path: root/test
2020-07-05sandbox, test: add test for GPIO_HOG functionHeiko Schocher
currently gpio hog function is not tested with "ut dm gpio" so add some basic tests for gpio hog functionality. For this enable GPIO_HOG in sandbox_defconfig, add in DTS some gpio hog entries, and add testcase in "ut dm gpio" command. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-06-30test/py: test_efi_fit: Update #size-cells to 1Bin Meng
test_efi_fit tests fail on RISC-V currently. This is due to the RISC-V arch_fixup_fdt() checks the #size-cells of the root node in order to correctly fix up the reserved memory node. Per the DT binding, the /reserved-memory node requires both <#address-cells> and <#size-cells> and they should use the same values as the root node. For the root node, it's not very useful if <#size-cells> is zero. Update #size-cells to 1 so tests can pass. Signed-off-by: Bin Meng <bin.meng@windriver.com>
2020-06-03Merge https://gitlab.denx.de/u-boot/custodians/u-boot-spiTom Rini
- Toshiba spinand (Yoshio) - SPI/SPI Flash cleanup (Jagan) - Remove SH SPI (Jagan)
2020-06-02test/py: use actual core count for parallel buildsHeinrich Schuchardt
When building U-Boot we should not blindly use make -j8 but consider the actual core count given by os.cpu_count(). Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Stephen Warren <swarren@nvidia.com>
2020-06-01sf: Drop spl_flash_get_sw_write_protJagan Teki
The get_sw_write_prot API is used to get the write-protected bits of flash by reading the status register and other wards it's API for reading register bits. 1) This kind of requirement can be achieved using existing flash operations and flash locking API calls instead of making a separate flash API. 2) Technically there is no real hardware user for this API to use in the source tree. 3) Having a flash operations API for simple register read bits also make difficult to extend the flash operations. 4) Instead of touching generic code, it is possible to have this functionality inside spinor operations in the form of flash hooks or fixups for associated flash chips. Considering all these points, this patch drops the get_sw_write_prot and associated code bases. Cc: Simon Glass <sjg@chromium.org> Cc: Vignesh R <vigneshr@ti.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2020-05-25Merge tag 'ti-v2020.07-rc3' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-ti - Enable DM_ETH on omap3_logic board - Enable Caches in SPL for K3 platforms - Enable backup boot mode support for J721E - Update the DDR timings for AM654 EVM - Add automated tests for RX-51
2020-05-19test: Use ut_asserteq_mem() where possibleSimon Glass
Quite a few tests still use ut_assertok(memcmp(...)) and variants. Modify them to use the macro designed for this purpose. Suggested-by: Wolfgang Wallner <wolfgang.wallner@br-automation.com> Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Wolfgang Wallner <wolfgang.wallner@br-automation.com>
2020-05-19Nokia RX-51: Add automated test for running RX-51 build in qemuPali Rohár
This patch contains test/nokia_rx51_test.sh script which automatically download and compile all needed tools in local temporary directory to generate a simple MTD images for booting Maemo kernel image by U-Boot from RAM, eMMC and OneNAND. MTD images are then run in virtual n900 machine provided by qemu-linaro project. This script does not need any special privileges, so it can be run as non-root nobody user. It can be used to check that U-Boot for Nokia N900 is not broken and can be successfully booted in emulator. Script is registered to .azure-pipelines.yml, .gitlab-ci.yml and .travis.yml so it would be automatically run on those CI services. Signed-off-by: Pali Rohár <pali@kernel.org>
2020-05-18common: Drop linux/delay.h from common headerSimon Glass
Move this uncommon header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop log.h from common headerSimon Glass
Move this header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18command: Remove the cmd_tbl_t typedefSimon Glass
We should not use typedefs in U-Boot. They cannot be used as forward declarations which means that header files must include the full header to access them. Drop the typedef and rename the struct to remove the _s suffix which is now not useful. This requires quite a few header-file additions. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop image.h from common headerSimon Glass
2020-05-18common: Drop part.h from common headerSimon Glass
2020-05-18common: Drop net.h from common headerSimon Glass
Move this header out of the common header. Network support is used in quite a few places but it still does not warrant blanket inclusion. Note that this net.h header itself has quite a lot in it. It could be split into the driver-mode support, functions, structures, checksumming, etc. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-12Merge tag 'u-boot-amlogic-20200511' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-amlogic - Enable USB Host for Odroid-C2 board - Add Open-Drain/Open-Source emulation in GPIO uclass
