path: root/scripts/mkmakefile
2014-11-12kbuild: Make scripts executableMasahiro Yamada
The Makefiles call the respective interpreter explicitly, but this makes it easier to use the scripts manually. (This commit follows commit 06ed5c2bfaca of Linux Kernel) Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-08-21kbuild: sync mixed targets handling with Linux 3.16Masahiro Yamada
"make %_config all" was supported for the first time in U-Boot: commit 53bca5ab kbuild: support simultaneous board configuration and "make all" Surprisingly it had not been working in Linux Kernel for a long time. So I sent back the patch to the Linux Kbuild community and it was accepted with a little code improvement, at commit 9319f453. Now, you can do "make defconfig all" or "make %_defconfig all" in Linux too. This commit updates some scripts to fill the code-diff between Linux and U-Boot. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19kbuild: import more build scripts from Linux v3.13 tagMasahiro Yamada
This commit imports build scripts from Linux Kernel v3.13 as they are. I know they include some trailing spaces but I am intentionally keeping them untouched. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
