path: root/post
2003-04-27* LWMON extensions:wdenk
- Splashscreen support - modem support - sysmon support - temperature dependend enabling of LCD * Allow booting from old "PPCBoot" disk partitions * Add support for TQM8255 Board / MPC8255 CPU
2003-04-10Add support for TQM862L moduleswdenk
2002-12-17* Use 1-byte-read instead of -write for iprobe() functionwdenk
Add i2c commands to PM826 config * extend I2C POST code: check for list on known addresses
2002-12-08* Improve log buffer code; use "loglevel" to decide which messageswdenk
to log on the console, too (like in Linux); get rid of "logstart"
2002-12-03* Fix startup problems with VFD display on TRABLABEL_2002_12_03_2230wdenk
* Patch by Pierre Aubert, 20 Nov 2002 Add driver for Epson SED13806 graphic controller. Add support for BMP logos in cfb_console driver.
2002-11-21* Added support for both PCMCIA slots (at the same time!) on MPC8xxLABEL_2002_11_22_0015wdenk
* Patch by Rod Boyce, 21 Nov 2002: fix PCMCIA on MBX8xx board * Patch by Pierre Aubert , 21 Nov 2002 Add CFG_CPM_POST_WORD_ADDR to make the offset of the bootmode word in DPRAM configurable
2002-11-05* Add support for log buffer which can be passed to Linux kernel'sLABEL_2002_11_05_1735wdenk
syslog mechanism; used especially for POST results. * Patch by Klaus Heydeck, 31 Oct 2002: Add initial support for kup4k board
2002-10-07Initial revisionwdenk
2002-09-24Initial revisionwdenk
2002-09-12Initial revisionwdenk
2002-08-27Initial revisionwdenk
