path: root/spl
2012-03-30Define CPUDIR for the .lds link scriptSimon Glass
Most link scripts differ only in the directory containing the start.o file. Make this a #define to remove this last difference. (Note that if start.o were disallowed outside the CPU start directory then we wouldn't even need this. But that is a separate discussion.) Signed-off-by: Simon Glass <sjg@chromium.org>
2012-03-30Allow arch directory to contain .lds without requiring MakefileSimon Glass
The Makefile for a CPU is in arch/($ARCH)/cpu/$(CPU). We want to support having an .lds file in arch/$(ARCH)/cpu without requiring an additional Makefile there. This change makes it clear that we expect a Makefile in the same directory as the link script except in this case. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-01-16ARM:AM33XX: Add SPL support for AM335X EVMChandan Nath
This patch is added to support SPL feature on AM335X platform. In this patch, MMC1 is configured as boot device for SPL and support for other devices will be added in the next patch series. Signed-off-by: Chandan Nath <chandan.nath@ti.com> Signed-off-by: Tom Rini <trini@ti.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2011-11-15omap5: Add minimal support for omap5430.Sricharan
This patch adds the minimal support for OMAP5. The platform and machine specific headers and sources updated for OMAP5430. OMAP5430 is Texas Instrument's SOC based on ARM Cortex-A15 SMP architecture. It's a dual core SOC with GIC used for interrupt handling and SCU for cache coherency. Also moved some part of code from the basic platform support that can be made common for OMAP4/5. Rest is kept out seperately. The same approach is followed for clocks and emif support in the subsequent patches. Signed-off-by: sricharan <r.sricharan@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-11-15OneNAND: Add simple OneNAND SPLMarek Vasut
This introduces small OneNAND loader, fitting into 1kB of space (smallest possible OneNAND RAM size). Some devices equipped with such crappy chips will use this. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Scott Wood <scottwood@freescale.com> V2: Introduce spl_onenand_load_image() to load data from OneNAND in SPL V3: Cleanup, align with nand_spl. Skip whole blocks.
2011-11-03spl: add option for adding post memory test to the SPL frameworkHeiko Schocher
Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Sandeep Paulraj <s-paulraj@ti.com> Cc: Sergei Shtylyov <sshtylyov@mvista.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-11-03ORIGEN : use absolute paths and fix tool namingAngus Ainslie
On some hosts using relative paths will cause the build to fail. This patch sets absolute paths for the tools directory Get rid of MSDOS style excecutable extension Signed-off-by: Angus Ainslie <angus.ainslie@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-10-27SPL: Add DMA librarySimon Schwarz
Adding a DMA library to the SPL. It is used if CONFIG_SPL_DMA_SUPPORT is defined. Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-10-05SPL: Make path to start.S configurableMarek Vasut
Introduce CONFIG_SPL_START_S_PATH to configure path to start.S file. It's not always fitting to use CPU's start.S . Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
2011-09-30spl: Add POWER library to new splSimon Schwarz
Adds power library to the new spl Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-30spl: add NAND Library to new SPLSimon Schwarz
Adds NAND library to SPL. Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com> Acked-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04ORIGEN: Add MMC SPL supportChander Kashyap
Adds mmc boot support. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-08-03mkimage: Add OMAP boot image supportJohn Rigby
- Add mkimage support for OMAP boot image - Add support for OMAP boot image(MLO) generation in the new SPL framework Signed-off-by: John Rigby <john.rigby@linaro.org> Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-07-26spl: add support for omap-common librariesDaniel Schwierzeck
Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
2011-07-26spl: Add support for common libraries and driversDaniel Schwierzeck
2011-07-26spl: add initial support for a generic SPL frameworkDaniel Schwierzeck