2020-05-11Merge tag 'efi-2020-07-rc2-4' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-efi Pull request for UEFI sub-system for efi-2020-07-rc2-4 This pull request comprises: * bug fixes * documentation fixes * a new function to determine u16 string sizes and its unit test
2020-05-11test: dm: update test for open-drain/open-source emulation in gpio-uclassNeil Armstrong
Add tests for testing open-drain/open-source emulation in gpio-uclass. It also adds two test3-gpios configured as GPIO_ACTIVE_LOW. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-05-10Merge branch 'master' of git://git.denx.de/u-bootStefano Babic
2020-05-09test: unit test for u16_strsize()Heinrich Schuchardt
Provide a test for new Unicode library function u16_strsize(). Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2020-05-08test: fix naming of test functions in the log test suiteHeinrich Schuchardt
Both the nolog as well as the syslog tests were not found by Python function generate_ut_subtest() due to not following the nameing requirements imposed by the regular expression used to find linker generated list entries in file u-boot.sym. Adjust the naming of test functions. With the patch the following tests are executed successfully for sandbox_defconfig: test/py/tests/test_ut.py::test_ut[ut_log_syslog_debug] PASSED test/py/tests/test_ut.py::test_ut[ut_log_syslog_err] PASSED test/py/tests/test_ut.py::test_ut[ut_log_syslog_info] PASSED test/py/tests/test_ut.py::test_ut[ut_log_syslog_nodebug] PASSED test/py/tests/test_ut.py::test_ut[ut_log_syslog_notice] PASSED test/py/tests/test_ut.py::test_ut[ut_log_syslog_warning] PASSED The nolog tests are only executed if CONFIG_LOG=n and CONFIG_CONSOLE_RECORD=y. Reported-by: Simon Glass <sjg@chromium.org> Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2020-05-08test: describe naming conventions for macro UNIT_TESTHeinrich Schuchardt
Strict naming conventions have to be followed for Python function generate_ut_subtest() to collect C unit tests to be executed via command 'ut'. Describe the requirements both on the C as well on the Python side. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-05-05Merge git://git.denx.de/u-boot-usbTom Rini
- MediaTek USB host support
2020-05-04test: stabilize test_efi_secbootHeinrich Schuchardt
When setting up the console via function efi_console_register() we call query_console_serial(). This functions sends an escape sequence to the terminal to query the display size. The response is another escape sequence. console.run_command_list() is looking for a regular expression '^==>'. If the escape sequence for the screen size precedes the prompt without a line break, no match is found. When efi_disk_register() is called before efi_console_register() this leads to a test failuere of the UEFI secure boot tests. We can avoid the problem if the first UEFI command passed to u_boot_console.run_command_list() produces output. This patch achieves this by appending '; echo' to the first UEFI related command of the problematic tests. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2020-05-04lib/crypto, efi_loader: move some headers to include/cryptoAKASHI Takahiro
Pkcs7_parse.h and x509_parser.h are used in UEFI subsystem, in particular, secure boot. So move them to include/crypto to avoid relative paths. Suggested-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Don't include include x509_parser.h twice. Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2020-05-03test: cpu: test current cpuPeng Fan
Add test whether the CPU is U-Boot is running from. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Peng Fan <peng.fan@nxp.com>
2020-05-02test: dm: phy: add a test item for the phy_bulk APIChunfeng Yun
Add a test item for the phy_bulk API Signed-off-by: Chunfeng Yun <chunfeng.yun@mediatek.com> Signed-off-by: Frank Wunderlich <frank-w@public-files.de> Reviewed-by: Weijie Gao <weijie.gao@mediatek.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
2020-05-02test: dm: add test item for ofnode_get_child_count()Chunfeng Yun
Add a test item for ofnode_get_child_count() Signed-off-by: Chunfeng Yun <chunfeng.yun@mediatek.com> Signed-off-by: Frank Wunderlich <frank-w@public-files.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Weijie Gao <weijie.gao@mediatek.com>
2020-05-01test/py: vboot: add a test to check fit signature on fit with paddingPhilippe Reynes
The pytest vboot does all his tests on fit without padding. We add the same tests on fit with padding. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com>
2020-04-30Merge tag 'efi-2020-07-rc2' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-efi Pull request for UEFI sub-system for efi-2020-07-rc2 This pull request contains bug fixes needed due to the merged changes for EFI secure boot. Patches are supplied to identify EFI system partitions.
