path: root/tools/patman/series.py
2016-10-09patman: Make print statements python 3.x safePaul Burton
In python 3.x, print must be used as a function call. Convert all print statements to the function call style, importing from __future__ where we print with no trailing newline or print to a file object. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-09patman: Replace tabs with spacesPaul Burton
In preparation for running on python 3.x, which will refuse to run scripts which mix tabs & spaces for indentation, replace 2 tab characters present in series.py with spaces. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-02-24patman: fix series-notes handling for buildmanAlbert ARIBAUD
A patman series with a 'Series-notes' section causes buildman to crash with: self.series.notes += self.section TypeError: cannot concatenate 'str' and 'list' objects Fix by initializing series.notes as a one-element array rather than a scalar. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2015-08-31buildman: Correct 'Series-cover-cc' detection logicSimon Glass
This requires 'Series-cover_cc' at present which is incorrect. Fix it. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-23patman: check git format.subjectprefix setting when generate patches prefixWu, Josh
For the local project, we may specified format.subjectprefix setting. Then the patch will be formated as [Project_prefix][PATCH]. But patman will not check this setting. It will remove the format.subjectprefix. So This patch will let patman check this setting and add it as a project prefix. Signed-off-by: Josh Wu <josh.wu@atmel.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2015-01-30patman: Make dry-run output match real functionalityPeter Tyser
When run with the --dry-run argument patman prints out information showing what it would do. This information currently doesn't line up with what patman/git send-email really do. Some basic examples: - If an email address is addressed via "Series-cc" and "Patch-cc" patman shows that email address would be CC-ed two times. - If an email address is addressed via "Series-to" and "Patch-cc" patman shows that email address would be sent TO and CC-ed. - If an email address is addressed from a combination of tag aliases, get_maintainer.pl output, "Series-cc", "Patch-cc", etc patman shows that the email address would be CC-ed multiple times. Patman currently does try to send duplicate emails like the --dry-run output shows, but "git send-email" intelligently removes duplicate addresses so this patch shouldn't change the non-dry-run functionality. Change patman's output and email addressing to line up with the "git send-email" logic. This trims down patman's dry-run output and prevents confusion about what patman will do when emails are actually sent. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-09-21patman: Add a -m option to avoid copying the maintainersSimon Glass
The get_maintainers script is a useful default, but sometimes is copies too many people, or takes a long time to run. Add an option to disable it and update the README. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-05-09buildman: Allow conflicting tags to avoid spurious errorsSimon Glass
Conflicting tags can prevent buildman from building two series which exist one after the other in a branch. There is no reason not to allow this sort of workflow with buildman, so ignore conflicting tags in buildman. Change-Id: I2231d04d8684fe0f8fe77f8ea107e5899a3da5e8 Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@ti.com>
2013-04-08patman: Add Series-process-log tag to sort/uniq change logsSimon Glass
For some series with lots of changes it is annoying that duplicate change log items are not caught. It is also helpful sometimes to sort the change logs. Add a Series-process-log tag to enable this, which can be placed in a commit to control this. The change to the Cc: line is to fix a checkpatch warning. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Doug Anderson <dianders@chromium.org>
2013-04-08patman: Provide option to ignore bad aliasesSimon Glass
Often it happens that patches include tags which don't have aliases. It is annoying that patman fails in this case, and provides no option to continue other than adding empty tags to the .patman file. Correct this by adding a '-t' option to ignore tags that don't exist. Print a warning instead. Since running the tests is not a common operation, move this to --test instead, to reserve -t for this new option. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Doug Anderson <dianders@chromium.org>
2013-04-04patman: Add Cover-letter-cc tag to Cc cover letter to peopleSimon Glass
The cover letter is sent to everyone who is on the Cc list for any of the patches in the series. Sometimes it is useful to send just the cover letter to additional people, so that they are aware of the series, but don't need to wade through all the individual patches. Add a new Cover-letter-cc tag for this purpose. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Doug Anderson <dianders@chromium.org>
2013-01-31patman: Add a call to get_maintainer.pl if it existsDoug Anderson
For Linux the best way to figure out where to send a patch is with the "get_maintainer.pl" script. Add support for calling it from patman. Support is added unconditionally for "scripts/get_maintainer.pl" in case it is helpful for any other projects. Signed-off-by: Doug Anderson <dianders@chromium.org>
2013-01-31patman: Add all CC addresses to the cover letterDoug Anderson
If we're sending a cover letter make sure to CC everyone that we're CCing on each of the individual patches. Signed-off-by: Doug Anderson <dianders@chromium.org>
2013-01-31patman: Cache the CC list from MakeCcFile() for use in ShowActions()Doug Anderson
Currently we go through and generate the CC list for patches twice. This gets slow when (in a future CL) we add a call to get_maintainer.pl on Linux. Instead of doing things twice, just cache the CC list when it is first generated. Signed-off-by: Doug Anderson <dianders@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2012-11-14patman: Issue empty change logs for unchanged patchesSimon Glass
Often a particular patch may change only for some versions of a series. For versions where there is no change, issue a change log indicating that (for example 'Changes in v4: None'). For such lines, don't add a blank line afterwards, to conserve space. Use list.insert() instead of list = [item] + list. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Stefan Roese <sr@denx.de>
2012-10-15patman: Support Series-name tag to name a seriesSimon Glass
Sometimes it is possible to forget the name of the branch you used to generate an upstream series. To assist with this, add an optional patman does not use this. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-09-26patman: Use reverse order for changelogOtavio Salvador
Specially when many revisions are need for a patchset, the most interesting information is about the last set of changes so we output the changelog in reverse order to easy identification of most recent change set. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Simon Glass <sjg@chromium.org>
2012-09-02patman: Do not Cc addresses included in To listOtavio Salvador
In case an address is listed in the To list, those will be skipped on Cc list or user might end with a duplicated message. This fixes the case when a tag points to same address used as series destination thus avoiding duplicated sending. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2012-09-02patman: Allow for changelog use in first version of a seriesOtavio Salvador
When a patchset had a RFC series, a v1 might have a changelog of changes done since the RFC. The patch changes the range checked for changelog and allow it to start for version 1. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Simon Glass <sjg@chromium.org>
2012-09-02patman: don't mess with changelogIlya Yanok
Don't try to sort and uniq changelog entries as this breaks multiline entries. It will be better to add some real multi-line support but for now just preserve the entries as is. Signed-off-by: Ilya Yanok <ilya.yanok@cogentembedded.com>
2012-04-21Add 'patman' patch generation, checking and submission scriptSimon Glass
What is this? ============= This tool is a Python script which: - Creates patch directly from your branch - Cleans them up by removing unwanted tags - Inserts a cover letter with change lists - Runs the patches through checkpatch.pl and its own checks - Optionally emails them out to selected people It is intended to automate patch creation and make it a less error-prone process. It is useful for U-Boot and Linux work so far, since it uses the checkpatch.pl script. It is configured almost entirely by tags it finds in your commits. This means that you can work on a number of different branches at once, and keep the settings with each branch rather than having to git format-patch, git send-email, etc. with the correct parameters each time. So for example if you put: in one of your commits, the series will be sent there. See the README file for full details. END Signed-off-by: Simon Glass <sjg@chromium.org>
