-by: Prafulla Wadaskar <prafulla@marvell.com> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Thomas Chou <thomas@wytron.com.tw>
2010-05-03./net/net.c - make Microsoft dns servers happy with random_port() numbersRobin Getz
For some reason, (which I can't find any documentation on), if U-Boot gives a port number higher than 17500 to a Microsoft DNS server, the server will reply to port 17500, and U-Boot will ignore things (since that isn't the port it asked the DNS server to reply to). This fixes that by ensuring the random port number is less than 17500. Signed-off-by: Robin Getz <rgetz@blackfin.uclinux.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-05-03net: Trivial coding style issue with empty for statementDetlev Zundel
Signed-off-by: Detlev Zundel <dzu@denx.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-03-21TFTP: allow for adjustable retransmission timoutWolfgang Denk
So far, TFTP negotiated a fixed retransmission timeout of 5 seconds. In some cases (busy networks, slow TFTP servers) this caused very slow transfers. A new environment variable "tftptimeout" allows to set this timeout. Lowering this value may make downloads succeed faster in networks with high packet loss rates or with unreliable TFTP servers. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Ben Warren <biggerbadderben@gmail.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-01-17Make getenv_IPaddr() globalDirk Behme
There are boards out there that do not have network support in U-Boot (CONFIG_CMD_NET not set), but they do so in Linux. This makes it desirable to be able to port network configuration (like the IP address) to the Linux kernel. We should not make the passing of the IP configuration to Linux dependent on U-Boot features / settings. For this, make getenv_IPaddr() global. This fixes build error u-boot/lib_xxx/board.c:360: undefined reference to `getenv_IPaddr' on various architectures. Signed-off-by: Dirk Behme <dirk.behme@googlemail.com> Acked-by: Ben Warren <biggerbadderben@gmail.com>
2009-12-13Add error codes/handling for TFTP-serverRemy Bohmer
Signed-off-by: Remy Bohmer <linux@bohmer.net> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-12-13net: pull CONFIG checks out of source and into makefileMike Frysinger
2009-12-07nfs: NfsTimeout() updatesEvan Samanas
- NfsTimeout() does not correctly update the NFS timeout value which results in NfsTimeout() only being called once in certain situations. This can result in the 'nfs' command hanging indefinetly. For example, the command: nfs 192.168.0.1:/home/user/file will not exit until ctrl-c is pressed if 192.168.0.1 does not have an NFS server running. This issue is resolved by reinitializting the NFS timeout value inside NfsTimeout() when a timeout occurs. - Make the 'nfs' command print the 'T' character when a timeout occurs. Previously there was no indication that timeouts were occuring. - Mimic the 'tftpboot' command and when a download fails print "Retry count exceeded; starting again", and restart the download taking the 'netretry' environment variable into account. Signed-off-by: Evan Samanas <esamanas@xes-inc.com> Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Tested on TQM8xxL. Tested by: Wolfgang Denk <wd@denx.de> Tested on MPC8527DS. Tested by: Ed Swarthout <Ed.Swarthout@freescale.com>
2009-12-07fix nfs symlink name corruptionEd Swarthout
An off by one error may cause nfs readlink lookup fail if nfs_path_buff has non-zero data from a previous use. Loading: *** ERROR: File lookup fail Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
2009-11-24Repair the 'netretry=once' option.Remy Bohmer
'netretry = once' does the same as 'netretry = yes', because it is not stored when it was tried once. Signed-off-by: Remy Bohmer <linux@bohmer.net> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-09-11net/bootp.c: fix compile warningWolfgang Denk
Fix warning: bootp.c:695: warning: dereferencing type-punned pointer will break strict-aliasing rules Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Ben Warren <biggerbadderben@gmail.com>