2020-04-30acpi: Add an acpi commandSimon Glass
It is useful to dump ACPI tables in U-Boot to see what has been generated. Add a command to handle this. To allow the command to find the tables, add a position into the global data. Support subcommands to list and dump the tables. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Wolfgang Wallner <wolfgang.wallner@br-automation.com>
2020-04-30acpi: Move the xsdt pointer to acpi_ctxSimon Glass
Put this in the context along with the other important pointers. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Wolfgang Wallner <wolfgang.wallner@br-automation.com>
2020-04-30acpi: Put table-setup code in its own functionSimon Glass
We always write three basic tables to ACPI at the start. Move this into its own function, along with acpi_fill_header(), so we can write a test for this code. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-04-30acpi: Move acpi_add_table() to generic codeSimon Glass
Move this code to a generic location so that we can test it with sandbox. This requires adding a few new fields to acpi_ctx, so drop the local variables used in the original code. Also use mapmem to avoid pointer-to-address casts which don't work on sandbox. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Wolfgang Wallner <wolfgang.wallner@br-automation.com>
2020-04-30acpi: Convert part of acpi_table to use acpi_ctxSimon Glass
The current code uses an address but a pointer would result in fewer casts. Also it repeats the alignment code in a lot of places so this would be better done in a helper function. Update write_acpi_tables() to make use of the new acpi_ctx structure, adding a few helpers to clean things up. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Wolfgang Wallner <wolfgang.wallner@br-automation.com>
2020-04-30acpi: Add a method to write tables for a deviceSimon Glass
A device may want to write out ACPI tables to describe itself to Linux. Add a method to permit this. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Wolfgang Wallner <wolfgang.wallner@br-automation.com>
2020-04-30test/py: fix test_efi_secboot/conftest.pyHeinrich Schuchardt
If udisksctl is present test/py/tests/test_efi_secboot/conftest.py fails because the disk image is never mounted. Normal users can only mount fuse file systems. Unfortunately fusefat is still in an experimental state and seems not to work here correctly. So as we have to be root or use the sudo command anyway delete all coding referring to udisksctl. -- We should not use mount point /mnt as this directory or one of its sub-directories might already be in use as active mount points. Instead create a new directory in the build root as mount point. -- Remove debug print statements that have been commented out. print without parentheses is anyway invalid in Python 3. And pytest anyway filters out the output if there is no exception reported. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2020-04-28Merge tag 'dm-pull-27apr20' of git://git.denx.de/u-boot-dmTom Rini
Move Python tools to use absolute paths Minor buildman fixes for new features Make libfdt code more similar to upsteam
2020-04-27test: test_fs error messageHeinrich Schuchardt
For non-root users mkfs.vfat is not in the search path at least on Debian. Hence when running 'make tests' a message indicates that file system tests have been skipped: SKIPPED [13] test/py/tests/test_fs/conftest.py:340: Setup failed for filesystem: fat16 This message is not really helpful as the executed program is not indicated. Provide a more complete message like SKIPPED [13] test/py/tests/test_fs/conftest.py:340: Setup failed for filesystem: fat16. Command 'mkfs.vfat -F 16 build-sandbox/persistent-data/3GB.fat16.img' returned non-zero exit status 127. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2020-04-26Add a 'make tcheck' option to test toolsSimon Glass
Running all the unit tests takes a while and is not useful when you are just modifying the tools. Add an option to run only the tools tests. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-04-24lib: Add a function to convert a string to upper caseSimon Glass
Add a helper function for this operation. Update the strtoul() tests to check upper case as well. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2020-04-24test: Add the beginnings of some string testsSimon Glass
There are quite a few string functions in U-Boot with no tests. Make a start by adding a test for strtoul(). Signed-off-by: Simon Glass <sjg@chromium.org>
2020-04-16test: pinmux: add pincontrol-gpio for pin configurationPatrick Delaunay
Add a simple pincontrol associated to the sandbox gpio driver, that allows to check pin configuration with the command pinmux. The pinmux test is also updated to test behavior with 2 pincontrols. Example to check LED pin configuration: => pinmux list | Device | Driver | Parent | pinctrl-gpio | sandbox_pinctrl_gpio | root_driver | pinctrl | sandbox_pinctrl | root_driver => pinmux dev pinctrl-gpio => pinmux status a0 : gpio input . a1 : gpio input . a2 : gpio input . a3 : gpio input . a4 : gpio input . a5 : gpio output . a6 : gpio output . ... Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2020-04-16test: dm: update test for pins configuration in gpioPatrick Delaunay
Add tests for new API set_dir_flags and set_dir_flags and associated code in gpio uclass. Test support for new flags GPIO_OPEN_DRAIN, GPIO_OPEN_SOURCE GPIO_PULL_UP and GPIO_PULL_DOWN. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2020-04-16test: dm: update test for pins configuration in pinctrl nodePatrick Delaunay
Add test for "pins" configuration in gpio uclass with set_state() ops and test for generic parsing of pinconf_param array). set_state() is called by: - pinctrl_generic_set_state |- pinctrl_generic_set_state_subnode Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-04-16gpio: remove the open_drain API and opsPatrick Delaunay
This patch removes the ops get_open_drain/set_open_drain and the API dm_gpio_get_open_drain/dm_gpio_set_open_drain. The ops only provided in one driver (mpc8xxx gpio) and the associated API is never called in boards. This patch prepare a more generic set/get_dir_flags ops, including the open drain property. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2020-04-16dm: core: add ofnode and dev function to iterate on node propertyPatrick Delaunay
Add functions to iterate on all property with livetree - dev_read_first_prop - dev_read_next_prop - dev_read_prop_by_prop and - ofnode_get_first_property - ofnode_get_next_property - ofnode_get_property_by_prop And helper: dev_for_each_property For example: struct ofprop property; dev_for_each_property(property, config) { value = dev_read_prop_by_prop(&property, &propname, &len); or: for (res = ofnode_get_first_property(node, &property); !res; res = ofnode_get_next_property(&property)) { value = ofnode_get_property_by_prop(&property, &propname, &len); .... } Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-04-16Merge tag 'efi-2020-07-rc1' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-efi Pull request for UEFI sub-system for efi-2020-07-rc1 This pull request * provides an implementation of UEFI secure booting * fixes a problem with the rsa_mod_exp driver which stops some boards from booting when CONFIG_RSA is enabled which is needed for UEFI secure booting * enables the EFI_RNG_PROTOCOL if DM_RNG is enabled * fixes some function comments
2020-04-16Merge tag 'dm-pull-10apr20-take2' of git://git.denx.de/u-boot-dmTom Rini
Functions for reading indexed values from device tree Enhancements to 'dm' command Log test enhancements and syslog driver DM change to read parent ofdata before children Minor fixes
2020-04-16dm: core: Read parent ofdata before childrenSimon Glass
At present a device can read its ofdata before its parent has done the same. This can cause problems in the case where the parent has a 'ranges' property, thus affecting the operation of dev_read_addr(), for example. We already probe parent devices before children so it does not seem to be a large step to do the same with ofdata. Make the change and update the documentation in this area. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Ley Foon Tan <ley.foon.tan@intel.com>
2020-04-16test: fdtdec: test fdtdec_set_carveout()Laurentiu Tudor
Add a new test for fdtdec_set_carveout(). Signed-off-by: Laurentiu Tudor <laurentiu.tudor@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org> Drop blank line at EFO: Signed-off-by: Simon Glass <sjg@chromium.org>
